pritch1 Posted February 20, 2006 Share Posted February 20, 2006 Looks great that gonna be awsome with the big tyres Quote Link to comment Share on other sites More sharing options...
SHAVED_GORILLA Posted February 20, 2006 Share Posted February 20, 2006 Excellent!!! What more can you say!!! SG Quote Link to comment Share on other sites More sharing options...
dollythelw Posted February 20, 2006 Share Posted February 20, 2006 did you buy it from Scorpiron? I looked in the catalogue and couldnt find it wheres the 8274?? Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted February 20, 2006 Share Posted February 20, 2006 all punches will now be on string 2 foot long attached at ground level. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 20, 2006 Share Posted February 20, 2006 all punches will now be on string 2 foot long attached at ground level. Don't you mean "Portal axles are banned because we can't handle progress and they smell of wee" like some other event organisers Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted February 20, 2006 Share Posted February 20, 2006 Don't you mean "Portal axles are banned because we can't handle progress and they smell of wee" like some other event organisers Good to see it outside at last Andy. Looking good. Got a planned date for moving under it's own power? Al. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 20, 2006 Share Posted February 20, 2006 Well it was worth the wait Andy - a fantastic piece of work. I notice you've calculated the approach angle based on the 44's then...... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 20, 2006 Share Posted February 20, 2006 Got a planned date for moving under it's own power?And a planned time thereafter for the first transit-section incident? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 20, 2006 Share Posted February 20, 2006 I can only copy what others have said Andy. A beautiful bit of work. You're not actually going to get it dirty are you? Les. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted February 20, 2006 Share Posted February 20, 2006 Don't you mean "Portal axles are banned because we can't handle progress and they smell of wee" like some other event organisers nah just going to add a limbo section at the start of the event. say 6 foot limbo bar. to start the event you have to go under the bar without knocking it off. Only tyres carried ON the vehicle when passing under the bar can be used on the event. So if Moglite uses space savers he must use them for the whole event unless he carries the 44" tyres underthe bar on the vehicle Then he could change them But he would have to have the space savers on the vehicle for the rest of the event. To finish the event they would again have to travel under the limbo bar. There playing field levelled Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted February 20, 2006 Share Posted February 20, 2006 There playing field levelled Or he could just deflate the tyres... Or... He could fit an extra CV and steering klnuckle to all four wheels - the line of the pivot being in the fore-aft direction - then he could just tilt the wheels out or in at the top/bottom and reduce their effective height - kind of like one of those wheelchairs they use for sports events. Hmm I kinda like that idea - lots of possibilities, most of the useless... Al. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 20, 2006 Share Posted February 20, 2006 Al - why not add a swivelling portion to the axles and rotate the ends so the portals are in the losing-clearance direction? That could even be vaguely useful, the twist-off scores would be astronomical Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 20, 2006 Author Share Posted February 20, 2006 Thanks for all the very kind comments - I'm certainly very chuffed with the way its shaping up. To answer some of the questions Big tyres are a way off yet, I've got quite a bit of work to do reversing the rims before powdercoat. I'll be happy to shake it down on the 37's Geoff - can you have one ? Of course, as long as you pay my monthly invoices at £50 an hour for build time. Time spent colour keying and parts chasing on eBay I'll invoice at £25 an hour - fair enough Diesel Jim - yeah the drag link on the front is all wrong bolting it above the steering arm will help, but it needs a touch of oxy to refine the angles. That will get it a lot higher. Its binding at the moment, so it will have to get sorted. Its a modified sumo bar, so it should take a knock or two. V8Camel - Paul, the overall height is similar/lower than my Ibex as there is no seatbox to speak of. I should have measured it - doh. I need to get it weighed when its got all the fluids and panels sorted out. Limbo sections - no problem I can pull the springs out in a few minutes - thats how I got it out of the garage Astro_al - engine running in march, trundling around in April is my approx time line. But if it slips - I don't care. Bish - the front approach angle is not quite 90degrees, but the winch bumper is 750mm off the ground, so I'm not expecting too many problems. That is as far back as the winch will go without moving the steering box. Les - get it dirty - hmmm not until I've finished painting it at least - washing mud off of red-oxide is a PITA Exhaust was done today, so I can now mount the oil coolers, and start wiring and piping all the relevant lines before the engine start. But I'm gonna have a break for a few days. A lot of hard work shifting and winching it around, next time it comes out of the garage, it will be driving Thanks again Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted February 20, 2006 Share Posted February 20, 2006 Does look bloody good Andy... in all the time you've done that, i've managed to get that old rangie rear axle casing that you gave me shot blasted and painted in black hammerite! Although i did build my 90 in 2000! LOL! Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted February 21, 2006 Share Posted February 21, 2006 Geoff - can you have one ? Of course, as long as you pay my monthly invoices at £50 an hour for build time. Time spent colour keying and parts chasing on eBay I'll invoice at £25 an hour - fair enough Better offer than I was expecting - thought I'd get "Build your own bleedin' truck!" B) 'Fraid if I had that much money I'd have my own workshop and toys (though I very much doubt the end result would be even close to the same class). Quote Link to comment Share on other sites More sharing options...
gelf Posted February 21, 2006 Share Posted February 21, 2006 wow! those nuts holding the waffles look good Quote Link to comment Share on other sites More sharing options...
freeagent Posted February 21, 2006 Share Posted February 21, 2006 the tubework on that is a work of art, you should be very proud of your work...... B) Quote Link to comment Share on other sites More sharing options...
Tonk Posted February 21, 2006 Share Posted February 21, 2006 hmmmm colour, is that zetor orange Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted February 21, 2006 Share Posted February 21, 2006 hmmmm colour, is that zetor orange It's whatever Scrapiron racing use - in fact, Andy is sponsored by Scrapiron, they just haven't got the stickers printed yet... Al. Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 21, 2006 Author Share Posted February 21, 2006 hmmmm colour, is that zetor orange It was supposed to be Tangiers G4 orange, which going all Laura Ashley is more of a blood orange colour. However the new tin that the paint factors mixed up by matching the old tin, is a much brighter orange - which is good IMHO. I think there is a colour called emergency orange, which they paint lifeboats with - that is an orange , and mine is pretty close Keep the compliments coming - I'm loving it B) Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted February 22, 2006 Share Posted February 22, 2006 It was supposed to be Tangiers G4 orange, which going all Laura Ashley is more of a blood orange colour.However the new tin that the paint factors mixed up by matching the old tin, is a much brighter orange - which is good IMHO. I think there is a colour called emergency orange, which they paint lifeboats with - that is an orange , and mine is pretty close Keep the compliments coming - I'm loving it B) are you putting side steps on it so that Ali Read can climb in? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted February 22, 2006 Share Posted February 22, 2006 are you putting side steps on it so that Ali Read can climb in? Fruity will be able to walk underneath without stooping Quote Link to comment Share on other sites More sharing options...
