NATO hitch bolt size?
Mudmonkey
Having looked at the Dixon-Bate site the other day, new ones are supllied with 8.8 grade M12 set screws or bolts. Mine however was bolted on with some strange UNF size.
I believe that it is quite acceptable to use M12 to replace the old UNF bolts.
Glue
The fitment on any Td5 onwards Defender has to be four M12's, because the threaded inserts inside the chassis crossmember are metric, either 4 x M12s, or for the other sort of towing hitch, 2 x M16s.
Half inch (12.7mm) bolts will fit the hitch but M14s, while they may fit through the hitch, won't fit through the hole in the rear crossmember of an older Defender without making the holes bigger, as they are about 13.5mm.
The tensile strength of four M12 8.8s works out as something like 26 tonnes anyway IIRC so M14s are probably overkill :)
Yes, they are stamped either 8.8, 10.9 or 12.9 on the head. If unstamped they are unrated - avoid these. Most bolts (i.e. those from screwfix etc) are 8.8.
Some people talk about 10.8's but I have never seen these myself
yeah, basically, the higher the value, the greater the tensile strength...
i've seen 10.8 bolts, i'm sure there are some on my Disco...
For Landrover applications, regular 8.8 bolts are fine... Landrover use higher spec bolts in a couple of safety critical areas (brake caliper mountings and swivel housing mountings for example) and it would be good engineering practice to replace like for like...
most socket head screws (hex key screws) are 12.7 rated, and are generally cheaper than 12.7 rated bolts...
if you fix a NATO hitch on with 4 M12 x 8.8 bolts, you've got to be doing something seriously wrong to stress them...
Never seen 12.7 either :huh:
Another way to tell - though not foolproof - is that 8.8 grade or less are usually electroplated, 10.9 grade are usually galvanised, and 12.9 are usually bare steel. there are of course exception so always check the head stamping
8.8, 10.9 and 12.9 are what Land Rover currently uses
Look near the bottom of this thread
http://forums.lr4x4.com/index.php?showtopic=617
in the tech archive, an explanation of the numbers is there.
There is also an old "imperial hardness" stamp, some are stamped S and some are T, not sure what they are equivalent to though.
