magnetically activated switches
heath robinson
Hi all.
This is Land rover related, but you'll have to bear with me. I'm looking for a magnetically activated switch. I've looked at a fair few reed switches, but they all seem a little flimsy for my needs. I'd ideally like to find a switch that will activate when a magnet like this is placed near it. When I say near, I mean a few mm away, say on the other side of some birmabrite or a bit of trim. I need the switch to be 12v, and handle enough current for, say, a fuel pump, or maybe a switched ignition line.
Do you see where I'm going with this? :ph34r: Sneaky, ain't it.
Maybe some form of microswitch could be used, but I'd rather just a beefy reed switch if possible.
Any thoughts or advice?
Thanks.
Beefy and reed switch don't go together well: have you thought of using the reed switch to trigger a small relay which then triggers / latches the bigger power relay? You could use a Hall Effect switch instead of a reed, solid state so no broken glass bits either.
Edit: the 3A ones in Superpants' link aren't big enough to switch a pump directly, but the 1A sort will easily fire the coil on a 12V automotive relay
You could always wire the cig lighter in series with a relay, so you have to push the lighter button in to start the car.
On that basis Fridge, you could have a large red illuminated push button in the middle of the dash with START written on it. It would be more secure if it was not actually wired up to anything !
Hat, coat, umbrella, keys, passport . . . .
There's a thread HERE about securing yer lock-up, that has some amazing tales of mis-direction. Seems like stupid thieves are fairly common.
Following on from ideas in that thread, I could link the started button to a smoke grenade and a massively loud alarm, although I'd need a switch to stop my mates from pushing it.
I just don't think that I can bring myself to sully my truck with one of those chav-tastic red "Start" buttons... :(
I do like the idea of an idiot button. It wouldn't necessarily need to be that blatant though. If the thing won't start, they'll probably look for small switches hidden away. Have one or two that aren't too well hidden. ;)
The ciggy lighter is nice. It never worked anyway. Just have to pray that the pikey doesn't have a fag to calm his nerves while he tries to get the thing to start. :o Could always have it the other way around, so that the thing WON'T start if the ciggy lighter's in. Not won't run though, or again my mates could inadvertently cause calamities.
I also thought that a latching button switch under a small hole in the trim might be good, poke a match through to toggle it.
There is a way of wiring the horn into the starting/running system such that the engine will turn but not pick up unless the horn button has been pressed first - the last thing a tealeaf is going to do is press the horn I reckon...
Roger
(p.s. my use of the RRC is not that frequent so my anti-theft solution is to remove a vital ignition component and hide it in the house - I wouldn't have posted the above idea if I actually used it myself)
Roger
In my MGB of old I had a number of high pitch, high volume sounders hidden around the interior that were wired to the ignition. Unless they were isolated first, by hidden switches, the noise was almost intollerable while trying to start the car.
I like Simon's idea.
I rigged up some deterrants it a mates old nova. We installed two extra switches in the blanks in the dash, one labelled as front fogs and the other labelled as heated seats, so they blended in nicely.
One of the switches was connected to the fuel pump, and the other triggered both the cars main horn, and a horn mounted in the footwell behind the dash via a latching relay.
With the ignition off, he'd turn the "fuel" switch off and the "horn" switch on. If a scrote was to try to hot wire it, as soon as the ignition was powered up, the horns would start blasting, and it bloody hurt!
I've got one of these: eBay linky
Ok, so it's still sat on my inventing table, but the idea is there...
James....
Thank you, thank you, thank you!
I have one of these fitted to my Disco and didn't know where it came from and as I only have one key set, I am totally paranoid about losing the damn thing!
Have asked at my local specialist and he just shook his head.
e-bay chap, here I come!
Cheers, once again!
