smokeyone Posted May 21, 2011 Share Posted May 21, 2011 Yes, I know it's been bounced around on the forum before but after reading up on the details I have confused myself about the gearbox mountings. Let's say I stick with the series transfer case and use an Ashcroft adapter kit to connect to the R380 gearbox. Leave the transfer case in the same place and move everything else forward - the transfer case has it's own mountings so do I still need gearbox mountings as well or are these instead of the transfer case mountings - which bit am I missing.... ...or is it engine mountings, gearbox mountings and transfer case mountings..... Thanks very much Quote Link to comment Share on other sites More sharing options...
Mike Brownlie Posted May 21, 2011 Share Posted May 21, 2011 Yes, I know it's been bounced around on the forum before but after reading up on the details I have confused myself about the gearbox mountings. Let's say I stick with the series transfer case and use an Ashcroft adapter kit to connect to the R380 gearbox. Leave the transfer case in the same place and move everything else forward - the transfer case has it's own mountings so do I still need gearbox mountings as well or are these instead of the transfer case mountings - which bit am I missing.... ...or is it engine mountings, gearbox mountings and transfer case mountings..... Thanks very much Would it not be easier to fit the r380 and lt230? Use a defender 300tdi/td5 gearbox tunnel ?? Quote Link to comment Share on other sites More sharing options...
smokeyone Posted May 22, 2011 Author Share Posted May 22, 2011 Would it not be easier to fit the r380 and lt230? Use a defender 300tdi/td5 gearbox tunnel ?? Probably would be easier but I would like to keep the series transfer box and in any event I do not have a lt230 transfer case. Also I will not have to worry about 2 wheel 4 wheel drive or cv joints on the front prop... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 23, 2011 Share Posted May 23, 2011 Just to play Devil's Avocado... 1 - You don't need CV's in the front axle (or prop, wherever that idea came from!) to run a full-time LT230, plenty on here doing it. 2 - You can convert the LT230 to 2WD if you want (I did, there's a writeup in the tech archive). 3 - You will spend far more on the conversion kit than just buying a good used LT230, and you're then running a much older weaker box with a poorer selection of gear ratios. Quote Link to comment Share on other sites More sharing options...
smokeyone Posted May 25, 2011 Author Share Posted May 25, 2011 Just to play Devil's Avocado... 1 - You don't need CV's in the front axle (or prop, wherever that idea came from!) to run a full-time LT230, plenty on here doing it. 2 - You can convert the LT230 to 2WD if you want (I did, there's a writeup in the tech archive). 3 - You will spend far more on the conversion kit than just buying a good used LT230, and you're then running a much older weaker box with a poorer selection of gear ratios. I realise the pitfalls but would still like to stick with the series transfer case. Thank you for the pointing out the problems. Still need to find out about the gearbox and or transfer box mounts...... Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 25, 2011 Share Posted May 25, 2011 Ok then, if you move everything forward you will need relocated engine mounts, no need for gearbox mounts as its supported by the TC. But having said that, i had an lt77 mated to a series TC, i had used one mount on the main box and one mount on the tc, just like when fitted to a 90/110. I also moved the gearbox mounts and not the engine mounts if it helps. Fridge summed it up for you, just keep it simple............... G Quote Link to comment Share on other sites More sharing options...
smokeyone Posted May 25, 2011 Author Share Posted May 25, 2011 Ok then, if you move everything forward you will need relocated engine mounts, no need for gearbox mounts as its supported by the TC. But having said that, i had an lt77 mated to a series TC, i had used one mount on the main box and one mount on the tc, just like when fitted to a 90/110. I also moved the gearbox mounts and not the engine mounts if it helps. Fridge summed it up for you, just keep it simple............... G Brilliant, just what I wanted to check on - all the searches mention gearbox mounts so I was thinking transfer case mounts plus gearbox mounts and engine mounts - could not be correct. Right then, keeping it simple ish - transfer case mounts leave as is - hang the r380 between the transfer case and engine and just make new engine mounts...I know there are 99 other things to fiddle with as well. How did yours turn out with one mount on the gearbox and one on the transfer case.... Cheers Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 25, 2011 Share Posted May 25, 2011 Brilliant, just what I wanted to check on - all the searches mention gearbox mounts so I was thinking transfer case mounts plus gearbox mounts and engine mounts - could not be correct. Right then, keeping it simple ish - transfer case mounts leave as is - hang the r380 between the transfer case and engine and just make new engine mounts...I know there are 99 other things to fiddle with as well. How did yours turn out with one mount on the gearbox and one on the transfer case.... Cheers Just fine, its the same as a normal 90/110 installation. When bolted together they make up one unit, and they line up perfectly. This is what mine looked like (home made conversion) G Quote Link to comment Share on other sites More sharing options...
