highlandmist Posted July 13, 2012 Share Posted July 13, 2012 I bought a breather set from this guy who looked kosha, I wanted to fit it this weekend as my rear axle breather is still underneath the vehicle. Unfortunately it never arrived and there has been no reply to my attempted contact. I have had to open a dispute and I'm now looking for a REAL kosha seller for my breather extension Here's the guys page as I couldn't list the item as it had ended with 10 to sell and 2 sold. http://myworld.ebay.co.uk/breathers-r-us/?_trksid=p4340.l2559 Quote Link to comment Share on other sites More sharing options...
sean f Posted July 13, 2012 Share Posted July 13, 2012 To be honest I wouldn't by a kit. The axles are tapped 1/8BSPT, buy a couple of pneumatic fittings, push fit swival 90deg elbows are best in 6mm pipe size, a roll of 6mm pipe in what ever colour you fancy and make it up yourself. A 2 into 1 fitting will allow you to join the breathers together if you wish. Picking up the gearbox and transfer cased breathers, you can either buy more screw in fittings or a 6mm to 6mm joiner and join onto the existing pipe. A 10m roll of pipe will do the entire vehicle easily with enough left over to replace any bits in the future if you damage them. All this stuff is available on ebay or various pneumatics online stores at pretty cheap prices. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted July 13, 2012 Share Posted July 13, 2012 yep, same here I bought half a dozen 90 fittings for 50p each (they're lasting well!) and roll or 6mm pipe (maybe 10m or so). I think it cost me less than £15. I don't know how places can sell a 'kit' for twice the price! Steve Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 14, 2012 Share Posted July 14, 2012 To be honest I wouldn't by a kit. The axles are tapped 1/8BSPT, buy a couple of pneumatic fittings, push fit swival 90deg elbows are best in 6mm pipe size, a roll of 6mm pipe in what ever colour you fancy and make it up yourself. A 2 into 1 fitting will allow you to join the breathers together if you wish. Picking up the gearbox and transfer cased breathers, you can either buy more screw in fittings or a 6mm to 6mm joiner and join onto the existing pipe. A 10m roll of pipe will do the entire vehicle easily with enough left over to replace any bits in the future if you damage them. All this stuff is available on ebay or various pneumatics online stores at pretty cheap prices. The axle threads are standard BSP, not Tapered bsp.. hence the copper washers. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted July 14, 2012 Share Posted July 14, 2012 I know you can make your own but sometimes its nice not to have to source all the bits for a kit its nice just to buy one and done with..or not in your case If its any help I have just bought a kit from these people and they were fine http://www.ebay.co.uk/itm/370627997150?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1998wt_982 I hope you get sorted out James Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted July 14, 2012 Share Posted July 14, 2012 I have got parts of R+C also with no problems what so ever. Quote Link to comment Share on other sites More sharing options...
sammyb Posted July 14, 2012 Share Posted July 14, 2012 had trhe same problem with the same seller Quote Link to comment Share on other sites More sharing options...
highlandmist Posted July 14, 2012 Author Share Posted July 14, 2012 had trhe same problem with the same seller Recently ? Are you the other one of the two that sold ? Quote Link to comment Share on other sites More sharing options...
highlandmist Posted July 14, 2012 Author Share Posted July 14, 2012 The axle threads are standard BSP, not Tapered bsp.. hence the copper washers. Looking for parts now, need an elbow or two, the tubing and a y piece connector, so is it BSP and do I need a copper washer too ? Gonna try this guy: http://stores.ebay.co.uk/cpmpneumatics/All-Pipes-Tubing-/_i.html?_fsub=2013795011&_sid=936810161&_trksid=p4634.c0.m322 Quote Link to comment Share on other sites More sharing options...
Sirocco Posted July 14, 2012 Share Posted July 14, 2012 I may have some bits in the garage. will have a look tomorrow. I know I have 1/2 a reel of hose. Let me know if you still need anything. G Quote Link to comment Share on other sites More sharing options...
sean f Posted July 14, 2012 Share Posted July 14, 2012 The axle threads are standard BSP, not Tapered bsp.. hence the copper washers. Correct but when it come to breathers it doesn't really make that much difference, a bit of tape or paint around the fitting will provide all the seal needed. If the system contained pressure it would be a different matter, I have a collection of pipe work and fittings all of this type about 2ft away from me right now which contain variously, compressed dry air at 120psi, vacuum, hydrogen at 50psi and mixed hydrocarbon gasses or H2S at variable concentrations in air (currently about 1.5% methane). Clever bugger award goes to who ever can work out what that lot goes to and why, all sat in a pressurised office container in the middle of the north sea. Quote Link to comment Share on other sites More sharing options...
