landroversforever Posted May 27 Share Posted May 27 That's not too bad then! The lightweight body is making it look wider than it is. Mine will be around that when it's done, about an inch or so narrower in total. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted May 27 Share Posted May 27 Pointing out the obvious but when you consider that you've bought half a foot of clearance in total and there are advantages to not having huge offset for things like bearings living a bit longer, seems plenty worthwhile to me. Besides, I'm sure you can make some lightweight arch eyebrow extensions out of the glacis plate of a MK10 Chieftain tank. Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 28 Share Posted May 28 With so much low down weight, I doubt you’ll have any lateral stability problems from the width reduction, and I can’t see it reducing available steering lock, but it will get you through tighter gaps/canes. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 29 Author Share Posted May 29 One piece of the puzzle through the post Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 29 Share Posted May 29 Wee, V8 noises soon! Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted May 29 Author Popular Post Share Posted May 29 A wee bit more wheel progress Two more wheel centres removed Rings rolled for clamping ring tacked and welded into position Blended Still to paint obviously, also waiting for delivery of stainless m8 cap heads Regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted May 30 Author Popular Post Share Posted May 30 A box of shiny beadlock niceness Regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted May 31 Author Popular Post Share Posted May 31 Weighed one of the modified rim and tyre combinations, came in at just under 63 kg For some reason I expected more, so I'm happy enough with that regards Stephen 5 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 31 Share Posted May 31 That's not too bad at all! How does it compare to the modified mog rim? Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 31 Share Posted May 31 That seems alright, my back still has PTSD from the 40" Boggers on Mouse No clue what those actually weighed though, probably similar. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 31 Author Share Posted May 31 10 hours ago, landroversforever said: That's not too bad at all! How does it compare to the modified mog rim? Modified mog rim and swamper tyre weigh in at 57.6kg, so quite a bit of weight in the mogrover 20" rim When the 40" wheels are on Sid I will only gain an additional 28kg Happy with that.... Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted May 31 Author Popular Post Share Posted May 31 1st beadlock ring fitted and tyre inflated to 10psi, see if it is still up in the morning....lol Bit of a pain torqueing up all the cap heads, went round 3 times until I was satisfied I am however very pleased with the result Regards Stephen 5 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 31 Share Posted May 31 I could park my 80” under there now. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 31 Share Posted May 31 That looks fantastic. And same for LGT, would fit under easily. Not under the tyre, obvs. 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 31 Author Share Posted May 31 Just now, Bowie69 said: Not under the tyre, obvs. Welllllllll.......if you change your mind............ Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted May 31 Share Posted May 31 That's looking very proper. Quite military. 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 31 Share Posted May 31 That looks amazingly good. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 31 Share Posted May 31 Nothing else matters but this: they have Reuben's approval. 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 31 Author Share Posted May 31 2 minutes ago, Bowie69 said: Nothing else matters but this: they have Reuben's approval. Agreed Regards Stephen Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 31 Share Posted May 31 They really do look great Stephen! They remind me of these wheels from Method…. Only I think your holes/location of holes look waaaaaay better balanced. 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 31 Author Share Posted May 31 8 minutes ago, landroversforever said: They really do look great Stephen! They remind me of these wheels from Method…. Only I think your holes/location of holes look waaaaaay better balanced. Damn, now you tell me I could have bought them......... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 31 Share Posted May 31 Where's the fun and entertainment in buying them? 1 Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted May 31 Share Posted May 31 If the point of the last few weeks wasn't that they're DIY, I wouldn't have thought they were. In my terms, that's the highest compliment I could receive so hopefully it's what you aimed for. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 31 Author Share Posted May 31 1 minute ago, ThreePointFive said: If the point of the last few weeks wasn't that they're DIY, I wouldn't have thought they were. In my terms, that's the highest compliment I could receive so hopefully it's what you aimed for. Thank you, very generous Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 1 Author Share Posted June 1 Hoping to have a wheely good day today........ Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