discomikey Posted May 25, 2011 Share Posted May 25, 2011 so, i know poeple say you cant use a disco box cos its too long. could you put the series bellhousing on to remedy this? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 25, 2011 Share Posted May 25, 2011 so, i know poeple say you cant use a disco box cos its too long. could you put the series bellhousing on to remedy this? No 'cos the input shaft is still a foot long, and the gear levers still come up a foot further back than a Defender box. Quote Link to comment Share on other sites More sharing options...
discomikey Posted May 25, 2011 Share Posted May 25, 2011 ahh fair enuff, just that i reckon my bearing is going in my box and i have a spare disco box and series bellhousing lying about ill probably just rebuild it. Quote Link to comment Share on other sites More sharing options...
SCG Posted March 1, 2022 Share Posted March 1, 2022 Hola a todos! Soy Santiago Graziano de Argentina y tengo un Serie IIA 109" Militar. Por motivos de documentación tengo que cambiar el motor 2.25 lts. original. Tengo pensado instalar un 200 td (sin intercooler) de una vieja Disco. El tema es; lo pongo sin el turbo y le dejo la caja de cambios original, o le dejo el turbo y le coloco una R380 con el transfer de serie ??? mis cajas son las originales y estan en muy buen estado, pero tengo miedo que el elevado torque del 200td rompa la transmisión! Atrás tengonun eje HD que se aguanta todo. Ustedes qur me dicen ??? esa caja R380 con transfer de serie que está en la foto. Está en venta ??? Muchas gracias! Saludos desde Argentina !!! Quote Link to comment Share on other sites More sharing options...
western Posted March 1, 2022 Share Posted March 1, 2022 Translated with Google translate.  Hello everyone! I am Santiago Graziano from Argentina and I have a Military Series IIA 109". For documentation reasons I have to change the original 2.25 liter engine. I plan to install a 200 td (without intercooler) from an old Disco. The issue is; I put it without the turbo and leave the original gearbox, or leave the turbo and put an R380 with the stock transfer??? my boxes are the original ones and they are in very good condition, but I am afraid that the high torque of the 200td will break the transmission! I have an HD axle on the back that can handle anything. What do you tell me??? that R380 box with serial transfer that is in the photo. On sale ??? Thank you very much! Greetings from Argentina !!! 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 1, 2022 Share Posted March 1, 2022 I vote Turbo + R380 + LT230 or there's not much point in making the change. 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 2, 2022 Share Posted March 2, 2022 It depends. I was happy with my di200. The turbo is better, though. Â Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 2, 2022 Share Posted March 2, 2022 I ran a V8 and later a 200tdi over 20 years on the same series box with no issues regards Stephen Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 5, 2022 Share Posted March 5, 2022 As long as you are not usually brutal with the clutch, a Series transmission copes fine behind a Tdi. Â Changing the oil every 15-20,000 km will help, and frequent level checks are important unless you know it is not leaking (especially into the transfer box, as is common). A stumpy R380 and LT230 is not necessary and is a lot of work, but the results would be better and you would have more confidence in driving hard. Â You would need 3.54 diffs to go with it. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 6, 2022 Share Posted March 6, 2022 On 3/5/2022 at 7:08 AM, Snagger said: You would need 3.54 diffs to go with it. If you used a higher-geared LT230 you could keep the Series diffs and have a very low low-range. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 6, 2022 Share Posted March 6, 2022 I have a 200 td with a series gearbox and it’s seems to be happy enough. I do drive like a grandma though. I also enjoy the series gearbox - it seems part of the experience.   Google translate:  Tengo un 200 td con caja de cambios de serie y parece bastante feliz. Sin embargo, conduzco como una abuela. También disfruto de la caja de cambios de serie, parece parte de la experiencia. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 7, 2022 Share Posted March 7, 2022 I enjoy not having a Series gearbox - all the beans are fully available 1 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 9, 2022 Share Posted March 9, 2022 In essence the only things you do like about your series are the chassis and the body work? 1 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 9, 2022 Share Posted March 9, 2022 10 hours ago, Gazzar said: In essence the only things you do like about your series are the chassis and the body work? Look, if you can't appreciate a classic restoration I'm just going to ignore you 1 Quote Link to comment Share on other sites More sharing options...
