Steve200TDi's New Racer!!
  • 1 month later...
I may not of touched the racer in lockdown, but I certainly have been thinking and dreaming about what I'm going to be doing once I can get over there!
@msb_axo sent over two defender td5 wiper boxes and arms. So along with the one that @GBMUD has been keeping safe, I have a full set to swap out! I saw swap out, it will involve some cutting, grinding and welding, but thats ok, I'm yearning for a bit of that!
I just need some nuts to hold the wiper arms on!
Regarding gearing, I have a 1.6 transfer box to fit, but I'm still reluctant as a borg warner is much nicer for racing. I would also need to make new mounts for it and fit new propshafts as they are slightly different lengths.
I've know for a while that Tomcat Motorsport make a smaller gear for the borg warner to change it from 1.2 to 1.38, but they are either unobtainable or a special order.
I heard on the grape vine a couple of weeks ago that there maybe 3 gears up for grabs.....
So this landed on the mat the other day!
So that's another job to add to the list!
The existing chain is shortened by a couple of links and then tig welded back together.
Steve
  • Like 1
Very nice find!
Last I heard they were getting on for £1k for a set....
But you are right, the BW is a good box, and unlike the LT230 doesn't insist on sprinkling the ground wherever you park it.
  • Like 1
  • 2 weeks later...
I found this on ebay:
https://www.ebay.co.uk/itm/Land-Rover-kit-Car-Arttcar-Gear-Shifter/283709093725?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
I've asked for a few more photos, but it could be a candidate for a new shift for the racer. I can't quite see the shift gate pattern, so am waiting on some photos.
Steve
Steve
P R N 3 2 1
It was more the gate layout, so i could shift without going into reverse or neutral accidently.
But yes, thanks Mike for the order, it appears not to have D and so depending on how it is built I don't know if it can be modified and whether it has the shift cable with it....
Steve
Steve
i know you can get the gate plates seperatley / make your own, i would assume in your instance that a P R N 4 3 2 1 would be a better option as 4 would become D
i think thats what WSR are doing with there kit
http://www.wsroffroad.com/gb/gear-box/25-shifter-wsr-for-autobox-land-rover-zf4hp.html?search_query=shifter&results=1
  • 2 weeks later...
Yes, I've seen that one a couple of times.
So I bought it!
Looks better in the flesh, as it has come with the cable! It has quite a bit of aluminium corrosion, but that can be sorted easily by some wiring brushing and painting.
The gate plates are available to buy (in america) seperately depending on your gearbox layout, but I'll be making my own. So I've measured from P to 3 (on this shifter) the length the cable moves, so I have the distance or span. I can then work out the length of the shift linkage needs to be on my gearbox.
Lets brake out my new level/angle gauge!
So starting from P and recording the angle of every position finishing at 3, I was able to working out the length of linkage I needed! 71.54mm long, across 60 degrees.
The end of the cable has a quick release ball joint linkage, so I;ll clean this up and hopefully use it or I may opt for a rose joint.
This is as far as I've got. I will need to do some more maths to make the gate plate for the shifter and also decide what gate I'm having!
Steve
  • Like 1
I had a quick play on solid works today. Using the dimensions from the gearbox and shifter, I've come up with a new shifter plate.
I'll probably print a cardboard copy and fit it all to the gearbox to check shift points etc before either getting it laser cut or I'll get the drill and file out!
Steve
On 6/24/2020 at 9:42 PM, Bowie69 said:
Nice :)
Also, have the same level ;)
15 hours ago, landroversforever said:
As do I! Level friends!
Shame it doesn't do 'the' beep :(
Yes! I think we had a level discussion on another thread about what level to get!
Was that a level-headed discussion about which level to level at the problem of levelling LR components?
  • Haha 1
I have 1:1 scale drawings to offer up to the gearbox and shifter. The gearbox linkage is just a guess regarding raduis, but the gate plate should hopefully be close as I've done a lot of measuring and calculating to produce that drawing!
Oh yes........and good old Windows 98! :D
Steve
My work PC runs Linux Mint and half the time I've got Mint in one monitor, Windows WM in another and Ubuntu VM in the 3rd :lol: and yes I do need a 4th monitor...
There's a few wrinkles to cloning XP / Vista / Win7 machines if anyone needs the info I've got it wrote down somewhere... :ph34r:
