Hybrid_From_Hell 401 Posted November 20, 2020 Share Posted November 20, 2020 Can anyone help please ? R380 Level plug - the nasty one with a T55 Torx fitting ? https://www.ebay.co.uk/i/143522727674?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=143522727674&targetid=1002021776353&device=c&mktype=pla&googleloc=1006878&poi=&campaignid=10195651178&mkgroupid=107296207892&rlsatarget=pla-1002021776353&abcId=1145987&merchantid=7100224&gclid=CjwKCAiA7939BRBMEiwA-hX5J7y0zPZT-p5N9HiciZeUGvEUVGDGprZgLkRDx5AhVW1roHxjdseA9hoCkogQAvD_BwE Anyone know what the thread is on this please ?? Nige Quote Link to post Share on other sites
vulcan bomber 87 Posted November 20, 2020 Share Posted November 20, 2020 Pretty sure it's the same as the LT77 and you can swap the plugs. Quote Link to post Share on other sites
miketomcat 703 Posted November 21, 2020 Share Posted November 21, 2020 If it's the same as the lt77 I'm fairly sure it's ½" BSP but I haven't got my Zeus book/ Vernier here to check. Mike Quote Link to post Share on other sites
mmgemini 79 Posted November 21, 2020 Share Posted November 21, 2020 17 hours ago, vulcan bomber said: Pretty sure it's the same as the LT77 and you can swap the plugs. Yes you can swap the plugs as I have Quote Link to post Share on other sites
Hybrid_From_Hell 401 Posted November 21, 2020 Author Share Posted November 21, 2020 Iys the actual thread size i am after Not sure if its Bsp Bspt of Cpt.... All.so bloody close 🙄 Quote Link to post Share on other sites
vulcan bomber 87 Posted November 22, 2020 Share Posted November 22, 2020 8 hours ago, Hybrid_From_Hell said: Iys the actual thread size i am after Not sure if its Bsp Bspt of Cpt.... All.so bloody close 🙄 Have you looked at NPT threads? Very similar to BSPT but American.. Quote Link to post Share on other sites
Hybrid_From_Hell 401 Posted November 22, 2020 Author Share Posted November 22, 2020 Don't think its npt Quote Link to post Share on other sites
simonr 297 Posted November 22, 2020 Share Posted November 22, 2020 I've used this a few times to identify 'mystery' threads: https://www.checkfluid.com/pages.php?pID=20&CDpath=3_20 Quote Link to post Share on other sites
Stellaghost 517 Posted November 22, 2020 Share Posted November 22, 2020 Definitely 1/2" bspt just removed one and checked it against a 1/2" bspt nipple same thread nipple also went into gearbox perfectly regards Stephen 1 Quote Link to post Share on other sites
Hybrid_From_Hell 401 Posted November 22, 2020 Author Share Posted November 22, 2020 Stephen You sir are a bloody star. I am going to have some id these horrible units cnc made with a monster neodymium magnet with a flange head ( ie socket or spanner to do / undo) as my others having spent an age getting on out for my disabled mate . Lm me your address and when made you can have a freebie 😊 Nige 1 1 Quote Link to post Share on other sites
steve b 345 Posted November 22, 2020 Share Posted November 22, 2020 Why not just use a 1/2" hydraulic male hex head blank plug ? already has a recess inside to stick the magnet too Steve Quote Link to post Share on other sites
Troll Hunter 119 Posted November 23, 2020 Share Posted November 23, 2020 HfH, why are you replacing the filler plug? This should be just above the fluid level, so will have very little effect. Why not replace the drain plug which will always be fully submerged and will be quite effective in gathering any ferrous materials in the oil. Mike 2 Quote Link to post Share on other sites
oneandtwo 109 Posted November 24, 2020 Share Posted November 24, 2020 17 hours ago, Troll Hunter said: HfH, why are you replacing the filler plug? This should be just above the fluid level, so will have very little effect. Why not replace the drain plug which will always be fully submerged and will be quite effective in gathering any ferrous materials in the oil. Mike R380s all have a magnetic drain plug anyway. When I have had rebuilt R380s from Ashcroft they send them out with a square taper plug in the filler instead of the torx. Quote Link to post Share on other sites
monkie 324 Posted November 24, 2020 Share Posted November 24, 2020 On 11/23/2020 at 6:41 AM, Troll Hunter said: HfH, why are you replacing the filler plug? This should be just above the fluid level, so will have very little effect. Why not replace the drain plug which will always be fully submerged and will be quite effective in gathering any ferrous materials in the oil. Mike A drain plug is no good to anyone if you can't get the filler plug undone. Plus if going to the trouble of making a new one, why not put a strong magnet in there? Oil is flung everywhere inside the box when running. Sounds like a great idea, I will be buying one when they are available. Quote Link to post Share on other sites
