Rat Monkey Posted March 18, 2008 Share Posted March 18, 2008 I' feed up of getting a soaking whenever I drive off in my Land Rover so I need to do some leak proofing. I have read the water ingress manual on the tech archive. Dum Dum I have found but it talks of using black tape to cover the Dum Dum and of clear sealant. Could anyone tell me what this "black tape" is and what sort of clear sealant I should use as well. Thanks in advance for helping to keep me nice and dry. James Quote Link to comment Share on other sites More sharing options...
rob90 Posted March 18, 2008 Share Posted March 18, 2008 for sealent I use clear silicone sealent you know the bathroom stuff Quote Link to comment Share on other sites More sharing options...
Scotian Posted March 18, 2008 Share Posted March 18, 2008 I got so fet up with leaking and I couldnt find where it was comming from so I stripped every bit of the old sealant out of the gutters and along the front top of the roof and replaced it with gutter sealant (tar like stuff in a tube) then when it was almost dry (took a few days) sprayed black waxoil/paint all over it. Then I used black silicone sealant and put it in all the gaps in the perrishing rubber window seals on the windscreen and the alpine windows. It seems to have done the job. Now the only water comming in is from the door seals but at least it doesnt drip on my lap. Quote Link to comment Share on other sites More sharing options...
MINESAPINT Posted March 18, 2008 Share Posted March 18, 2008 Been there, done that. Found the solution. OILSKINS! Or don't venture out when its raining. MINESAPINT Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted March 18, 2008 Share Posted March 18, 2008 I got so fet up with leaking and I couldnt find where it was comming from so I stripped every bit of the old sealant out of the gutters and along the front top of the roof and replaced it with gutter sealant (tar like stuff in a tube) then when it was almost dry (took a few days) sprayed black waxoil/paint all over it. Then I used black silicone sealant and put it in all the gaps in the perrishing rubber window seals on the windscreen and the alpine windows. It seems to have done the job. Now the only water comming in is from the door seals but at least it doesnt drip on my lap. Gutter Sealent is black gold. I used bathroom stuff on my sunroof and within a few days it was leaking. I got fed up with it so took the glass out, cleaned out the gutters, filled it with gutter sealant and put the glass back on then filled the second gutter running around the outside of the sunroof until it was level with the top of the glass. It hasn't leaked since. Although I can't open the sunroof any more, but a Defender has enough places for air to get in. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted March 18, 2008 Share Posted March 18, 2008 Searching in the tech archive and downloading the water ingress manual could be handy Quote Link to comment Share on other sites More sharing options...
smo Posted March 18, 2008 Share Posted March 18, 2008 Searching in the tech archive and downloading the water ingress manual could be handy Somebody didnt read the original post - he already has read it (from the tech archive too!) Rat Monkey - The black tape it talks of is exactly that, its tape, and its black - probably of the duck-tape variety. Quote Link to comment Share on other sites More sharing options...
Rat Monkey Posted March 18, 2008 Author Share Posted March 18, 2008 Cheers for the replies so far. I have some black duck tape so will use that. Here's hoping for some dry driving after easter when i've had a chance to play with some sealants. Quote Link to comment Share on other sites More sharing options...
smo Posted March 18, 2008 Share Posted March 18, 2008 Cheers for the replies so far. I have some black duck tape so will use that. Here's hoping for some dry driving after easter when i've had a chance to play with some sealants. For a good permenant seal use Sikaflex or similar, its a marine sealant that kinda glues as well - always remains flexible and is incredibly strong, it also cures with moisture which is good for both marine, and landrover environments!! Quote Link to comment Share on other sites More sharing options...
Rat Monkey Posted March 18, 2008 Author Share Posted March 18, 2008 Sounds like good stuff SMO, will it work on door seals as thats where most of my problem is Quote Link to comment Share on other sites More sharing options...
smo Posted March 18, 2008 Share Posted March 18, 2008 Yes, but your best bet is to get new seals and then adjust the door hinges so it closes properly - ive never had one that cant be adjusted enough, youll find some leaks look like a door seal problem but turn out to be where the roof joins the screen. Quote Link to comment Share on other sites More sharing options...
steve b Posted March 18, 2008 Share Posted March 18, 2008 Hi James, ......just use it when its not raining mate ....seriously though I'd check the alpine glass seals as a start....the water gets in there and then runs along the inside gutter to drip on your right knee when you brake/go round a left corner, also make sure that your roof rack feet haven't damaged the mastic seal in the outside gutter.... How is Sara getting on with learning to drive ? Hope all is well with you Cheers Steveb Quote Link to comment Share on other sites More sharing options...
