The sticky trep which is the spare in the group of tyres I've just bought has a noticeably soft tread, reminds me of Michelin X1 tyres I used to use on my trials bike years ago. I did'nt realise how much of a difference this would make. The realisation came when I started to load tyres, I did this by rolling them up to the ball on the tow hitch and then rolled the tyre up and in, the sticky did not slip yet the other tyres did and i had to alter my position on the tyre and apply some additional pressure to wheel it into the car. I will eventually get 3 more stickys
Regards Stephen
  • Like 1
Good news for me regarding tyres, I can deform them by leaning on them so should have plenty of flexibility when getting used in anger. Should mention I had let air out of the tyre, could not do the above with rhe swampers
Regards Stephen
  • Like 3
Oh and curiosity got the better of me, 20 mins later
Centre has deformed due to assistance of a BFH not worried about it as I reckon I'm going to have to fab up some new centre's anyway
Regards Stephen
  • Like 3
Had a bit play with tyre pressures to see how much more flexible these tyres are over the swampers
20psi
10psi
Zero psi
so way more flexible than the swampers
regards Stephen
  • Like 1
I have two types of mach5 single beadlocks above is my spare wheel, yellow is outer rim the white ring clamps the tyre to the yellow rim. However these need tubes really which kind of makes them double beadlocks ish.
The others have the white ring as part of the wheel with a removable outer rim. These you need to stretch the inner tyre bead over the ring and onto the wheel bead. The outer bead sits against the ring the the rim bolts on and traps the tyre bead. These can be used tubeless as they are easier to seal.
The other thing to remember is the mach5 type of beadlocks is technically road legal as it's just a split rim. The type that clamps the bead between two flat rings is not.
Mike
  • Like 1
John Sales made these for me:
They are based on modular rims, 2 rings are welded in the rim, then cut the rim in half, and you have a split rim. The inserts are PVC tube, sealing is by a large squishy O-ring, which is meant for a manhole cover.
You could make the ID of one of the rings smaller and incorporate a mounting bolt hole pattern to fit them to the hub.
I had them down to 2PSI in the swamps, no problems.
O-ring between the wheel halves:
  • Like 4
Brilliant. But kind of disappointed you haven't turned them from solid out of a bit of ship's propshaft you had lying around. In about an hour.😉
  • Like 1
  • Haha 1
27 minutes ago, fmmv said:
 disappointed you haven't turned them from solid out of a bit of ship's propshaft you had lying around. .😉
Could have, but I've only got a couple of ships props left, didn't want to waste all that material I would of had to turn of
Could always cast a couple more props............
Regards Stephen
  • Like 2
  • Haha 2
