fozsug Posted September 19, 2011 Share Posted September 19, 2011 Just got sent some info from a new manufacturer of windows for Horseboxes, and i happened to see that they do Panoramic either fixed or sliding windows for LR, and some other bits as well http://www.masai-lan...product=3524353 Quote Link to comment Share on other sites More sharing options...
pat_pending Posted September 19, 2011 Share Posted September 19, 2011 Saw these at Peterborough show last year. They appear to be sheets of toughened glass bonded to the sides, apart from looking fugly, I wonder how they'll cope with the body flex on a Land Rover used off road. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 19, 2011 Share Posted September 19, 2011 I heard they were £££££'s too, a mate has bought some though so I'll see if I can have a nose round them sometime. Nice idea visibility-wise I have to say, and could look quite smart if that 90 was black rather than white. Quote Link to comment Share on other sites More sharing options...
western Posted September 19, 2011 Share Posted September 19, 2011 the rear pane still slides open,it's slightly recessed so not as smooth as they look from a distance, the body opening looks about the same size as standard windows, so they don't look much of a gain in see through area. Quote Link to comment Share on other sites More sharing options...
Steve King Posted September 19, 2011 Share Posted September 19, 2011 Ugly, just plain ugly. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 20, 2011 Share Posted September 20, 2011 Not to my taste, no more visibility (as far as I can see in the pictures) than a standard window and a far greater area vulnerable to breakage than standard windows. IMHO they might suit the same people who would add a body kit to a Vauxhall Nova just to be different. Chris Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted September 20, 2011 Share Posted September 20, 2011 the rear pane still slides open,it's slightly recessed so not as smooth as they look from a distance, the body opening looks about the same size as standard windows, so they don't look much of a gain in see through area. You can have them as a non opening window too Ralph. They might suit some people but they aren't what I want for my 110, each to their own.... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 20, 2011 Share Posted September 20, 2011 You hardly gain any visibility... the only gain is the thickness of the old window frame. For me the only think I think they would look any good on or be of any use is a road going black defender. Quote Link to comment Share on other sites More sharing options...
C18RCH Posted September 20, 2011 Share Posted September 20, 2011 It makes the defender look like a modern block of flats Quote Link to comment Share on other sites More sharing options...
Daan Posted September 20, 2011 Share Posted September 20, 2011 Uh? No good for bashing trees... Use perspex for side windows, at least it bends back when you lean against a tree, plus saving about 3kg. Daan Quote Link to comment Share on other sites More sharing options...
Guest Posted September 20, 2011 Share Posted September 20, 2011 I looked at these a while ago when they first came out, I was looking at putting lockers in the rear sides and replacing the windows, basically you remove your existing windows/frames and bond/stick these to the outside of your truck!! I went on to ask about how safe they were breakages etc, the only answer I got back was that you were no more likely to brake them than a standard window, I then said well surely you have more chance of breaking them as there is a bigger surface area and exposed edges which is always the weak point on a laminated window. His answer was that if you used your land rover for off-roading then this may not be the product for you!!! Jason. Quote Link to comment Share on other sites More sharing options...
missingsid Posted September 21, 2011 Share Posted September 21, 2011 My ex boss has these on this black 90 and no he does not use it off road. Marc. Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted September 21, 2011 Share Posted September 21, 2011 My ex boss has these on this black 90 and no he does not use it off road. Marc. Any chance of you taking a picture still? Quote Link to comment Share on other sites More sharing options...
fozsug Posted September 22, 2011 Author Share Posted September 22, 2011 Quote Link to comment Share on other sites More sharing options...
Tufty Posted September 22, 2011 Share Posted September 22, 2011 For me, they almost exactly fail to please the eye. No, scrub the 'almost' part. Yuk! Quote Link to comment Share on other sites More sharing options...
Steve King Posted September 22, 2011 Share Posted September 22, 2011 Bling and not at all practical off road (or even laning with overgrown trees!!) Quote Link to comment Share on other sites More sharing options...
Guest Posted September 22, 2011 Share Posted September 22, 2011 Although you have to admit that with panel gaps like that it could be a OEM Land Rover part!! Quote Link to comment Share on other sites More sharing options...
task Posted September 23, 2011 Share Posted September 23, 2011 The white 90 reminds me of the girlfriends iPhone. Quote Link to comment Share on other sites More sharing options...
GL88 Posted September 24, 2011 Share Posted September 24, 2011 Saw these on a silver D90 in Wells earlier this week. I think that they would be fine on a black one but look a bit odd on any other colour (and you'd need to tint the glass in the rear door). Quote Link to comment Share on other sites More sharing options...
