Escape Posted March 13, 2018 Share Posted March 13, 2018 Tough luck Mike :-(. Hope you get a break soon! Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 13, 2018 Author Share Posted March 13, 2018 Hopefully I'm looking at an engine locally tonight. I have run through all the options I can think of but keep coming back to swapping the engine being the quickest relatively cheap solution. Mike Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2018 Share Posted March 13, 2018 16 hours ago, Bowie69 said: Yeah just trying to think of line of least resistance, at least to get you on the road. If just a piston, can you do that with ladder frame on? No. ladder frame completely covers the crankcase lower area with only drain holes for oil to get back to the sump & for oil pump & strainer to poke through. cam bearing change is a full engine out/strip job. my ladder frame & oil pump refitted prior to sump being refitted Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 14, 2018 Author Share Posted March 14, 2018 There is a little bit of silver. The engine I looked at last night comes with the car still attached. So at least I can now get some of the other bits I've been planning to sort for a while now. Mike 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 14, 2018 Share Posted March 14, 2018 Excellent Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 14, 2018 Share Posted March 14, 2018 Glad to hear it's starting to work out Mike. Mo Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted March 14, 2018 Share Posted March 14, 2018 That's some run of bad luck Mike, I hope the new motor is the turning point, good luck Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 19, 2018 Author Share Posted March 19, 2018 Well the good news it the new motor is up and running after an oil leak from the cooler pipes and a stuck boost pin. However my luck hasn't improved much 45 has now blown another core plug so I'm now certain the head gasket has gone. This is not even funny any more I think I may be fixing this then selling 45. I simply don't have time for this and it's wearing thin on my boss. Mike Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 19, 2018 Share Posted March 19, 2018 That's too bad My 300TDi cracked the block after freezing, might have happened to 45 too... Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 19, 2018 Author Share Posted March 19, 2018 I suspected the head gasket had gone before it froze due to excess pressure in the header tank. But didn't have time to change it plus it's not the first time it' gone so I suspect the head is warped. Trouble is both our trucks are daily drivers so I was holding out for the ibex to go on the road. That way both could get some tlc without leaving us vehicleless. Mike Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 20, 2018 Share Posted March 20, 2018 Is the head on your spare engine (the one with the potentially holed piston) a likely candidate for a replacement on 45? Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted March 20, 2018 Share Posted March 20, 2018 Mike, if there is anything on the 200tdi I had off you that will help, its still here, mostly complete, give me a shout. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 20, 2018 Share Posted March 20, 2018 Pop a new core plug in and run with the radiator cap loose...? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 20, 2018 Author Share Posted March 20, 2018 I'm going to swap the head with the one from the holed piston engine assuming it's ok. The core plug thats gone is in the head anyway. Mike Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 20, 2018 Author Share Posted March 20, 2018 Well it wasn't a holed piston. Yes that is a 6mm gap in the head gasket between no4 piston and no8 cam follower. The head gasket has also gone in the middle at the back of no4 piston. So good news is I have a serviceable engine as a spare. I'm going to rob the head for 45 and use the head off the snapped cam engine or re-con 45's head for a spare. Mike 1 Quote Link to comment Share on other sites More sharing options...
western Posted March 20, 2018 Share Posted March 20, 2018 Glad the fault wasn't as drastic as you thought, having spares to hand is good too. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 21, 2018 Share Posted March 21, 2018 That's a better outcome 👍😊 Mo Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 21, 2018 Share Posted March 21, 2018 Sunny side up Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 21, 2018 Share Posted March 21, 2018 Good news! And you still have a spare engine for when the next one expires. 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 21, 2018 Author Share Posted March 21, 2018 And the hits just keep coming! Just dropped something and you guessed it smashed the windscreen on the 110. Mike Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted March 21, 2018 Share Posted March 21, 2018 Was that dropped or "launched" given your current run... Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 22, 2018 Author Share Posted March 22, 2018 I was getting a sofa off the roof with my wife and it slipped out of my hand. I'd like to say thanks to everyone I've had a run of bad luck and needed to vent. Hopefully things are going to improve, if not this thread may go on a while....... Mike Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 22, 2018 Share Posted March 22, 2018 You had a sofa on your roof ? 😳 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 22, 2018 Share Posted March 22, 2018 Just change your forum name to ''Lucky'' 😂 Mo Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 22, 2018 Share Posted March 22, 2018 Quote If it wasn’t for bad luck - I wouldn’t have any luck at all... Quote Link to comment Share on other sites More sharing options...
