Frax Posted December 30, 2012 Share Posted December 30, 2012 Hi all I was having some strange noises coming from don’t know where but it only happened after driving for 3 or more miles, I would then get a noise like a scraping fan. Switched the heater on and off but this made no difference at all. Radiator fan off as it electric still no difference. Checked both props as I just replaced them both a few weeks ago. found nothing wrong. Checked all steering rods as these were replaced at the same time with heavy duty ones, still nothing. Next was the wheels - on removing the wheels I found that my brake disks (drilled and grooved) to be blocked - all the holes and the groves with a pasty pooo stuff. This was found to be coming from the pads which seamed to have went soft on the surface. The wear groves in the pads were full of this paste - cleaned it all up on no more noise. I think as he pads or disks heated the noise started - OK when cold. These were recommended but I for one wont buy them again. Has anyone else had any bad experiences with these pads. All the best Frax Don't know why but this has doubled posted. Quote Link to comment Share on other sites More sharing options...
19MART82 Posted December 30, 2012 Share Posted December 30, 2012 i had the greenstuff pads in the rear of my last truck,they wore down unbelievably fast and i found off road they didnt stop so well either,replaced them with ferrodo pads and they were loads better Quote Link to comment Share on other sites More sharing options...
Frax Posted December 30, 2012 Author Share Posted December 30, 2012 Well I was never impressed with the pad performance; they have been in for a year now and still have a lot of meat on them. It might be hard to ware down a sponge... Quote Link to comment Share on other sites More sharing options...
19MART82 Posted December 30, 2012 Share Posted December 30, 2012 ha ha,ive read quite a lot of bad stuff about them as i trawled the internett after mine had worn down,i actually thought my callipers were sticking they wore down that fast,considering they are meant to be better for offroad use i was pretty dissapointed Quote Link to comment Share on other sites More sharing options...
simonr Posted December 30, 2012 Share Posted December 30, 2012 I had a set on the front of my 110 which lasted about 2 months until they were down to the wear indicators. Replaced with EBC which squealed like you wouldnt believe. They were swapped out for genuine which have been great ever since! The problem might well be with drilled vented disks - acting like a cheese grater! Si Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 31, 2012 Share Posted December 31, 2012 I had a set on the front of my 110 which lasted about 2 months until they were down to the wear indicators. Replaced with EBC which squealed like you wouldnt believe. They were swapped out for genuine which have been great ever since!The problem might well be with drilled vented disks - acting like a cheese grater! Si I would be very interested to know who actually made the Genuine pads. Quote Link to comment Share on other sites More sharing options...
muddychris300tdi Posted December 31, 2012 Share Posted December 31, 2012 I had Green stuff pads in the front of my Disco, I went and checked them, had loads of pad left in depth but on one pad half the pad had come away from the backing plate. Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 31, 2012 Share Posted December 31, 2012 I've never had any troubles with the EBC green pads, but that's on vented (not drilled and slotted) disks. Quote Link to comment Share on other sites More sharing options...
Sirocco Posted December 31, 2012 Share Posted December 31, 2012 I would be very interested to know who actually made the Genuine pads. Quote Link to comment Share on other sites More sharing options...
Sirocco Posted December 31, 2012 Share Posted December 31, 2012 What is wrong with LR4x4? It wont show the quotes and now wont let me edit!? Anyway, I was going to say (for the 5th time) Ferrodo make the genuine pads, that is what came in my green box a while back. G Quote Link to comment Share on other sites More sharing options...
rick Posted December 31, 2012 Share Posted December 31, 2012 What is wrong with LR4x4? It wont show the quotes and now wont let me edit!?Anyway, I was going to say (for the 5th time) Ferrodo make the genuine pads, that is what came in my green box a while back. G I wonder how much the compounding differs from the UK/Europe to us in the east ? Our aftermarket Ferodo 4WD pads come out of Thailand Excellent pads but the rears squeal like a Banshee with dust on them, and considering I drive a hell of a lot of gravel that adds up to buckets of unwelcome noise [edit] FWIW one of the engineers at DBA (Disc Brakes Australia ) advised me ten years ago to stay away from EBC. In their testing they found them to be too inconsistent batch to batch, but bear in mind this was ten years ago. His recommendation was Ferodo. Quote Link to comment Share on other sites More sharing options...
danielh110 Posted December 31, 2012 Share Posted December 31, 2012 we have been using ebc green stuff pads with cross drilled and groved disks for quite some time... You MUST break them in following ebc's instructions. The pads do not set until after ther break in sequence. Also make sure you buy them from a reputable sorce as there are fakes out there! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 31, 2012 Share Posted December 31, 2012 I used to get the pads from a guy two doors away from me. He worked in a small factory unit. They made brake pads for different manufacturers. Never had any problem with them For my Defender I just take what ever is in stock at the shop. Quote Link to comment Share on other sites More sharing options...
