Defender Heaters?
  • Please log in to reply
16 replies to this topic
#1 Unsworth
Unsworth
    Member
  • Settled In
  • PipPip
  • 169 posts
Posted 27 November 2009 - 12:43 AM
Hi all..
After bang on 12 months of ownership of my 1988 90 (Driving it daily through wind, snow, rain and summer) I have realised how much you can take a modern cars heater for granted!. I have to drive with the window down most of the time but also my heater doesnt work at all
When I give power to my heaters motor it doesnt work any more (It simply does nothing yet gives out a little amount of smoke). To test it I used a set of jump leads and a battery
So a few questions..
- Are all Defender heaters universal to eachother?, Would a TD5 heater fit into a 1988 90 and vice versa?.
- I plan to wire it up to a toggle switch to the maximum speed as the dash control isnt reliable either. But I plan to use the hot-cold knob and the direction knob when I took the engine out I disconnected the two cables to the heater box so how do I find out which one is which?
- Did heaters ever improve through the years?. So would a 300tdi or TD5 one be better than a "Ninetys"?
- What modifications can be done to a standard heater to make it function better?
- Is there a wiring diagramme or a diagramme of where everything should go such as operating cables and wires?
I just want a heater which works as I do not want to have to de-ice the inside of the windows whilst I am driving like last year. I just want it so I can flick a toggle switch and the heater blows on full and I can change the direction of the air flow!
Sorry for all the stupid questions but I cannot go another winter in my ninety without being comfortable!
1973 S3 88 - Being rebuilt on a new chassis (Full restoration job)
1969 2a 88 - My Red pickup series, Rebuilt and my first road worthy land rover
1982 S3 109 - Nackered and getting used as a donor for spares
1988 D90 CSW - Daily drive, Converted to 200Tdi, Re-sprayed Yellow and much more!
#2 mad_pete
mad_pete
    Old Hand
  • Supporters
  • 599 posts
Posted 27 November 2009 - 12:56 AM
I think you can get an uprated heater matrix for better heat transfer and maybe wider output vents to help on the windscreen.
I think the cable that runs to the top does flips the flap that does hot and cold and the other one does feet or windshield which should run to the middle of the lower part of the dash I think.
Parts manual shows 4 different parts for the box. Whether that means they don't fit or they are just different I don't know.
#3 oakesy
oakesy
    Member
  • Settled In
  • PipPip
  • 170 posts
Posted 27 November 2009 - 01:01 AM
In short answer for the heater is no but with a caveat. You will find in the archive section on how to check and readjust the cables to gain maximum heat. To alternatives to kenworth engine heater or the internal espacher route. I on the other hand have a v8 which heats up quicker than the diesel models.
Ðonc for eower ærende.
Glæd Tid fram john n oakes.
#4 Eightpot
Eightpot
    Old Hand
  • Settled In
  • PipPipPip
  • 1,141 posts
Posted 27 November 2009 - 10:05 AM
I have to say that the heater in my 1988 soft top 90 is more than adequate and heats up the interior nicely. A couple of years ago we drove through the length of France in December and it was below -8c outside - the heater gave out enough heat, trouble is ice cold air attacked us through all the door gaps and holes dotted about! It got so cold that we had to gaffer tape the inside edges of the doors up and put rolled up towels round gaps in the hood to stop the needle sharp air getting in! The heater was decent enough though and once the draights were sorted we were fairly toasty.
Maybe just get yourself a motor off ebay, flush your matrix out and spend an hour sorting the cables out?
#5 markyboy
markyboy
    Old Hand
  • Settled In
  • PipPipPip
  • 336 posts
Posted 27 November 2009 - 10:07 AM
Hi all..
Western is the man for this one.
he has done a post which describes how to set the heater controls up. Have you done a search in the tech archive?
Mark.
1992 200Tdi 90
#6 mickeyw
mickeyw
    Petrol Head
  • Long Term Supporters
  • 2,864 posts
Posted 27 November 2009 - 11:14 AM
Best heater upgrade I know is to run a V8. Never any shortage of heat with that :lol:
Michael
1986 Ninety 3.9 EFI Auto LPG 'Jolted' | 1990 Range Rover Vogue SE Auto LPG | 1986 One-Ten CSW V8 LPG
#7 nicks90
nicks90
    Old Hand
  • Settled In
  • PipPipPip
  • 1,456 posts
Posted 27 November 2009 - 12:30 PM
Its that time of year again :ph34r:
maybe a mod could temporarily put a couple of the relevant tech threads as stickies at the top of this forum?