Rat Monkey Posted March 18, 2008 Author Share Posted March 18, 2008 Hi Steve, Cheers for the suggestion, thats exactly where it drips on me, tends to do it when I reverse out of the drive, have to get ready with a big wad of tissue or my right leg gets a soaking. Sarahs been driving round car parks in the Landy so far, but no lessons yet. James Quote Link to comment Share on other sites More sharing options...
steve b Posted March 18, 2008 Share Posted March 18, 2008 Welcome to the world of Land Rovers, a damp right knee is part of the initiation ceremony Another point to suggest is get someone to 'rain' a hose onto the roof on a dry day and see if you can see water coming in anywhere. The most likely place is the gutter run on the HT as it can sit in there and any gaps allow seepage to the inner part of the gutter......which then drains all over your right knee when you brake/ reverse out of your drive... ....you could always reverse in .... Steve Quote Link to comment Share on other sites More sharing options...
Rat Monkey Posted March 18, 2008 Author Share Posted March 18, 2008 Tried that one, just leaks on the other end of the door all over the seat, found that out after jumping in and driving off then wondered if i'd sudenly become incontinent Quote Link to comment Share on other sites More sharing options...
Rat Monkey Posted March 18, 2008 Author Share Posted March 18, 2008 btw Steve what would tou suggest to use to seal the HT gutter with?? Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2008 Share Posted March 18, 2008 I see your a bit closer to Land's End than me if your 110 has the vents above the rear door, try blanking these off too, LR deleted them froml ater models as they found water/mist was being sucked in due to the airflow around the 110's rear end. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted March 19, 2008 Share Posted March 19, 2008 I get water dripping on my right foot. Luckily it doesn't rain much here Quote Link to comment Share on other sites More sharing options...
steve b Posted March 19, 2008 Share Posted March 19, 2008 btw Steve what would tou suggest to use to seal the HT gutter with?? I'd go for Seam Sealer from a motor factors/car paint shop - silicone works ok but seems to be affected by sunlight and won't take a coat of paint should you need to paint over it. Steveb Quote Link to comment Share on other sites More sharing options...
Dave K Posted March 19, 2008 Share Posted March 19, 2008 I see your a bit closer to Land's End than me if your 110 has the vents above the rear door, try blanking these off too, LR deleted them fromlater models as they found water/mist was being sucked in due to the airflow around the 110's rear end. The sealant around them also deteriorates causing leaks, it happened on my 90! Quote Link to comment Share on other sites More sharing options...
Spearos Posted May 26, 2008 Share Posted May 26, 2008 Welcome to the world of Land Rovers, a damp right knee is part of the initiation ceremony Another point to suggest is get someone to 'rain' a hose onto the roof on a dry day and see if you can see water coming in anywhere. The most likely place is the gutter run on the HT as it can sit in there and any gaps allow seepage to the inner part of the gutter......which then drains all over your right knee when you brake/ reverse out of your drive... ....you could always reverse in .... Steve Time for a dumb question! I'm relatively new to Land Rovers and my 90 drenches my right knee when it rains so I'm looking to solve this but what is 'HT'??? Thanks in advance, Mark Quote Link to comment Share on other sites More sharing options...
110WestCape Posted May 27, 2008 Share Posted May 27, 2008 Time for a dumb question! I'm relatively new to Land Rovers and my 90 drenches my right knee when it rains so I'm looking to solve this but what is 'HT'???Thanks in advance, Mark Mark, I presume reference is made to Hard Top gutter. Cheers Wikus Quote Link to comment Share on other sites More sharing options...
bpman Posted May 27, 2008 Share Posted May 27, 2008 Mark, I presume reference is made to Hard Top gutter.Cheers Wikus my 110 used to leak, again it was the gutters .. it was on the rear panel where the gutter curves around the door, there was a hairline crack, seated with dumdum. As stated in previous posts, the water ingress manual has a diagram of how the roof section is attached to the gutter, you don't need a big hole to let water in! I am now a member of the "dry knees club". bpman Quote Link to comment Share on other sites More sharing options...
Spearos Posted May 27, 2008 Share Posted May 27, 2008 Thanks guys, I thought it might of meant hardtop. I've had a look at the Water Ingress Manual and when I get chance it looks like I'm going to be inspecting the roof and end panel for cracks/gaps/holes... Mark Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 27, 2008 Share Posted May 27, 2008 Is the land rover leak proofing manual published by the same people who print "Cat herding for beginners" and "Jelly nailing for fun and profit" Quote Link to comment Share on other sites More sharing options...
