Bowie69 Posted November 13, 2023 Share Posted November 13, 2023 No (well, negligible....) pulses true, but most of them produce LT76 destroying levels of torque without even blinking an eye. Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 13, 2023 Share Posted November 13, 2023 55 minutes ago, Bowie69 said: No (well, negligible....) pulses true, but most of them produce LT76 destroying levels of torque without even blinking an eye. You’d get away with a Hyper 9 or Leaf motor, but not much more. Sorry for dragging the discussion off topic. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2023 Share Posted November 14, 2023 18 hours ago, Bowie69 said: No (well, negligible....) pulses true, but most of them produce LT76 destroying levels of torque without even blinking an eye. But you can just dial it down in the configuration for a happy gearbox and likely still very good performance. 1 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted November 14, 2023 Author Share Posted November 14, 2023 On 11/12/2023 at 5:08 PM, Bowie69 said: Do you drop out of overdrive on the hills? Yes Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 14, 2023 Share Posted November 14, 2023 Just now, FridgeFreezer said: But you can just dial it down in the configuration for a happy gearbox and likely still very good performance. A bit like having a V8 and ensuring you only ever get 1/4 throttle 😛 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2023 Share Posted November 14, 2023 3 hours ago, Bowie69 said: A bit like having a V8 and ensuring you only ever get 1/4 throttle 😛 Not exactly - many modern cars limit torque in certain gears, and you can avoid shock loads like clutch dumps which makes everything kinder for the transmission. Given the smooth continuous power of an electric motor compared to the lumpy torque of an IC, it's likely you'd be able to transmit a LOT more actual useful power through any given gearbox than you otherwise could, even if you had to add some protection / limits. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted November 30, 2023 Author Share Posted November 30, 2023 On 11/14/2023 at 1:36 PM, FridgeFreezer said: Not exactly - many modern cars limit torque in certain gears, and you can avoid shock loads like clutch dumps which makes everything kinder for the transmission. Given the smooth continuous power of an electric motor compared to the lumpy torque of an IC, it's likely you'd be able to transmit a LOT more actual useful power through any given gearbox than you otherwise could, even if you had to add some protection / limits. Hopfully if everything goes ok i should be testing it all at the weekend 😃 2 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted December 1, 2023 Share Posted December 1, 2023 Interested! Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 2, 2023 Author Share Posted December 2, 2023 I wish this weather would go away as its been to cold to work in there so although the engine is back in now i still need to fit everything back in place, can't use my log burner as my Son's motorbike is parked right across the front of it and can't move it anywhere else whilst the landy is in there and didn't have anywhere else to put it 😟 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 2, 2023 Share Posted December 2, 2023 I bought an electric patio heater on offer from Morrisons, £29 / 2kw, mounted it on an old monitor arm on the garage wall so it can be pointed to shine down at me wherever I'm stood - even on low setting it's enough to take the edge off in a frosty workshop. Doesn't cost much electric to run. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 3, 2023 Share Posted December 3, 2023 I’ve just come indoors from a very long walk (about 9 hours) in the cold wind and that may be why I misread you comment as “electric potato heater “, John - I could really do with a cheesy hot potato right now!😬 2 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 3, 2023 Author Share Posted December 3, 2023 Got the engine running earlier after fitting everything back on ( front panel and stuff ) and once the engine was warm a i gave it a good rev ( not loaded ) and it boosed to 1.0 bar, its never done that in all the time i've owned it but will tell better once i've given it a road test 🙂 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 11, 2023 Author Share Posted December 11, 2023 Managed to give it a road test yesterday and wow what a difference the hybrid turbo and Mamba actuator kit has made, not had it on the Mway yet but it will easily boost to 1.4 so hopfully will boost more on the Mway 🙂 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted December 12, 2023 Share Posted December 12, 2023 Got a link to these? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 12, 2023 Author Share Posted December 12, 2023 (edited) 1 hour ago, Gazzar said: Got a link to these? No but will dig the paperwork out tomoz as at work till 10pm Edited December 12, 2023 by Cornish Rattler Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 12, 2023 Share Posted December 12, 2023 I hope you aren’t going to be asking about an exploded engine in the future… big wheels, 1.4 transfer, and 3.54 diffs is a lot to ask Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 12, 2023 Author Share Posted December 12, 2023 2 hours ago, Anderzander said: I hope you aren’t going to be asking about an exploded engine in the future… big wheels, 1.4 transfer, and 3.54 diffs is a lot to ask Std transfer box Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted December 13, 2023 Share Posted December 13, 2023 A 200 usually boosts to .8 bar from the factory. It's possible to get over 2bar from the OE set up, but 1.4 was always deemed a safe max. Rather than an exploded lump, you'll usually just get a blown head gasket, or if your injectors are dribbling, a melted piston Quote Link to comment Share on other sites More sharing options...
Gazzar Posted December 13, 2023 Share Posted December 13, 2023 Would an exhaust gas temperatures gauge be of benefit in this installation? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 13, 2023 Author Share Posted December 13, 2023 18 hours ago, Gazzar said: Got a link to these? Can't post pic's for some reason 😩 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted December 13, 2023 Share Posted December 13, 2023 1 hour ago, Gazzar said: Would an exhaust gas temperatures gauge be of benefit in this installation? Absolutely. A must have. I'd suggest that any deliberate upward variation in the turbo pressure requires one, so you can adjust the fuelling to suit. 1 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 13, 2023 Author Share Posted December 13, 2023 (edited) 3 hours ago, Gazzar said: Would an exhaust gas temperatures gauge be of benefit in this installation? Got one but didn't really get chance to look at it in traffic the other day but will take it on a run over the weekend and see what it reads 👍 Edited December 13, 2023 by Cornish Rattler Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted December 13, 2023 Share Posted December 13, 2023 On 12/11/2023 at 1:16 PM, Cornish Rattler said: Managed to give it a road test yesterday and wow what a difference the hybrid turbo and Mamba actuator kit has made, not had it on the Mway yet but it will easily boost to 1.4 so hopfully will boost more on the Mway 🙂 So what did you actually fit in the end? Can you post a link to the items? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted December 13, 2023 Author Share Posted December 13, 2023 2 hours ago, Chicken Drumstick said: So what did you actually fit in the end? Can you post a link to the items? Sorry i'm old school and not sure how to do links ☺️ But basicly a Falcon hybrid turbo with Mamba actuator kit comes with loads of different springs and rods Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 13, 2023 Share Posted December 13, 2023 Does this have anything to do with it? MAMBA TURBO - MAMBATEK Quote Link to comment Share on other sites More sharing options...
