L19MUD Posted August 24, 2022 Share Posted August 24, 2022 12 minutes ago, Stellaghost said: Bit more mock up, was seeing if wings will interfere with top suspension mounts, thankfully plenty of room space under the wings well filled now.... regards Stephenย ย ย ย Bit disappointed the wings are not getting remade in Ali ......๐ Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 24, 2022 Author Share Posted August 24, 2022 Just now, L19MUD said: Bit disappointed the wings are not getting remade in Ali ......๐ I thought you wanted to see this finished.............lol If you remember back in my vent panel bulkhead build thread I did mention I might make some new wings due to having to.make a folder to form vent panel Quite happy to let you come up and make some for me .....lol Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 24, 2022 Share Posted August 24, 2022 1 hour ago, L19MUD said: Bit disappointed the wings are not getting remade in Ali ......๐ They are ali anyway Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 24, 2022 Share Posted August 24, 2022 12 minutes ago, Bowie69 said: They are ali anyway For some odd reason I though some of the bodywork of a lightweight was steel including the wings Quote Link to comment Share on other sites More sharing options...
steve b Posted August 24, 2022 Share Posted August 24, 2022 It's the lower section that is the footwell of the BH that is steel as std. Not on this though , obviously Steve Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 24, 2022 Share Posted August 24, 2022 Donโt forget the misalignment spacers! Also for your clearance checks, donโt forget that if you drop the opposite side the wheel will come up further.ย 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 24, 2022 Author Share Posted August 24, 2022 2 hours ago, landroversforever said: Donโt forget the misalignment spacers! Also for your clearance checks, donโt forget that if you drop the opposite side the wheel will come up further.ย Noted, that was my point with the trial shock mount, not enough gap for misalignment, the joys eh Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 24, 2022 Author Share Posted August 24, 2022 3 hours ago, L19MUD said: For some odd reason I though some of the bodywork of a lightweight was steel including the wings No, vent panel, bulkhead and front panel are the steel bodywork items, gonna have to make the front panel aluminium now for the hat trick Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted August 25, 2022 Share Posted August 25, 2022 also an option๐ ย 2 Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted August 25, 2022 Share Posted August 25, 2022 @Stellaghost have you degassed the shock? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 25, 2022 Author Share Posted August 25, 2022 11 minutes ago, RedLineMike said: @Stellaghost have you degassed the shock? No I hav'nt, was I supposed to regards Stephen Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted August 25, 2022 Share Posted August 25, 2022 9 minutes ago, Stellaghost said: No I hav'nt, was I supposed to regards Stephen it would make things easier for checking your clearances / cycling the suspension, you wouldnt need to put them in the press to compress them, ย Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 25, 2022 Author Share Posted August 25, 2022 21 minutes ago, RedLineMike said: it would make things easier for checking your clearances / cycling the suspension, you wouldnt need to put them in the press to compress them, ย ok I wondered about that, but then they would need recharging with nitrogen I guess and that I don't have regards stephen Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 25, 2022 Share Posted August 25, 2022 25 minutes ago, Stellaghost said: ok I wondered about that, but then they would need recharging with nitrogen I guess and that I don't have regards stephen Shouldn't cost much to have them regassed. Only thing is that I'm not sure they're supposed to be left without pressureย forย a long period. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 25, 2022 Author Share Posted August 25, 2022 47 minutes ago, landroversforever said: Shouldn't cost much to have them regassed. Only thing is that I'm not sure they're supposed to be left without pressureย forย a long period. Pretty sure I can manage without degassing them only needed closed length to make brackets regards Stephen Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 25, 2022 Share Posted August 25, 2022 35 minutes ago, Stellaghost said: Pretty sure I can manage without degassing them only needed closed length to make brackets regards Stephen My mock up stuff Iโve done with a set of threaded rod and rod ends. Made one up to the open and one to the closed length.ย 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 25, 2022 Author Share Posted August 25, 2022 13 minutes ago, landroversforever said: My mock up stuff Iโve done with a set of threaded rod and rod ends. Made one up to the open and one to the closed length.ย That's a very good idea Ross, I may have to steal that idea from you...... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 25, 2022 Share Posted August 25, 2022 Steal away! I just used some cheap m12 rod ends and some โacquiredโ threaded rod.ย Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 25, 2022 Author Share Posted August 25, 2022 6 minutes ago, landroversforever said: Steal away! I just used some cheap m12 rod ends and some โacquiredโ threaded rod.ย I do believe I have everything I need in the garage, unfortunately work is in the way for a few days... Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 28, 2022 Author Share Posted August 28, 2022 All bottom shock brackets and misalignment spacers made, binned the lathe route, made these in 1/4 of the time it took to make trial mount in lathe regards Stephenย 3 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 28, 2022 Share Posted August 28, 2022 Steel thickness? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 28, 2022 Author Share Posted August 28, 2022 9 minutes ago, Bowie69 said: Steel thickness? 6mm, there could be some additional bracing in the form of a curved shroud around the pin holes and back to the bottom for welding if additional strength needed, similar to what I made for trailing arm brackets for rear axle regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted August 29, 2022 Author Popular Post Share Posted August 29, 2022 What a carry on, all day and not much to show for it, but the next one should be easier.ย Trying to fit front shocks, tried always to keep shock body under wings but to no avail, try as I might steering components will not stay out of my way, so shock top will be through wing but under bonnet so will not be seen So started with a cad templateย To make a metal templateย Then a fake shock body with spherical joints at closed shock centre'sย some 6mm box section cutting and folding upper shock tower false one for size Some backing plate for additional strengthย real shock tried for size, got it compressed with the assistance of some small pull lifts this is about where I want it to be regards Stephenย 10 Quote Link to comment Share on other sites More sharing options...
muddy Posted August 30, 2022 Share Posted August 30, 2022 Looks good, check the tyre doesn't rub the resovoir area when the other side is full droop and full left lock. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 30, 2022 Author Share Posted August 30, 2022 26 minutes ago, muddy said: Looks good, check the tyre doesn't rub the resovoir area when the other side is full droop and full left lock. Thanks Still got all droop etc to check, that's why nothing is fully welded yet just in case stuff has to be reconfigured, nowt worse than cutting off after fully welding. The reservoir is just cable tied there for out of the way convenience although it will probably stay there but held with a purpose made clamp regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
