Mutley Posted April 15, 2019 Share Posted April 15, 2019 So going to finally attempt the timing belt on my '95 Defender 300Tdi...... And it seems to make life easier i need a Crank Pulley Puller???.......The ones i have been looking at are the "Harmonic balancer puller"...... Can anyone recommend a good quality make for these or is are there other/better options? Cheers Andy Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 15, 2019 Share Posted April 15, 2019 The timing kits you can get for about £40 include a crank pulley puller. Quote Link to comment Share on other sites More sharing options...
Mutley Posted April 15, 2019 Author Share Posted April 15, 2019 The timing kit i was looking at is STC4096K but has no mention of a puller included? I have a kit with pins and such to hold/lock things in place so timing is safe, hence the need for a puller just don't want cheap nasty Chinese cheese stuff! Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 15, 2019 Share Posted April 15, 2019 You may have to consider too how to undo and especially do up the crank pulley bolt, and you may need a puller for the toothed belt pulley. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 15, 2019 Share Posted April 15, 2019 13 minutes ago, Mutley said: The timing kit i was looking at is STC4096K but has no mention of a puller included? I have a kit with pins and such to hold/lock things in place so timing is safe, hence the need for a puller just don't want cheap nasty Chinese cheese stuff! Sorry, I meant the tool kit. I have one with the timing pins and it has a round tool which doubles as a crank pulley puller and the holding tool that lets you remove the FIP without disturbing the timing belt. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted April 15, 2019 Share Posted April 15, 2019 Piece of flat bar, big bolt and some M8 (I think bolts). Make your own. I would have but I've got a mate who's already made them all! Quote Link to comment Share on other sites More sharing options...
Mutley Posted April 15, 2019 Author Share Posted April 15, 2019 Cackshifter i have the special locking tool thing for the crank bolt, very similar to Land Rovers one, a few years back a guy on Ebay made and sold them for a fraction of LR price! I got x1 it's heavy, solid and well made quality bit of kit i put it down to forward planning, that and don't like the idea of bouncing the breaker bar against the chasis whilst spinning the engine over. @Retroanaconda will check my timing tool kit and see if it has similar as to what you describe Cheers Andy Quote Link to comment Share on other sites More sharing options...
Mutley Posted April 15, 2019 Author Share Posted April 15, 2019 Retroanaconda..... this is the kit i have so looks like i am sorted i think 1 Quote Link to comment Share on other sites More sharing options...
Mutley Posted April 15, 2019 Author Share Posted April 15, 2019 @cackshifter.... I got this for the job off ebay Quote Link to comment Share on other sites More sharing options...
western Posted April 15, 2019 Share Posted April 15, 2019 35 minutes ago, Mutley said: Retroanaconda..... this is the kit i have so looks like i am sorted i think Yes that's the correct kit, I have one as well. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 15, 2019 Share Posted April 15, 2019 Your welcome to borrow my puller and big spanner for the bolt. I'm just of the M1 junction 20. If your wanting them posted then you'll probably have to remortgage your house. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 15, 2019 Share Posted April 15, 2019 That looks the dog's Mutley. Quote Link to comment Share on other sites More sharing options...
Mutley Posted April 16, 2019 Author Share Posted April 16, 2019 Thanks for that vulcan bomber, i am off junction 24 M1 so would be quicker cheaper to drive to yours? Will see how i get on with the tools i have and if it goes south might take you up on the offer. cackshifter i have a few specialised tools, not many, that i have obtained over the past few years. Either for anticipation of doing when money allows or for the odd job that's hopefully a one off??? Trouble is i don't always remember what tools and bits i have, like the timing pin and puller kit!?! One of my favourites is the crimping tool for lugs on battery cables, it does the hex crimp at various sizes and works very well! Make all my own now when needed using glued heat shrink, they look very business like and are stong too. Even my local garage man raised an eyebrow and said he might have to borrow it sometime, when i mentioned it to him. Quote Link to comment Share on other sites More sharing options...
Sabre Posted April 22, 2019 Share Posted April 22, 2019 On 4/15/2019 at 10:28 PM, Mutley said: @cackshifter.... I got this for the job off ebay You will still need a sturdy pipe (about 1 meter long) to slide over the handle when you turn the bolt 90 degrees after the initial 80Nm. On the same subject, do you use a half-inch drive when tightening the final 90 degrees ? Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 22, 2019 Share Posted April 22, 2019 Air is the easiest way to get the bolt undone... Need to do that, again, later this week.... Bon Courage ! Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted April 22, 2019 Share Posted April 22, 2019 10 hours ago, Arjan said: Air is the easiest way to get the bolt undone... This is easier. No air line , and I should know done 5 sodding crank bolts in the last few months! Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 22, 2019 Share Posted April 22, 2019 yes - easier. But also VERY expensive out here... The airgun was about 1/3 of this one.. Quote Link to comment Share on other sites More sharing options...
Mutley Posted April 23, 2019 Author Share Posted April 23, 2019 @Ed poore i have the combi drill with x2 batteries in this so will look at getting just the body of the impact wrench in the near future. Well impressed with the drill so an addition only seems practical!?! Sorry just working on how to sell it to the wife Arjan courage and then some, this is going to be like major surgery for me lol Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted April 23, 2019 Share Posted April 23, 2019 @Mutley that was the first Milwaukee tool I got after getting to experience it in the Lakes with a garage. It wasn't cheap, think at the time (almost 4 years ago now) it was £440 for the kit with 2 5Ah batteries but it's still going strong. The only downside with it is it's a monster of a motor on it which means it doesn't fit into most places! I'm seriously considering a smaller one as I don't always need the 1000ftlbs that one delivers. You do need good fitting sockets though, if you get a perfect fit the motor often has enough torque to not even bother with the hammer action. The little 1/4" driver is also very handy for most stuff, even that "light" one is still capable of 150ftlbs. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 23, 2019 Share Posted April 23, 2019 @Ed Poore, I have the smaller 1/2" Milwaukee impact, and rate it very, very highly. I think it is 170lb/ft (at least the model was when I bought it) which is plenty for most everyday stuff. As you say, the bigger ones can just be too big, and 1000lb/ft is monster! I'd love an M12 3/8 ratchet, but can't quite get the cash together whenever I look Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 23, 2019 Share Posted April 23, 2019 Milwaukee every time for me got several cordless tools all exceeding performance of previous gear always used to be makita but not now Quote Link to comment Share on other sites More sharing options...
