One Of My Best Tool investments
AJL
Hi just thought i'd share this with you couple of years ago now I decided to invest in some new sockets etc.
I bought the Halfords Pro 150 piece socket & Spanner set for £99.00 usual price £149 i've got to say its a really superb kit as well as every socket your ever likely to need biggest 32mm you also get a selection of great quality ring / openended spanners plus ratchet spanners too.
They usually discount this at Christmas and easter etc in their sale so if you wait you'll save £50!
The kit is guaranteed "lifetime" which enabled me to exchange for new a broken socket even after i'd used it as a drift to knock bearings out :blink: No questions asked just OK mate here you go!
The kit comes in an ABS Plastic case and is excellent to stick in the back of the truck
Product info:
Chrome vanadium steel sockets and accessories
Fully polished chrome vanadium steel ratchets and combination spanners
Ratchet spanners metric with robust ratchet mechanism requires just 6 degrees movement to turn fastener
An unbeatable selection of Halfords professional tools - designed for the professional mechanic.Comes with Lifetime Guarantee.
PS I dont work for Halfords!!
Another vote here for Halfords professional socket sets and spanners. I have a 1/2" drive set and a much older and still going strong 3/8" and 1/4" drive set, as well as loads of combination and ratchet spanners too. It's all good quality kit (make sure you get the 'professional' range) and I don't think you can buy better for the same money.
I don't work for Halfords either :unsure:
I've been using mine for about 5 years now - absolutely brilliant :)
I'd buy the same again without thinking about it
My top tip is, if you buy the Halfords tool chests, the black (industrial/proffesional) ones, then the plastic case can be cut along the hinge, and both bits fit perfectly in two drawers.
Ive had exactly the same kit for 7 years now, very good, I've broken several things over the years but always by using them for purposes other than designed :-) no problems with replacing bits though..
Interestingly when I bought mine it only came with a 1 year guarantee - however they upgraded this to lifetime on all their 'professional' kits after a couple of years, even ones they had sold previously :-) well handy...
Ben
I use Halfords proffesional too. I have 1/4, 3/8, and 1/2 drive socket set, plus metric and imperial spanners.
The 3/8 rachet now slips occasionally, so I'll be taking advantage of the guarantee soon.
Les.
Top Tip time!
DONT, I say DONT try to preserve your receipt by putting it through a laminator, the paper is heat sensitive and just turns black!
Halfords cant supply a copy receipt, but said they would replace without a receipt as the proffesional range is clearly different.
  • 1 month later...
  • 2 weeks later...
Top Tip time!
I had a chat with them about this and they said that it is because they were suffering a lot of fraud (don't quite know how you would use this to defraud them?). Saying you need a receipt just means they have grounds to refuse if you look dodgy.
The manager said that i you look the part (oily, no extra eyes or fingers) you will not even be asked for a receipt.
I went in and bought another set to keep in the 90!
Si
  • 5 months later...
