Universal electrics for old cars
Thats why I prefer RS485 over CAN
I try to make drawings, but its a bit to early. So i apply to the imagination of everybody 😁
main goal is to have an overview to all by yourself and use a lot less cableing
Edited by Sigi_H
I can’t see myself ever retrofitting such a system in my cars, but it’s great to have the information laid out for those of us who don’t understand how to design or programme electronics in order to give us the option.  I like your approach of eliminating connectors where feasible, as long as that doesn’t interfere with the normal reparability of our vehicles - there is a lot to be said for being able to quickly unplug the electrics for a front wing, for example, so that it can be removed with a minimum of complication or effort.
  • Like 1
I even would connect the front wings without connectors. Better to have a tiny loop in the cableing in order to cut it easy and the cables still remain long enough to solder them. On the other hand, you still can attach connectors in that case, if you find them necessary
  • Like 1
Another option could be a really good anti-theft method.
The Arduino can easily be expanded with GPS and even GSM, That means, it can send coordinates via mobile net. It can ask for a special code to start or activate the electrics. It can stop after a time, when there was the wrong code. No limitations. Want to have a special sequence of switches to start? Everything is possible and individual. For example: Activate the Ignition key. Then activate indicator left (no signal is turned on), then indicator right, then push the horn button (without horn signal) to start and voila' ... brrrrrrrrrr ... 😁
Edited by Sigi_H
  • Like 1
Very interesting so please keep it coming.
However, there always is one.....
A major problem with all the conversions is legality....
I have left only a few LR's and 1 could e a god candidate for an E-motor conversion.
But one can't do it DIY here as only at the time of writing 2 companies can do this. And the amount of €€€  involved make it a big no go.
Not to mention us mere mortals living out in the deep dark Auvergne where 3 phase is getting rare and solar panels can't be integrated into the grid..
  • Like 1
  • Sad 1
3 hours ago, Sigi_H said:
RS485 Modbus is used in harsh environments not only in industry but also in domestic electrical systems.
I used Modbus in the 1980s - it was the proprietary network connection for Modicon PLCS. RS485 is I think is based on balanced pairs, extending the range of normal RS232. What I didn't know about is its use in domestic electrical systems. Have you an example?
This scares me, a lot, can you imagine the court case when your vehicle shuts off in the outside lane of the motorway?
By all means do lights, track stuff, do clever sequencing, but keep DIY electronics and software away from the vehicle controls.
  • Like 1
  • Thanks 2
Look for Modbus RTU in the Internet. Many of the chinese RS485 Cards work with Modbus RTU
Edited by Sigi_H
To be honest, this doesn´t scare me at all, because I am always free to hardwire things, which are important for me. Electronics only scare me, when the software is proprietary and I have no clue, what it really does. For example phoning "home" 😉
  • Like 1
I thought about CAN,  but I couldnt find a spec to program it. My experience from industry is: RS485 is way good enough !! Look at the spec.
... and a lot easier to handle.
Especially for people who are not at home in electronics
The mayor problem in automotive electronics is glitches from the sparks in the ignition system.
No problem with Diesel and not really from neighbor cars on the road.
Spec of RS485 is way enough and experience tells the same.
No problem with Diesel ......
mmm i work with Heavy Goods Vehicle's at a Dealer , and we see a lot off hick-ups with can signal's on trucks .... and they are all big diesels ....
As you will know I am into Morgans, MX5s and less fanatically, almost anything with an engine. There is almost no electronic logic in a pre-1990 Morgan, so parts availability and fit of alternatives are the only issues. For the Mk1 and Mk2 MX5 only the engine ECU is an issue, and the usual workaround is a motorsport ECU like Emerald (or MegaSquirt).
Where things get really difficult is obscure bits of electronic hardware and the underlying logic of the body systems. Tesla Roadsters and early Tesla Ss are being bricked by the failure of LCD screens with specific characteristics and specific obscure control chips. Although Tesla have open-sourced much of the early patents, they have not been forthcoming with the technical specification of older systems, citing "security" as the main issue.
Is there a standard way to collate data on what each widget does, what the dependencies are and the sub-systems design? (You can tell I'm an accountant and not a systems engineer).
TBH this has been more a marketing stunt than anything, they've "open-sourced" stuff that was all out there anyway and tells you nothing useful / nothing that people couldn't have worked out by themselves.
  • Like 3
19 hours ago, Bowie69 said:
Spark suppression is a pretty well understood science these days.
It is and therefore I am not affraid about a max 4 m long RS485
Put the Arduino in a metal case, coils on all inputs and most of the problems are solved. RS485 is shielded anyway
I have to say, I was inspired by the german company Joost, who made something like that, but with completely self developed components and proprietary software. He stoped the project, because he is more into motorcycle electrics now, but he was kind enough to leave me a lot of documents.
He also used RS485 for the project.
https://www.elektronikbox.de/shop/index.php?main_page=index&language=en
Main differences are:
The power modules are completely electronic, no mechanical relays and components. No fuses, because self protecting highside switches.
The dashboard module is a self developed Microcontroller board, no Arduino.
Why Arduino and relays
The Arduino is a cheap and well testet microcontroller, which can be changed easily
Highside switches have a lot smaller volume and are more reliable and self protecting , but they are not interchangeable in foreign countries. Relays with fuses are.
My concept with RS485 receivers in a relay box is identical for front and rear, but the adress-switch, which separates the adresses tells the box, if it is front or rear.
As I can see, enthusiasm is limited 😁
I can understand that, as electrics are not everyone's cup of tea. In any case, I will stick to my concept. I will describe the progress and invite everyone to add their two cents. The project will certainly take some time, because everything is working so far. However, I have often seen cable insulation crumble and the copper strands inside have oxidised black over long distances. That's why you can't even cut off a piece of cable and crimp a new connector
Thing is you're not really talking about electrics, it's much more electronics / microcontrollers, and while I have no fear of those things (see my LGT digi dash), I simply can't see the benefit of having that much electronics controlling everything in the car.
For a LR or any other classic car replacing a crumbling loom with a universal or even an auto sparks pre made loom is not at all difficult and should allow you to do everything 99.9% of what people want.
That said, it's the 0.1% that change the world and it's obviously up to everyone to do what they want with their vehicles, so very good luck and all :)
  • Like 2
May be, but aren´t electrics simply more cables than electronics?
The benefit of using the Arduino and power boxes is minimizing cableing and connectors with easy to learn programming. The overall system is indeed easier than bunches of cables.
The arduino is no rocket sience. In every ECU is more calculating power and most of us rely on it without thinking.
Lots of people underestimate themselfes.
But as I said, I can understand the fear 🫣
Lets see, what develops from the idea and thanks for the wishes.
Edited by Sigi_H
  • Like 2
