AWDC Howlin'Wolf round 2
saley
Well, I've just got back from 2 days recceing with Badger and I can tell you that the lake is the highest I have ever seen it in over 4 years. :blink: :blink:
However, we won't be using it :P There may be a handful of sections with some standing water/puddles etc but there will be no reason for you to go into the lake.
I would point out that the ground is as hard as nails so you may want to consider an alternative type of ground anchor to the spade type - I would :ph34r:
The fire pit is there but bear in mind that Kirton is open this weekend for Pay & Play so how much wood is left is anyones guess. I will bring a few pallets to get a fire started so if anyone has an excess of wood they'd like to bring, every little helps.
KORC assure me that the Cafe will be open on Sunday morning and through the day.
Arm bands - check
Sealskinz socks - check
Spare pair of underware in case I'm in the truck if/when Dan rolls it again - check :ph34r:
Neil, does that mean pin'n'plate is the order of the day??? That'll end badly for someone - make the $itch run up and down with a tonne of steel then put a hammer in his hand :lol: :lol: :lol:
Current entry list for Round 2 as follows
2 Richard Nicolson Nik Tall Land Rover 90 2
4 Alastair David Philip David Range Rover Hybrid 1
6 Nick Watts James Trembath Special Special 2
7 John Sales Carl Hurst Land Rover Hybrid 1
8 Rob Tunnah Jamie Lewis ART Mitsimog 1
10 Gary Zoller Jon Norman Land Rover 90 2
11 Philon Parpottas Alex Parpottas Land Rover 90 2
15 Peter Jackson Richard Norris Range Rover 2
19 John Fair Robert Jones Land Rover Discovery 2
21 Jason Morgan Nathan Morgan Suzuki Samurai 3
22 Chris Booth Thomas Booth Land Rover Series II 1
24 Jonathan Smith Alan Webb Land Rover 90 3
25 Rob Butler Andrew Marshall Suzuki Samurai 3
27 Glynn Yates Richard Weatherly Land Rover 90 2
29 Kevin Pocock Adrian Turner Range Rover 1
32 Bruce Gould Andy Wilkinson Land Rover Defender 2
33 Ian Corfield Emma Corfield Land Rover 90 3
36 Austin Jewitt Marc Dyer Land Rover 90 2
40 Bert Smith Dan Smith Land Rover 90 2
41 Bob Smith Ian Moulsdale Land Rover Hybrid 3
42 Sam Coulton Matthew Martin Land Rover 90 3
43 Andrew Woodhouse Mark Whetton Land Rover 90 2
44 Tim Burt Jake Lloyd Land Rover 90 3
47 John Barrie Gee TBA Range Rover 3
50 Dan Elias Will Warne Land Rover 90 2
53 Steven Bennett Stephen Hoole Land Rover 90 2
54 Timothy Slator Robert Forbes Range Rover 3
55 Nathan Flinton tbc tbc tbc tbc
Entries close tomorrow Monday 30th
Finnished work on the car today and it now looks like this. If you think i missed anything please let me know as i can alter during the week!
SW you can have a look under at the w/e as im having trouble sending photos for some reason?
Final entry list as follows. Entries are now closed.
Number Driver Co-Driver Vehicle Class
25 Rob Butler Jack Dolan Suzuki Samurai 3
31 Jonathan Jacques Dan Furniss Jeep CJ 7 1
32 Bruce Gould * Andy Wilkinson Land Rover Defender 2
36 Austin Jewitt * Marc Dyer Land Rover 90 2
48 Tony Cordell Les Brocklehurst Land Rover 90 2
55 Nathan Flinton tbc tbc tbc 2
I was chuffed to bits to be able to remember the route through the deep water in the big lake Rob, after spending ages in the morning and eventually giving up on it after several deep dunkings, and then watching you go to it at half tyre depth after I retired when I filled the dipstick,
and now we are not using it :(
See you all Sun, minus paint job
Chris
im really gutted that there is no deep water (NOT)
did you retire before us Boothy or was it the other way around but im nie on convinced it was down to very similar reasons :lol: :lol: :lol:
as far as the dry cyber keys goes i didnt get a chance to see 1 :(
No I lasted until about 2.30ish but I was soaked to the skin early doors and bloody frozen all day,
I saw the oil pressure dropping when I had been in the deep stuff for about 20 minutes waiting for the lad to get to grips with the ground anchor and I presume I filled the sump via the dipstick with muddy water, so turned it off and called it a day.
I've spent the last week water proofiing it again, for nowt now were only puddle splashing. :P
Hotel Saturday night, I'm still a soft ar*e. :blush:
last year apparently 2/3 of cyber keys were set on dry sections I think I successfully managed to find none of those but all of the other 1/3
i think we were lucky and found the other 2/3rds last year