WWW.YORKSHIREOFFROADCLUB.NET
Familly friendly 4x4 club. Monthly RTVs, nav scatter, clubman challenges and pub meets.
#8 HPLP
HPLP
    Old Hand
  • Settled In
  • PipPipPip
  • 239 posts
  • Location:Origionally Ireland/UK presently on the road.....based in Cirencester Glos atm
Posted 27 November 2009 - 04:40 PM
Hiya,
Im my experience the heater itself is fine just a few other things need to be sorted before you can get the full benefit from it.
Firstly, Id attack every little draught, door seals, holes in seatbox etc and then secondly, id strip the bulkhead back to be sure that you are getting every bit of warm air thats coming from the heater matrix. In the 2 defenders ive owned, the ducting is usually leaking so with some work and tape to seal where they change or meet a junction, you can get them to work soooooooo much better.
The alturnative is to just fit an aux diesel/petrol heater.
Hope that helps,
H
#9 JasonG4110
JasonG4110
    Sankey Trailer expert!!
  • 2,349 posts
Posted 27 November 2009 - 05:53 PM
I would recomend aslo fitting an air scoop on the heater intake looks like a gymmic but really makes a diffrence espicialy on motorway journeys I find myself having to turn down the heater!!
If brute force, tie wraps or duck tape won't solve your problems, then you aren't using enough!!
2010 Freelander 2, 2003 110 G4 LE,
#10 reb78
reb78
    Old Hand
  • Supporters
  • 3,693 posts
Posted 27 November 2009 - 06:25 PM
I found mine made no difference at all apart from perhaps a little extra noise! Does help keep rain and muck out to an extent when stationary though.
Richard
1989 110 - Defender 200tdi (ex 19J), LT77s, LT230 (from a TD5) & GKN overdrive
2004 D2 TD5 Landmark
#11 defender dave
defender dave
    Member
  • Settled In
  • PipPip
  • 82 posts
Posted 27 November 2009 - 07:03 PM
hi all one thing you can try is moving the fan blades as in the summer you don't use the heater and the fan can seez up as mine did . it just blow a fuse every time i switched it on. what i did was turned the fan by hand a few times to unseez it the it ran fine after that. hope that might help
#12 RustyNissanPrairie
RustyNissanPrairie
    Old Hand
  • Settled In
  • PipPipPip
  • 543 posts
Posted 28 November 2009 - 11:27 AM
on some LR engines there is a choice of thermostats-i know on my 2.5na there's a 70-odd degree stat and an 80-odd optional one. I use the 70odd one in summer to help keep the engine temp down as I never have the viscous fan fitted and swop over to the 80odd one in winter for increased heating
#13 sas pinkie
sas pinkie
    Member
  • Settled In
  • PipPip
  • 115 posts
Posted 28 November 2009 - 03:08 PM
YOu may well find the motor is nearly siezed. I had one where the hole in the bottom of the air intake that allows the water to flow out had become blocked with rubish, meaning that the rain water started to fill up the air itake. This meant my motor was sat in water and gone rusty , causing it to nearly sieze solid.
Later heaters are better, a Td5 heater has a larger matrix, but will fit, you may just have to fiddle with the heater pipes, as one comes out the side, the other then has a 90 degree turn.
My wolfs heater is superb, my girlfreind feels the cold easily, yet she is always telling me to turn the heater down in it.
#14 q-rover
q-rover
    Old Hand
  • Settled In
  • PipPipPip
  • 1,518 posts
Posted 30 November 2009 - 09:00 AM
Why not fit a proper heater?
From here (in norwegian)
Posted Image
Posted Image
Posted Image
Zephyr 3D not a plug and play, but most likely better. ;)
No matter how much you push the envelope, it'll still be stationery.
#15 Red90
Red90
    Old Hand
  • Settled In
  • PipPipPip
  • 1,794 posts
Posted 30 November 2009 - 04:49 PM
Now, THAT is interesting. 3840 Watt should be much bigger than stock and it seems to fit.
#16 Red90
Red90
    Old Hand
  • Settled In
  • PipPipPip
  • 1,794 posts
Posted 04 December 2009 - 08:26 PM
I found this one: http://www.summitrac...05/?image=large
Posted Image
They claim 8200 Watts and 440 m3/h..... with the same dimensions. Might have to try it.
#17 Red90
Red90
    Old Hand
  • Settled In
  • PipPipPip
  • 1,794 posts
Posted 04 December 2009 - 08:39 PM
Some non LR installs:
http://www.ffcobra.c...ad.php?t=232881
http://www.jeepsunli...ad.php?t=512629
Ohhhh AND a Series install:
http://www.landrover...ter-siii-22650/
