jimmy_neutron Posted February 6, 2008 Share Posted February 6, 2008 When i start my landy up on a morning i need to check for cats hiding in the black wind tunnel thing that for the cooling fan. Needless to say i discovered i had to do this after loosing a couple of alternator belts and my mrs complaining of cats going missing. This checking before starting method has worked for ages but now the buggers are getting wise and jump out when i pop the bonnet and then jumping back in. Its all rathee messy So i had a plan.. I can remove the black wind tunnel cat bed and fit a kenlowe fan which won't even turn till its actually needed. I want to mount the fan on the engine side of the radiator and not the front. So, do i need a blow *** or a suction type ? Quote Link to comment Share on other sites More sharing options...
denviks Posted February 6, 2008 Share Posted February 6, 2008 When i start my landy up on a morning i need to check for cats hiding in the black wind tunnel thing that for the cooling fan.Needless to say i discovered i had to do this after loosing a couple of alternator belts and my mrs complaining of cats going missing. This checking before starting method has worked for ages but now the buggers are getting wise and jump out when i pop the bonnet and then jumping back in. Its all rathee messy So i had a plan.. I can remove the black wind tunnel cat bed and fit a kenlowe fan which won't even turn till its actually needed. I want to mount the fan on the engine side of the radiator and not the front. So, do i need a blow *** or a suction type ? a sucker type mate.........i have twins on mine Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted February 6, 2008 Author Share Posted February 6, 2008 a sucker type mate.........i have twins on mine TA Are they any good .. other than for saving cats of course ? Quote Link to comment Share on other sites More sharing options...
Lars L Posted February 6, 2008 Share Posted February 6, 2008 Now I don't know what engine you have, but the fan on my 200Tdi is almost never running. Only when hauling a trailer up steep hills in hot weather and when offroading. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted February 6, 2008 Share Posted February 6, 2008 Don't waste money on a kenlowe, nip down the scrappy and get one for about a tenner, possibly less. I've got a 2.0 mundano fan (i think!) and it does the job admirably with an X-eng thermoswitch housing. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted February 6, 2008 Author Share Posted February 6, 2008 Good guess .. its a 200tdi. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted February 6, 2008 Author Share Posted February 6, 2008 Nice job .. How much is one of the thermostat housing. Looks much better than the kenlowe thing Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 6, 2008 Share Posted February 6, 2008 The X-Switch is about £35 I think, you get a forum discount (find SimonR and follow the link in his signature). The kenlowe switch is total junk and the fans are well overpriced. I'm using a twin fan from an Audi something, Mondeo ones are good (big, common, cheap) but the general rule is wander the scrapyard with a tape-measure until you find something that will fit. Then spend the £100 you've just saved on beer! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 7, 2008 Share Posted February 7, 2008 I'll echo Lukes and Fridges advice another vote for Mondeo fans and the X-switch Mo Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted February 7, 2008 Author Share Posted February 7, 2008 Cheers both... X-eng switch jobby ordered.. Quote Link to comment Share on other sites More sharing options...
firemannotsam Posted February 7, 2008 Share Posted February 7, 2008 When i start my landy up on a morning i need to check for cats hiding in the black wind tunnel thing that for the cooling fan.Needless to say i discovered i had to do this after loosing a couple of alternator belts and my mrs complaining of cats going missing. This checking before starting method has worked for ages but now the buggers are getting wise and jump out when i pop the bonnet and then jumping back in. Its all rathee messy So i had a plan.. I can remove the black wind tunnel cat bed and fit a kenlowe fan which won't even turn till its actually needed. I want to mount the fan on the engine side of the radiator and not the front. So, do i need a blow *** or a suction type ? Hi guys I have a 98 Disco 3.9 with auto box and aircon and larger tyres so the engine works hard would a fan from a car such as a mondeo be powerfull enough to cope rather than paying big bucks for a kenlowe? Thanks in advance firemannotsam Quote Link to comment Share on other sites More sharing options...
Guest mortus Posted February 7, 2008 Share Posted February 7, 2008 i remember when my cat had no hair on one side of its body when it sat in my parents disco... Quote Link to comment Share on other sites More sharing options...
Guest l90truck Posted February 7, 2008 Share Posted February 7, 2008 i used rr chassic air con fans on the fron works wicked on a 3.9 v8 90 Quote Link to comment Share on other sites More sharing options...
nicks90 Posted February 8, 2008 Share Posted February 8, 2008 i wish next doors cat would come and sleep in my fan cowl! bloody annoying noisey sod yowling all night long. Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 8, 2008 Share Posted February 8, 2008 bloody annoying noisey sod yowling all night long the cat or the neighbour :) Quote Link to comment Share on other sites More sharing options...
AD90 Posted February 8, 2008 Share Posted February 8, 2008 I fitted twin fans off a Peugeot 405 td (£10 from breaker) These are mounted in front of the radiator. I then drilled and tapped the stat housing to accept a 95degC switch. Much neater (and cheaper) than the X-Eng gismo or the Kenlowe 'thing' I'll try post some pics AD90 Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2008 Share Posted February 8, 2008 LR do a anti cat guard for the fan cowling. part number STC8866 Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted February 8, 2008 Share Posted February 8, 2008 "bloody annoying noisey sod yowling all night long." Try a dog whistle, most of the local cats can't stand it, and the noise carries well, so you can use it from the bedroom window. The other trick is to develop the ability to make the PSSSSHH noise a cat makes when trying to scare off a competitor. The combination of both sees off the all the local cats. I'm not saying they won't come back occasionally, but they don't stay long once you have explained in language they can understand that it's your territory. Cheers. Quote Link to comment Share on other sites More sharing options...
Superduke Posted February 8, 2008 Share Posted February 8, 2008 Jimmy I have run my 110 200tdi for two years with no fan at all ( or cat box) and it has never once got hot, the temp gauge sits happily at 88/90 degrees all day! I was planning to fit a kenlowe and just never got round to it Quote Link to comment Share on other sites More sharing options...
