dangerous doug Posted May 2 Share Posted May 2 I think I still have the d2 sliding caliper that I was looking at using which I can pop in the post if you like. It takes a lot of space inboard though which is why I opted to use the willwood set with wolf wheels. i will say that you’re shooting for one of the narrowest pcd/disk conversions I’ve ever seen on a 404. I thought i did well with the face of the rim sitting about 20mm in from the hub nut. Like I say if it helps I do still have the mog wheels that you can cut the centres out of an modify the “spokes” and pcd like you did on the last set 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 2 Share Posted May 2 I'm just astonished Stephen hasn't just narrowed the axle casing. I mean... You shortened the diffs, the casing should a piece of cake? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 2 Author Share Posted May 2 1 hour ago, dangerous doug said: I think I still have the d2 sliding caliper that I was looking at using which I can pop in the post if you like. It takes a lot of space inboard No need to post caliper, a measurement from pad braking surface to outside of called bracket would be good though Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 2 Author Share Posted May 2 1 hour ago, Bowie69 said: I'm just astonished Stephen hasn't just narrowed the axle casing. I mean... You shortened the diffs, the casing should a piece of cake? One thing stopping me narrowing the axles, my lathe does not have the length to make new halfshafts also if I shorten axle tubes I will need to undo my road wheels and re-make/ position spring mounts etc. Modifying the new wheels and re-jigging the brakes is relatively straight forward in comparison I like the look with the 20" mogrover rims, I'm really only looking at minor alterations to fit my off road 40" tyres Regards Stephen Edit...do you also like popcorn..............lol 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Ed Poore Posted May 2 Popular Post Share Posted May 2 18 minutes ago, Stellaghost said: I'm really only looking at minor alterations To most folk minor alterations are swapping tyres for some chunky ones. Not building new wheels from scratch. 5 Quote Link to comment Share on other sites More sharing options...
Stinkfloyd Posted May 2 Share Posted May 2 (edited) 1 hour ago, Ed Poore said: To most folk minor alterations are swapping tyres for some chunky ones. Not building new wheels from scratch. Normal* Incase you've not noticed Stella's brain operates a bit differently to a normal person 😂 Edited May 2 by Stinkfloyd 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 2 Author Share Posted May 2 1 hour ago, Ed Poore said: To most folk minor alterations are swapping tyres for some chunky ones. Not building new wheels from scratch. 11 minutes ago, Stinkfloyd said: Normal* Incase you've not noticed Stella's brain operates a bit differently to a normal person 😂 What can I say.....guess I'm mentally impaired....... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted May 2 Author Popular Post Share Posted May 2 13 minutes ago, Stinkfloyd said: Normal* Incase you've not noticed Stella's brain operates a bit differently to a normal person 😂 Your quite brave when I'm NOT at work..... Regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 2 Share Posted May 2 6 hours ago, Stellaghost said: What can I say.....guess I'm mentally impaired prepared....... Regards Stephen Mike 1 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted May 3 Share Posted May 3 Your are exceptionally gifted, if that's an impairment, there should be more of it about. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted Sunday at 10:56 PM Author Popular Post Share Posted Sunday at 10:56 PM A quick update ( only because its been about a week or so and I usually get lack of progress grump mail if I take too long.......lol ) Been making progress 440 holes drilled, 180 tapped to m8 and 10 rings rolled also plenty of have to do DIY..... On holiday this week, will start building wheels once I get back Regards Stephen 9 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted Monday at 06:36 PM Author Share Posted Monday at 06:36 PM Teaser shots before my hols Now with original insert in position..ish Regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Wytze Posted Monday at 07:36 PM Share Posted Monday at 07:36 PM 1 hour ago, Stellaghost said: Teaser shots before my hols Now with original insert in position..ish Regards Stephen Very nice, as expected😁 1 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted Monday at 08:28 PM Share Posted Monday at 08:28 PM You could sell them to military vehicle contractors... Cheers Dave 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted Tuesday at 07:03 AM Share Posted Tuesday at 07:03 AM Not quite what I had in mind when I said concaved but just as good and looks better. Mike 1 Quote Link to comment Share on other sites More sharing options...
Daan Posted Tuesday at 10:51 AM Share Posted Tuesday at 10:51 AM That looks terrible! Some good skills with thick plate, we need to see the tooling you did for that. Enjoy your hols. Daan 2 Quote Link to comment Share on other sites More sharing options...
