Storage for Nuts & Washers?
What are people using for storing/organising nuts/washers etc? I'm going to be doing a bulk order soon for the rebuild.
I don't want to use open bins (linbin type) as they collect grinding dust other stuff, either looking at using cases, or wall mounted organisers.
What are you using? does it work?
Those plastic boxes with compartments are next to bloody useless
( step on them and they shatter. I've got some soft plastic tackle boxes (came with a fishingg tackle bag....) that almost do the job, but next time I get paid (bloody weather) I will be buying something like this:
http://www.ebay.co.uk/itm/Clarke-CTB1000-36-Drawer-Parts-Cabinets-Metal-Tool-Storage-Draw-Unit-Parts-Bin-/310830399149?pt=UK_Garage_Equipment_Tools_Tool_Boxes_Storage&hash=item485eef7ead
I have the same problem, currently I store them in some of the drawers in my bottom box, it's neat and tidy and easy to get at everything but it's an expensive storage solution
4C067BA1-31DF-4930-9697-3719B60B4A09_zps
My intention is to build a shallow cupboard with a louvred panel on the back internal face and on the inside of both doors which I would hook the linbins to. I don't like the idea of those metal drawer sets Jeff linked to, they seem to promote condensation and you end up with rusty fasteners (and drawers).
If you are gonna mount anything to a wall be aware that when you start to fill it it's gonna get heavy fast, make sure your mountings are sufficient
These rack and bin sets seem good value
http://bit.ly/YVnkes
I use glass jars, you know the ones you buy when you buy your groceries, gurkens, beet root, or similar. I nail the lid from the inside to a wooden shelf or self tapper screws in a triangular format. So it's just a twist to remove or replace and it's see through easy to spot what you are after.
Put a couple of kitchen cupboard runners and drawer in the bottom of one of your cupboards, fill with appropriate sized bins and nuts/bolts. Plonk a shelf on top and you won't lose much space at all.
I use http://www.ebay.co.uk/itm/Stanley-25-compartment-organiser-/321345976258?pt=UK_Garage_Equipment_Tools_Tool_Boxes_Storage&hash=item4ad1b677c2
You can take them to where you are working.
You can label above each compartment you make with the contents
The compartments are adjustbale
I've got something very similar myself-sits on the bottom shelf of my two four tier shelves at the back of my garage
John
I'd be interested to see what you decide to do on this one, I'm looking at doing something similar but have run out of space on the walls.
The current plan is to make a large draw that slides in under the top of the workbench, then throw a load of linbins into it so they can be removed and carried around if required.
Whats wrong with emptying them all into a couple of old Quality Steet tins or similar, in time honoured fashion :ph34r:
i remember my dad doing this when I was a kid in the Sixties...................Oh the swearing :rofl:
Yup.... Wickes do an own brand version - prettymuch identical.
I have 3 for various fixings. Theyre great and for less than a tenner cant go wrong.
http://www.wickes.co.uk/content/ebiz/wickes/invt/168023/25-Compartment-Organiser_large.jpg
http://www.wickes.co.uk/invt/168023
I went for one of these in the end as I was ordering some other bits from amazon.
http://www.amazon.co.uk/gp/product/B0001JZYAG/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
Draws are the softer kind of plastic so look like they will take any knocks. Got it stood at one end of the bench so I can move it if it gets in the way.
I custom ordered my M4 - M20 4 box selection (came out to about 2000 parts as got multiple lengths spaced about every 20mm - I hate cutting bolts down)
The number of each was based on size and expected quantity of use from www.orbitalfasteners.co.uk