PieEater3142 Posted July 15, 2012 Share Posted July 15, 2012 I found a 5 way version of one of these on ebay (can't find it now) http://www.ebay.co.uk/itm/Land-Rover-HD-Breather-Wading-Kit-90-110-Defender-Range-Rover-Discovery-/280887975224?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D612240837339694118%26pid%3D100033%26prg%3D1011%26rk%3D2%26#ht_1363wt_1165 But its metal and screws in, the pipe pushes and locks in on rubber grommets. Knowing what I know now, I really need another 2 breathers anyway. (high pressure fuel (injector) pump, pas fluid resivoir (different cap for bottle) Sure there's another i've forgotten. But 2 of these wouldn't be a bad shout if you really want to do EVERYTHING. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted July 15, 2012 Share Posted July 15, 2012 Clever bugger award goes to who ever can work out what that lot goes to and why, all sat in a pressurised office container in the middle of the north sea. 120psi will be the rig air. Pressurised cabin means Service Co. Sounds like Gas Chromatograph... I'd say possibly Mud Logger or GC Tracer Eng? Quote Link to comment Share on other sites More sharing options...
sean f Posted July 15, 2012 Share Posted July 15, 2012 120psi will be the rig air. Pressurised cabin means Service Co. Sounds like Gas Chromatograph... I'd say possibly Mud Logger or GC Tracer Eng? Correct, Gas Chromatograph and total gas detector combined. Not actually the mudlogger myself although I did that for 10 years, now doing well bore stability and vibration management stuff but based out in the combined mudlogging and MWD unit. Quote Link to comment Share on other sites More sharing options...
Dave W Posted July 15, 2012 Share Posted July 15, 2012 I found a 5 way version of one of these on ebay (can't find it now) http://www.ebay.co.u...#ht_1363wt_1165 But its metal and screws in, the pipe pushes and locks in on rubber grommets. Knowing what I know now, I really need another 2 breathers anyway. (high pressure fuel (injector) pump, pas fluid resivoir (different cap for bottle) Sure there's another i've forgotten. But 2 of these wouldn't be a bad shout if you really want to do EVERYTHING. I really would think twice about connecting breathers together, even more so when the breathers are for items with different fluids. When a gearbox/transfer box/axle component overheats it's not unusual for the oil to be thrown out of the breather. Joining them together not only causes potential problems with cross contamination but also makes it difficult to identify the cause of the problem. Quote Link to comment Share on other sites More sharing options...
sammyb Posted July 16, 2012 Share Posted July 16, 2012 Recently ? Are you the other one of the two that sold ? aye man thats me, takes the proverbial TBH doesnt live far away either, might have to make a wee visit there Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted July 16, 2012 Share Posted July 16, 2012 sorry to be the one to point out the obvious but the guy only has 97.8% feedback and in the last month has had 11 negative for mostly no goods shipped, after being conned a couple of times when i first started using ebay i started reviewing the sellers before buying, a nuicanse yes but gives you piece of mind that your buying from someone reputable. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 16, 2012 Share Posted July 16, 2012 In fairness the majority of bad feedback came in the last 5 days so in this case you would have only seen 1 negative feedback when purchasing (assuming purchasing was over 5 days ago which is most likely). It may be a supplier issue, illness, or something else. Bad form to not reply to messages but if he has died or been flooded out of his house he's probably not too bothered about his feedback, or he may have just turned bad .... I've seen that happen to. There is normally a reason, sometimes it's a good one ... often it isn't Quote Link to comment Share on other sites More sharing options...
sammyb Posted July 16, 2012 Share Posted July 16, 2012 3 weeks ago when i bought them, there was no neg feed back Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 16, 2012 Share Posted July 16, 2012 Paypal are very good at refunding money if the seller can't provide proof of receipt of the parcel. Item not as described problems are harder to resolve. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted July 16, 2012 Share Posted July 16, 2012 I found a 5 way version of one of these on ebay (can't find it now) http://www.ebay.co.u...#ht_1363wt_1165 i just came across this, is this the kind of thing you ment? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 17, 2012 Share Posted July 17, 2012 i just came across this, is this the kind of thing you ment? Lol, that's another listing from the bloke who isn't posting anything out at the moment and is getting all the poor feedback. Quote Link to comment Share on other sites More sharing options...
sean f Posted July 17, 2012 Share Posted July 17, 2012 Since all the bad feedback has happened recently it is possible somethings bad has happened, flooding or illness. I had a purchase a will ago which never arrived, no responce to messages etc when to Ebay / PayPal dispute. Turns out the guy had died, month or so later his widow sent things through and apologised for the delay, I had no reason to disbelieve the story. Not always the case but with every thing happening suddenly after previously good feedback just might be. Not a great deal of help for those loosing out at the moment though!. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted July 17, 2012 Share Posted July 17, 2012 Lol, that's another listing from the bloke who isn't posting anything out at the moment and is getting all the poor feedback. opps. i found this but its more than the complete kit in an earlier comment. Quote Link to comment Share on other sites More sharing options...
highlandmist Posted July 18, 2012 Author Share Posted July 18, 2012 Thanks for the guy who had stuff in his garage and the other who was looking at similar fittings at his work, made me wonder... I ended up getting the stuff from the instrument techs at my work Quote Link to comment Share on other sites More sharing options...
