Wytze Posted January 13, 2023 Share Posted January 13, 2023 3 minutes ago, Stellaghost said: All in good time, all in good time.......... Regards Stephen Not rushing you... Can't rush a storm. Just keep going.. I try planning to be at seven sisters in September.. Would like to see your's there.. And a few more.. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 14, 2023 Author Share Posted January 14, 2023 Bit of Mog work this morning Started putting caliper brackets and calipers On with an added bit of brake pipe fitting But first I had to clean disc up Regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 14, 2023 Author Share Posted January 14, 2023 Just put the wheel back on, thought I'd best try because it looked like brake pipes might rub Thankfully they don't, but a bit more securing with cable ties won't hurt All nice and tight in there Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 14, 2023 Share Posted January 14, 2023 Little late now, but you can get them made up with angled ends to help clearance like that. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 14, 2023 Author Share Posted January 14, 2023 10 minutes ago, landroversforever said: Little late now, but you can get them made up with angled ends to help clearance like that. Yes I'm aware of that, have 90 degree ones for the master cylinder, the reality is I should have made the pipes up with sacrificial brake pipe and this would have given me the angles, but they are working so not too worried regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 14, 2023 Author Share Posted January 14, 2023 And the other side done regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 14, 2023 Share Posted January 14, 2023 That looks cracking! 2 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted January 14, 2023 Share Posted January 14, 2023 What about banjo adaptors for the pipes that stick out? It should just screw together and would bring the flexi close in to the portal housing for max protection? Looking great, can't be too far from being road ready now. Steve 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 14, 2023 Author Share Posted January 14, 2023 21 minutes ago, steve b said: What about banjo adaptors for the pipes that stick out? Steve Never heard of them will have a look thanks regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 14, 2023 Author Share Posted January 14, 2023 1 hour ago, steve b said: What about banjo adaptors for the pipes that stick out? Steve Struggling to find some of these push comes to shove I can buy new brake pipes from Llama 4x4, they are pleasantly reasonably priced regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted January 14, 2023 Share Posted January 14, 2023 Car builder solutions list various UNF banjo fittings so could be worth a call about metric ones but I bet David will know what you could use as a screw together adaptor. I think @FridgeFreezer had some SS flexibles made with banjo's for the 109. The other option would be to make the banjo. Lots of modern cars use crimped on banjo brake pipes (incl. the D2) so the bolts should be easily available. Steve Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 14, 2023 Share Posted January 14, 2023 Just now, steve b said: I think @FridgeFreezer had some SS flexibles made with banjo's for the 109. I bought TFE hose & fittings from Think Automotive and made my own, it doesn't save you much if anything but it does mean you can make it all up to length on the truck without having to get accurate measurements in advance. Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted January 14, 2023 Share Posted January 14, 2023 That is going to have serious stopping power! 🤪 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 14, 2023 Author Share Posted January 14, 2023 20 minutes ago, TD5toV8110 said: That is going to have serious stopping power! 🤪 I hope so Dave regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted January 14, 2023 Share Posted January 14, 2023 Is it the same on all 4 corners? 🤔 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 14, 2023 Author Share Posted January 14, 2023 6 minutes ago, TD5toV8110 said: Is it the same on all 4 corners? 🤔 No, standard configuration on the rear axle Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 15, 2023 Author Share Posted January 15, 2023 One side of the rear axle done, unfortunately I didn't allow enough wiggle room for the brake pipe so will need to order a longer one tomorrow but the good news is it will fit the other side Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted January 15, 2023 Author Popular Post Share Posted January 15, 2023 Shocker fitted, you don't want to know how much trouble that caused me......should have left the tub off lol Regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 15, 2023 Author Share Posted January 15, 2023 Other side done and brake pipe fitted, have some P clips coming so might drill and tap 1st skin of axle to secure brake pipes better Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 15, 2023 Author Share Posted January 15, 2023 Needs must and all that Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 15, 2023 Author Share Posted January 15, 2023 I know, I know, I know...... Electrickery coming shortly.... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 15, 2023 Share Posted January 15, 2023 Flexy...... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 15, 2023 Author Share Posted January 15, 2023 8 minutes ago, Bowie69 said: Flexy...... I hope so, final flexing to be done soonish, front shocks to fit and pan hard rod to sort first Regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 15, 2023 Share Posted January 15, 2023 So, @Stellaghost... Summer Sisters announced for 24/25 June, gonna make it? 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 15, 2023 Share Posted January 15, 2023 Quote Could you put a small bracket under the bolts to hold the brake line instead of drilling and using P clips? Quote Link to comment Share on other sites More sharing options...
