Chroming my balls.
Nigelw
Have found a place not so far away that does chrome plating http://www.belcroom.be/index.html, so the question is.....
What do I need to do to prepare them exactly??
Would they need spun on a lathe and the old plating stripped off?
What about the rust pitting in the surface? Would it need to be welded over and turned back?
Any ideas?
Can only find the Teflon coated ones and quite a few people are talking about the coating wearing thin and exposing the steel behind it, hence wanting to stay with chrome I suppose?
Was wondering what else would be fun to chrome too???
I have pinged a mail and await reply, just wondering what others thought would be appropriate.
Got a set of pitted balls on my bench to be done and then swapped for the ones on there now, am going to get a steering box shaft done too just to see what it comes back like, looking at a few other angles on this now I found somewhere that can do it.
I've had some motorcycle fork tubes rechromed before and the engineering shop did the prep as well. They checked they were straight, ground the old chrome down to remove the pits, rechromed till oversize and then ground back to size.
I imagine your balls will be harder to do than the simple tube that is a motorcyle fork.
Well, this is a subject that interests me.
I have had a few pairs of the modern Teflon coated balls, and they do this:
901C2083-5CCA-45BA-8561-173595FACCD0-224
That looks like this at Parkwood:
D8C6D22C-01A6-4197-9A08-A97057B0ADFD-224
Or like this in the desert:
As such, they are confirmed at carp.
I have just bought a pair of superb condition chrome balls and am actively collecting good condition ones:
I will never buy a Teflon ball again, they are inferior.
Rechroming original land rover balls is something that needs to happen on a large scale.
There was somebody on a forum who had his series balls 'spray painted' with a 2 pack(IIRC) plastic stuff, it looked odd as it was brown in colour, but it was very tough and tolerant of a less than perfect start finish which was just the original grit blasted, pits and all. Pits were delt with by locally added extra 'paint' followed by flatting down. The 'paint' was used on stuff used off shore. That could well be a better bet than re-chroming.
Done to death:
http://forums.roversnorth.com/showthread.php?12858-Can-I-save-these-swivel-balls
http://www.defendersource.com/forum/showthread.php?t=37019
no one ever seems to give long term feedback or updates though.
I'm about to put a teflon set on my axle rebuild ...... interested to see if someone has found a re-chrome solution.
what about spot welding the pits (if they are not too bad) profiling filing down to the ball, and then nickel plating them? http://www.frost.co.uk/brilliant-nickel-plating-modules.html
(do they have to be chrome? ... is nickel not harder?)
Nickel is your base coat, chrome over the top, as chrome is porous? (cheap 8 spoke rims). As I understood it?
I did my chrome ball with body filler, but only because the pits were above the oil line. It does 30 mile a year.
We have single pack epoxy at work and that is very hard. If you use any product on there like that, I guess there won't be much feedback, as it will outlast a chrome set?
If you could nickel and chrome plate with a 'bag' to stop stone chips I imagine they would last a very long time.
I wonder if the Teflon ball problem is the metal mix or the process of tefloning? They just look well too hard and brittle?
Why do we have so much trouble when the Yota seal seems so much more basic and even have a cut at the top? Makes me think that what we really need is an aftermarket seal with a lot more lips and less wiper force?
When I broke the 1998 V8 D1 it had genuine teflon coated swivels, now these swivels had done over 100,000 miles and only just starting to wear through the teflon coating, I have heard of some trucks doing less than 5,000 miles and it has worn throughon the aftermarket ones!!!
Hence my reasoning to want to re-chrome an original set.
I think if you have the patience required then the rubber swivel gaiters are worthwhile fitting or if you could buy aftermarket leather ones or make your own??? Then that is worth considering too.
Mr. Noisy, you are not alone in your experience with self destructing swivels of aftermarket variety, but it makes me wonder about cost effectiveness of D2 front axle swaps and moving away from the old swivel balls? Especially if reasonable condition ones get hard to come by? It works on DANA axles?
