Retroanaconda Posted May 24, 2020 Author Share Posted May 24, 2020 Should be doable with a sensible roof design. Speak to your local planning office and run your thoughts by them. Had to go and buy a new stepladder this morning (all hail Screwfix!) as my old one gave up the ghost so not much progress today, but I’ve painted the last wall and have been doing more in the roof. I’ve decided to put some extra supports in the loft space after all, there wasn’t much flex in it but now it’s rock solid. There will be another one two rafters further back, but there’s so much space up there that they aren’t going to get in the way. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 24, 2020 Share Posted May 24, 2020 How will you hold in the lift insulation? Board it over? and if boards will you use a lighter one? Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 24, 2020 Share Posted May 24, 2020 Very, very Nice !! Once we find time - will be a few months - it is workshop / hay storage construction time here.... TBH - the money sounds right for UK and what you have. Good investment. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 24, 2020 Share Posted May 24, 2020 24 minutes ago, Arjan said: Once we find time - will be a few months - it is workshop / hay storage construction time here.... Make sure to post a build thread Arian Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 24, 2020 Share Posted May 24, 2020 We will...... It is a 14 x 8 x 4 mtrs. build not to mentions the other 2 .... Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 24, 2020 Author Share Posted May 24, 2020 2 hours ago, Anderzander said: How will you hold in the lift insulation? Board it over? and if boards will you use a lighter one? It’ll be fitted between the rafters and then boarded in the same 9mm OSB as the walls. Really not looking forward to that job! The big shelf is done - gratuitous panoramic shot of terrible mess 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 24, 2020 Share Posted May 24, 2020 Blimey - I thought you’d be using 3mm hardboard or something ! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 24, 2020 Share Posted May 24, 2020 I've always found hardboard ends up warping badly, even with lots of nails in it. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 24, 2020 Share Posted May 24, 2020 41 minutes ago, Bowie69 said: I've always found hardboard ends up warping badly, even with lots of nails in it. Likewise, always sags in my experience. Quote Link to comment Share on other sites More sharing options...
ballcock Posted May 24, 2020 Share Posted May 24, 2020 Are they double yellow lines down the side to stop people parking? Looking very nice although my garage is a bit bigger I still can't find the floor. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 24, 2020 Share Posted May 24, 2020 1 hour ago, Bowie69 said: I've always found hardboard ends up warping badly, even with lots of nails in it. Even on a short span like that ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 24, 2020 Share Posted May 24, 2020 Yeah, with any potentially damp building (i.e. not heated) it eventually gets to it. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 24, 2020 Author Share Posted May 24, 2020 The OSB isn’t too bad weight-wise, and save for the bit in the middle I will be working off the loft platforms which will minimise the amount of lifting involved. Adds more strength to the roof too. Quote Link to comment Share on other sites More sharing options...
HoSS Posted May 25, 2020 Share Posted May 25, 2020 Yeah OSB is nice stuff, in the past i'd always used Chipboard for floors etc, but OSB is lighter yet more rigid across spans and much more waterproof. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 30, 2020 Author Share Posted May 30, 2020 Laid the first part of the concrete area out front this morning. This piece will serve as a ramp from the building down to the linear drain, with the larger slab beyond. There is a 1:50 fall away from the building and a 1:100 fall to the left for the drain to follow, plus a small (c. 10-15mm) step to prevent rainwater being driven in by wind. I am hopeful that this will not prove a significant barrier to rolling things in or out. Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 30, 2020 Share Posted May 30, 2020 Looks promising ! Hope you put netting in... (sorry) Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 4, 2020 Share Posted June 4, 2020 Any updates James ? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 4, 2020 Author Share Posted June 4, 2020 Not yet. Hopefully get some more bits done this coming weekend time allowing. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 7, 2020 Author Share Posted June 7, 2020 I flippin’ knew it! Needs raised by half an inch to let the welder roll underneath Started moving some more bits in this weekend and got my compressor hooked up in a temporary fashion to let me use it. Need to get the belt done on the 90 and then I can do some more treasure collecting. But first I need to get the roof insulated and boarded so that I can use the loft to house some of the junk I’ve brought up the road. 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 7, 2020 Share Posted June 7, 2020 Looks like if you tip it or take the plastic off that will go under ? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 7, 2020 Share Posted June 7, 2020 Why not notch the bench to suit? The other thing being the gas companies like to vary the tops of them too. So whatever you do it might need changing with the next cylinder sadly. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 7, 2020 Author Share Posted June 7, 2020 It will go under by tipping it, but I’d like it to roll under easily. Might look at replacing the crossmembers with sections of 75x50 rather than 100x50 as that will gain me an inch. The last cylinder lasted 9 years and two workshops so I’m not too worried about that Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 7, 2020 Share Posted June 7, 2020 Is it on the back of your welder ? Or free standing ? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 7, 2020 Share Posted June 7, 2020 12 minutes ago, Anderzander said: Is it on the back of your welder ? Or free standing ? I’m guessing it’s like mine and sat on the back of the welder. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 7, 2020 Share Posted June 7, 2020 7 minutes ago, landroversforever said: I’m guessing it’s like mine and sat on the back of the welder. And I’m thinking - if it is, just take the plastic handle off - as it won’t need picking up for 9 years. Quote Link to comment Share on other sites More sharing options...
