Is there an easy way to tell if I have diluted a bottle of coolant?
reb78
I usually scribble on the tub when I dilute antifreeze so that I know I have done it. But I have two open 5l bottles of blue antifreeze and I am sure one of them is neat and one is 50% - there is a small chance they may both be neat! Is there an easy way to tell if I have diluted one?
Hydrometer is the word I couldn't think of!
According to the link in my previous post, the specific gravity of 100% concentration is 1.13 at 27'C or if it is 50% diluted then the SG will be 1.077 at the same temperature.
Hope this helps you.
Hydrometer is of course the correct answer, as above.
Slightly more whimsically, dilute samples of both a bit more, and stick them in the freezer, see which freezes first :)
But if it were me, I'd just mix both bottles with 10L of water, and know I then had 20L of mix at somewhere between 33% and 50% which should be close enough for anyone...
  • Like 1
  • 2 weeks later...
99% of antifreeze for sale now is pre-diluted (at least from garages and supermarkets, professional may be still concentrate) -  easier to use for stupid people, but we are buying water at some inflated rate.