BIG DAN T Posted December 31, 2012 Share Posted December 31, 2012 I think Landrover must use several brands as genuine because the last two sets I have had were Delphi Lockheed not Ferodo and came in genuine boxes. Quote Link to comment Share on other sites More sharing options...
ELVIS Posted December 31, 2012 Share Posted December 31, 2012 cross drilled/grooved discs kill break pads at a lot quicker rate over OE Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 31, 2012 Share Posted December 31, 2012 I've used Ferodo, Mintex, and AP Lockheed (those were genuine parts) pads on mine and had no issues. But then I have standard discs, no drilling or grooving. No point on a Land Rover in my opinion since A: it's not like it's a fast race car and B: they just fill up with mud etc. off road and this wears your pads down even faster! Quote Link to comment Share on other sites More sharing options...
19MART82 Posted December 31, 2012 Share Posted December 31, 2012 mine were standard solid discs,ive never used vented or grooved, they still wore down at an alarming rate. to answer the question a few posts up the pads were bought from paddocks Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 31, 2012 Share Posted December 31, 2012 My fronts are mintex and are great. The rears are Ferrodo, and they do squeal quite a bit for no apparent reason. Quote Link to comment Share on other sites More sharing options...
Frax Posted December 31, 2012 Author Share Posted December 31, 2012 Well I will have to order a set of mintex for my one. Thanks for the recomendations. The EBC pads did not help the braking even with drilled and groved disks. I did expect them to wear down quicker with this type of disk which I dont mind if they are doing a good job. Frax Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 1, 2013 Share Posted January 1, 2013 My fronts are mintex and are great. The rears are Ferrodo, and they do squeal quite a bit for no apparent reason.Fitted Mintex to the rear of mine and it sounded like I was using some cats to grip the disc with their claws any time I even thought about the brake pedal. Finally got hold of some oem anti squeal shims and it solved the problem .... mostly. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 1, 2013 Share Posted January 1, 2013 You MUST break them in following ebc's instructions. The pads do not set until after ther break in sequence. Now, I didn't know that! They were fitted by someone else and nobody gave any indication they needed breaking in! Do you have more details? Si Quote Link to comment Share on other sites More sharing options...
danielh110 Posted January 1, 2013 Share Posted January 1, 2013 have a look here,http://www.ebcbrakes.com/troubleshooting.shtml Quote Link to comment Share on other sites More sharing options...
19MART82 Posted January 1, 2013 Share Posted January 1, 2013 all brake pads whatever brand should be bedded in,normally its cycling 10-20 harsh stops to build up the heat without overheating the discs and pads to bed them and thats what i allways do including with the green stuff pads, in the link above is showing 300-400mile to bed the green stuffs in???? i seriously joking aside dont think i even got that milage out of the pads! i was recommended the green stuff pads as i was told they were better for offroad use but where are you going to fit that many road miles in a offroader? i do know the green stuff pads come in different grades so maybe i was supplied the wrong grade? but there is a lot of bad reviews about them if you do a google search Quote Link to comment Share on other sites More sharing options...
cackshifter Posted January 1, 2013 Share Posted January 1, 2013 I have greenstuff 6000 on 2 defenders, pads were conditioned as per ebc guide, and have no issues. Enough bite to lock wheels. Much less squeaky than previous Mintex, just an occasional squeal first time the brakes are used after being stood for while. And they seem to give off very little dust.But they are dearer than others. Which grade of Ferodo do people use? Quote Link to comment Share on other sites More sharing options...
bluespanner Posted January 1, 2013 Share Posted January 1, 2013 Why anybody would fit drilled or grooved discs to a land rover is beyond me. As I understood it, it was the EBC Red or yellow pads that were worth having, and that the green ones were designed for less brake dust for the shiny alloy wheel brigade. Quote Link to comment Share on other sites More sharing options...
