2 hours ago, Bowie69 said:
Yup, they look sound to me, bolt on and move on to wiring ;)
18 minutes ago, Anderzander said:
Pretend it’s hydraulics ?
13 minutes ago, landroversforever said:
Hydraulics with a little motor/generator for each light? :lol:
This is a Landrover forum.....
Not comedy bloody central..........lol
Regards Stephen
This is pretty much how I learnt electrics.
Positive=flow
Negative=return
Both must be connected for anything to work. The body and engine etc is negative so you don't necessarily need two wires (guage sender's etc).
Mike
  • Like 1
Canvas fitted, in a fashion
Now the in a fashion bit
Due to shortening the body many moons ago a swb canvas is now around 10" too long, I've always just made do, but I think that needs to change, hence looking at constructing a new canvas at some point in the future, however I will be looking to modify this one sooner rather than later
16 minutes ago, CwazyWabbit said:
Nah, canvas next :)
Need to make Sid watertight ;)
@CwazyWabbit  has a point, makes a bit of sense to have some weather protection when wiring the clocks, also seats to be fitted shortly, again a bit of weather protection won't hurt
Regards Stephen
  • Like 2
7 minutes ago, steve b said:
The side view above with the canvas on looks great, this is starting to make standard Ltwt's look wrong.
Have you cycled the suspension now it's built?
Steve
Did that a few posts back when pretty much everything that needed to be on was  however it will probably happen again now I've got mud flaps etc on
Regards Stephen
A bit more pottering
Bottom folded
Tried for size
Couple of bits of 12 mm aluminium for holding bolts to tap into
Box for window channel to sit on
Door surrounds
Folded
Then used vice in stages to compress angle to what I need
roughly fitted over
You get the idea
Will cut and weld later, no rush as window runners not here yet
Regards Stephen
  • Like 3
3 hours ago, Bowie69 said:
Wiring tomorrow then! :D
3 hours ago, Stellaghost said:
That is the plan my friend I would like Sid breathing by the end of the weekend
Regards Stephen
53 minutes ago, Bowie69 said:
Odd looking wiring.
It's not tomorrow yet .......
  • Haha 1
I wasn't sure when you first showed them but the wheels really do suit it. I'm so impressed how 'right' it all looks, I thought it was going to end up as a very well built, hugely capable, very badly proportioned car but it's all spot-on. Watching it come together has the same mix of satisfcation/admiration of seeing a set of skills at work and the execution of an idea as Project Binky.
I am certain you'll find a way to weld a new canvas top.
  • Like 2
  • Thanks 2
