iron_city Posted October 30, 2023 Share Posted October 30, 2023 Hello, I just became an owner of a 1988 Defender 90. When I run the VIN through the LRWorkshop decoder it says the the engine is a 2.5 TD. However when I'm looking at photos of LR engines, it looks a lot more like the 200 TDI. In addition, on top of the head, there is a code HRC2666 and when I google that it seems to be possibly a 300 TDI. However the turbocharger is a Garrett and according to Wikipedia that turbocharger in a 300 TDI is an AlliedSignal T25. So needless to say I'm thoroughly confused as to which engine is in this truck. Any helpwith identifying the engine would be very much appreciated. Thank you! Quote Link to comment Share on other sites More sharing options...
western Posted October 30, 2023 Share Posted October 30, 2023 21L is a Discovery 300Tdi engine, so still a Turbo diesel but with direct injection Quote Link to comment Share on other sites More sharing options...
monkie Posted October 30, 2023 Share Posted October 30, 2023 30 minutes ago, western said: 21L is a Discovery 200Tdi engine, so still a Turbo diesel but with direct injection I thought 21L was a 300Tdi engine? One of the easiest ways to tell a 300Tdi engine from a 200Tdi is the belt at the front of the engine. A 300Tdi has a single serpentine belt driving the PAS pump, alternator and water pump/fan. Whereas a 200Tdi has two separate belts, 1 drives the alternator and the coolant pump/fan, the other drives the PAS pump. 1 Quote Link to comment Share on other sites More sharing options...
Escape Posted October 30, 2023 Share Posted October 30, 2023 That definitely looks like a 300tdi, with the serpentine belt. A mix and match is quite common on (old) Land Rovers, so a different turbo is not a big surprise. You can be happy @iron_city, some previous owner upgraded your 90 from a TD to a 300Tdi. 😎 1 Quote Link to comment Share on other sites More sharing options...
Landy7 Posted October 30, 2023 Share Posted October 30, 2023 (edited) 21L is a Discovery 300TDI engine with EGR. 300TDI's also had Garret turbo's. ERR4802G - Garrett 300TDI Turbocharger (johncraddockltd.co.uk) The 200TDI & 300TDI turbo's are interchangeable and to my knowledge same spec. Edited October 30, 2023 by Landy7 1 Quote Link to comment Share on other sites More sharing options...
simonb Posted October 30, 2023 Share Posted October 30, 2023 300Tdi, the dipstick location - and its yellow, and the cast elbow for the top hose/thermostat housing. Ignore the HRCxxxx numbers, they are casting refernces and won't be found in the parts catalogues. 1 Quote Link to comment Share on other sites More sharing options...
iron_city Posted October 30, 2023 Author Share Posted October 30, 2023 thank you very much for the responses, so nice to know what engine is in this now! The import papers show it came into the US from Italy. Unfortunately there is no paperwork regarding the engine swap. Thank you again for the info! Quote Link to comment Share on other sites More sharing options...
Peaklander Posted October 30, 2023 Share Posted October 30, 2023 My 1996 300TDi none EGR is a 21L from a Discovery, supplied by Turner Engineering. It used to be 16L which must have failed and was swapped in 2003 (before me). Quote Link to comment Share on other sites More sharing options...
iron_city Posted October 30, 2023 Author Share Posted October 30, 2023 Is there a number on the engine that shows it is a 21L? Quote Link to comment Share on other sites More sharing options...
western Posted October 30, 2023 Share Posted October 30, 2023 12 hours ago, monkie said: I thought 21L was a 300Tdi engine? One of the easiest ways to tell a 300Tdi engine from a 200Tdi is the belt at the front of the engine. A 300Tdi has a single serpentine belt driving the PAS pump, alternator and water pump/fan. Whereas a 200Tdi has two separate belts, 1 drives the alternator and the coolant pump/fan, the other drives the PAS pump. Your right, corrected my post above 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted October 30, 2023 Share Posted October 30, 2023 1 hour ago, iron_city said: Is there a number on the engine that shows it is a 21L? Yes , stamped on the block adjacent to the injector pump side just behind the timing belt housing Steve 1 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted October 30, 2023 Share Posted October 30, 2023 1 hour ago, iron_city said: Is there a number on the engine that shows it is a 21L? The engine code is at the start of the engine number stamped on the block - it's a little hard to see on yours. I imagine the engine was fitted in the US after import as it would breach customs rules if shipped like that from italy. 1 Quote Link to comment Share on other sites More sharing options...
iron_city Posted October 30, 2023 Author Share Posted October 30, 2023 thank you @Eightpot. Is this the picture of the engine code? Quote Link to comment Share on other sites More sharing options...
Peaklander Posted October 30, 2023 Share Posted October 30, 2023 Yes. The 2 is there if you look for long enough and fold your eyelids and refocus several times 😄 1 Quote Link to comment Share on other sites More sharing options...
western Posted October 31, 2023 Share Posted October 31, 2023 9 hours ago, iron_city said: thank you @Eightpot. Is this the picture of the engine code? 21L10743A 2 Quote Link to comment Share on other sites More sharing options...
Junglie Posted October 31, 2023 Share Posted October 31, 2023 I'd have said 21L40743A but I may be wrong... 2 Quote Link to comment Share on other sites More sharing options...
western Posted October 31, 2023 Share Posted October 31, 2023 10 minutes ago, Junglie said: I'd have said 21L40743A but I may be wrong... Not wrong, I missed the first 4, so it's as you have shown ^^^^^ 👍 2 Quote Link to comment Share on other sites More sharing options...
iron_city Posted October 31, 2023 Author Share Posted October 31, 2023 oh yes, now I see the "2" on the left, thank you for pointing that out! Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted November 10, 2023 Share Posted November 10, 2023 On 10/30/2023 at 5:44 PM, simonb said: 300Tdi, the dipstick location - and its yellow, and the cast elbow for the top hose/thermostat housing. Ignore the HRCxxxx numbers, they are casting refernces and won't be found in the parts catalogues. Just to confuse people in the future, I fitted 300tdi dipsticks to a couple of 200tdi’s many years ago. (I actually did it to stop the usual 200tdi dipstick tube falling into the sump issue - removed the 200tdi dipstick tube, bored out the retaining union to the correct depth to accept the 300tdi dipstick / o ring. The engine casting has a bolt in the same position as the 300tdi dipstick is bolted to.) Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted November 10, 2023 Share Posted November 10, 2023 200tdi dressed up to look like a 300tdi - dipstick, turbo and acoustic cover, ten years ago to the week I did this!, where did that go? Quote Link to comment Share on other sites More sharing options...
