Diablo Posted November 10, 2011 Share Posted November 10, 2011 I drove a puma recently and found it as rattly as my 200tdi! It was a bit quieter at motorway speeds though. Has it got much soundproofing? Might be something to play with before going down the engine change route.... I crawled under one at the local dealer's not long ago and all I can say is no, it doesn't! Don't know what spec it was though. Just had carpets and some thin vinyl in footwells. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 10, 2011 Share Posted November 10, 2011 Why ?? I can maybe understand the R380, but why change from 200tdi into 300tdi ? Maybe I must read the thread back again, and see if there are som valid reasons. I love my 200tdi. Indeed why ? No perceptible increase in performance or reliability. I'm puzzled ! Mo Quote Link to comment Share on other sites More sharing options...
nidge Posted November 11, 2011 Author Share Posted November 11, 2011 Well Mo and Finn, its like this the truck was rebuilt with Td5 seat box and 300 bulkhead so needs R 380 to finish Gearbox tunnel etc. I also find this particular 200tdi very noisy, especially on tick over, I drive a 300tdi 90 at the moment and there is a big difference between the 2. I just keep saying to myself the 110 would be a lovely car with R380 and 300 ....... but you got me thinking tho, as I am aware of the durability of the 200 over the 300 . Thanks for imput fellas all helps to making the right decision in the end Nidge. Quote Link to comment Share on other sites More sharing options...
finnarne Posted November 11, 2011 Share Posted November 11, 2011 What kind of noise ? Mine got a bit more silent when I added a litre of 2-stroke oil. "Tick over" is when the engine is idling, right ? Quote Link to comment Share on other sites More sharing options...
discomikey Posted November 11, 2011 Share Posted November 11, 2011 i would never choose 300 over 200. for some reason to me 300s seem more lazy and tend to smoke more when cold. why not mate the 200 to a R380? Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted November 11, 2011 Share Posted November 11, 2011 up the tickover speed a bit, fit a wright offroad urethane seatbox cover thingy and stick in a short bellhousing r380. the ultimate 110 Quote Link to comment Share on other sites More sharing options...
nidge Posted November 12, 2011 Author Share Posted November 12, 2011 up the tickover speed a bit, fit a wright offroad urethane seatbox cover thingy and stick in a short bellhousing r380. the ultimate 110 Yes have I upped the tick over speed and ordered a set of genuine engine mounts, also priced up a R380 stumpy and according to Ashcrofts I can use the r 380 gear box tunnel cover !! Heading towards keeping the 200 now and r380 box. Nidge Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted November 12, 2011 Share Posted November 12, 2011 good man! now post some pics up when you've got the ST Max's fitted!!!! Quote Link to comment Share on other sites More sharing options...
Smego Posted November 13, 2011 Share Posted November 13, 2011 What kind of noise ? Mine got a bit more silent when I added a litre of 2-stroke oil. "Tick over" is when the engine is idling, right ? What does that do? If it safe to do it - assume it is? Quote Link to comment Share on other sites More sharing options...
finnarne Posted November 13, 2011 Share Posted November 13, 2011 I think it lubricates the valves. The engine runs smoother. I think there is a thread on the Norwagian forum about it, I've nevere heard anything harmfull about using two-stroke oil. Now I'm using a bit of two-stroke oil together with kerosene (My neighbor found a barrel with some kerosene while clearing out his basement...) I also run the engine on a mixture of wvo and petrol sometimes. I think maybe the 200tdi takes a bout anything I give it. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted November 13, 2011 Share Posted November 13, 2011 2stroke oil replaces the sulphur thats removed from diesel nowadays-its mainly used to provide lubricant to the FIP and injectors on common rail high pressure injection engines. quite a bit on south African 4x4 forums about it as they have very low levels of sulphur plus bad quality fuels Quote Link to comment Share on other sites More sharing options...
tango90 Posted November 13, 2011 Share Posted November 13, 2011 Hi Nidge, I drove a 200tdi 90 as a daily drive the only thing I did was put a higher ratio transfer box from an auto RR and tweeked the pump slightly and it made it very quiet several people driving 300's actually commented it was the quietest LR they ever traveled in. Quote Link to comment Share on other sites More sharing options...
simkin Posted November 13, 2011 Share Posted November 13, 2011 I've had my 110 200tdi for about 6 months now and it is pretty standard factory with the only upgrades being the lower door ventilation kit. You know, the one where mother nature creates naturally aspirated ventilation through the combination of steel and rainwater. I am interested in the talk of intercooler upgrades as I seem to be on the motorway a bit more often at the moment than I was expecting. Can somebody point out a thread that goes over the options? Or should it be a case of getting the sound-proofing and fitting an overdrive as the first things to do before any tweaking? Sound-proofing will have to wait until I've managed to stop the passenger footwell becoming a swamp when it rains mind.... Quote Link to comment Share on other sites More sharing options...
landy V8 Posted November 13, 2011 Share Posted November 13, 2011 i upgraded my 200 with an uprated RS500 cooler.did a write up on here.together with the fueling tweeks has made a fair difference on the drivability. you should find it in the Defender section.it's even got pictures Quote Link to comment Share on other sites More sharing options...
Smego Posted November 14, 2011 Share Posted November 14, 2011 assume you just put the 2-stroke in a tank if derv, how often do you do it? Quote Link to comment Share on other sites More sharing options...
finnarne Posted November 14, 2011 Share Posted November 14, 2011 not sure what "if derv" means, but I've added ~2 litres of 2stroke oil, and have driven maybe 110-120000 km since I got the car. almost 3 years ago. Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2011 Share Posted November 14, 2011 "if derv" means derv = diesel engined road vehicle Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 14, 2011 Share Posted November 14, 2011 I've added ~2 litres of 2stroke oil Per tank? I wonder what the result would be over here if VOSA dipped the tank with 2 stroke oil added? (its clearly allowed in 3 stroke engines, but is it allowed as an additive to other fuels and would they notice at that concentration?) Quote Link to comment Share on other sites More sharing options...
finnarne Posted November 14, 2011 Share Posted November 14, 2011 No, in total. I've added a bit more now when I use kerosene, but I've soon used all of it. Then I guess I'll go back to normal. that is 2 litres 2stroke with 10000 litres of diesel. Or maybe a bit more. I think've read something about up to 0.1 l per 80 litres. Quote Link to comment Share on other sites More sharing options...
Smego Posted November 20, 2011 Share Posted November 20, 2011 derv = diesel engined road vehicle Haha you have4 been using google :-p It can mean ^^ that but really means derivitive in the fuel industry as in diesel is a derivitive of prossesing crude oil to get petrol http://bikeadvice.in/insight-petrol-liquid-gold/ Quote Link to comment Share on other sites More sharing options...
