landroversforever Posted December 13, 2022 Share Posted December 13, 2022 That looks a lot like the later ~td5 maybe column? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 13, 2022 Share Posted December 13, 2022 If you remade the column with a homebrew collapsible section (thinking a scaled down tractor PTO shaft style), would that fit past the suspension? I'm thinking that the main section of the column needs to mount as standard alignment-wise so the steering wheel isn't offset from the divers seat. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 13, 2022 Share Posted December 13, 2022 5 minutes ago, landroversforever said: That looks a lot like the later ~td5 maybe column? I think they're all now made like that, so if you buy a replacement for an older one, you'll get that style too. @Stellaghost if you get heated screens you can wire the two halves in series which means they run cooler (getting 6v each) and don't need a timer and the current draw is halved (so an easier life for the switch/relay) - I found mine still worked pretty well that way although a bit slower to clear, obviously. 1 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted December 13, 2022 Share Posted December 13, 2022 Could you add an extra UJ into the mix to get you around the obstacle? You'd need another bearing mount too, but we now don't bat an eyelid when we expect you to do hours of machining off the back of a throw away comment 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 13, 2022 Author Share Posted December 13, 2022 Just to complete my cold Mog misery Snow Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 13, 2022 Author Share Posted December 13, 2022 If you look carefully you can see a new gearbox tunnel in there... Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 13, 2022 Author Share Posted December 13, 2022 1 hour ago, CwazyWabbit said: Could you add an extra UJ into the mix to get you around the obstacle? You'd need another bearing mount too, but we now don't bat an eyelid when we expect you to do hours of machining off the back of a throw away comment I'm absolutely positive you don't want me to finish this!!!!!!!!!!!! Lol Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 13, 2022 Share Posted December 13, 2022 4 hours ago, FridgeFreezer said: I think they're all now made like that, so if you buy a replacement for an older one, you'll get that style too. @Stellaghost if you get heated screens you can wire the two halves in series which means they run cooler (getting 6v each) and don't need a timer and the current draw is halved (so an easier life for the switch/relay) - I found mine still worked pretty well that way although a bit slower to clear, obviously. In series…. That’s an excellent pun, intended or not Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 13, 2022 Author Share Posted December 13, 2022 13 hours ago, L19MUD said: Screens don't like being left on for too long so the right way to do it is to use a timer relay (stays on for a fixed time) fed by a mom on switch and then use that relay to trigger a bigger relay capable of powering the current needed by the screen. By chance I was making up some relay boards for two Defenders yesterday to do just this @L19MUD I would be extremely grateful if you could post up a picture of your heated windscreen boards once they have been wired up regards Stephen Quote Link to comment Share on other sites More sharing options...
L19MUD Posted December 13, 2022 Share Posted December 13, 2022 ⁷Wired them up today but still need wiring to the truck. The timer relays have 5 pins. The extra pin should really have a switched ignition feed but I have linked to the permanent feed as it makes the wiring easier where I am fitting. Downside is you need to turn off before switching the ignition off or it will run for the remainder of the 10 mins. Output of main relay to the left will be to the screen. Input to the timer will be from the momentary switch which is fed from and ignition switched feed so can only be turned on when ignition on. Earths will go to an earth point or the negative terminal Diagram here of the timer relay but in an application where it can handle the load itself. I am using it to power the bigger load capacity relay 3 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 14, 2022 Author Share Posted December 14, 2022 Well that's my heated windscreens ordered and thanks to @L19MUD I stand half a chance of being able to wire them up, cheers Sam Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted December 14, 2022 Share Posted December 14, 2022 Happy to help with any questions 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 14, 2022 Author Share Posted December 14, 2022 26 minutes ago, L19MUD said: Happy to help with any questions Believe me !! It would be more than questions if you were just down the road .......... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 15, 2022 Share Posted December 15, 2022 Here's my setup with the screens wired in series, just in case a picture helps... 1 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 15, 2022 Author Share Posted December 15, 2022 I've said this before, sometimes it's the little touches regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Wytze Posted December 15, 2022 Share Posted December 15, 2022 4 hours ago, Stellaghost said: I've said this before, sometimes it's the little touches regards Stephen This is not acceptable... 😁😁 That needs to be 10 mm plate at least with brackets to hang massive D clamps from🤓 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 15, 2022 Author Share Posted December 15, 2022 Gearbox tunnel progressed, been a long afternoon's work First off some former / jig making Cleaned up Use of new toy Hole cut in aluminium sheet put into jig started hammer forming At this point I decided to annealed the aluminium again Recess for gator more or less completed Dark now so that will do for today regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 15, 2022 Author Share Posted December 15, 2022 I lied !!! Was at a loose end so thought I would progress gearbox tunnel Out with the night lights Not fitting too bad after a wee bit of cutting, a little bit of work in the shrinker stretcher and I think it will be OK seat box plate over the top will neaten it up regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 15, 2022 Author Share Posted December 15, 2022 6 hours ago, Wytze said: This is not acceptable... 😁😁 That needs to be 10 mm plate at least with brackets to hang massive D clamps from🤓 Part of me is undecided with what to do in this area at the moment ,hence the end caps I was thinking of hinging both ends and using the cross member for storage ie; a place to put ground anchor pins, the caps will be very easy to remove, 10mm welded plate end caps not so easy ..lol Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Wytze Posted December 16, 2022 Share Posted December 16, 2022 7 hours ago, Stellaghost said: Part of me is undecided with what to do in this area at the moment ,hence the end caps I was thinking of hinging both ends and using the cross member for storage ie; a place to put ground anchor pins, the caps will be very easy to remove, 10mm welded plate end caps not so easy ..lol Regards Stephen Just had to tickle you, to get this explanation😁😁 And i'm happy they are not there to stay😅 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 16, 2022 Share Posted December 16, 2022 I like them !! 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 16, 2022 Share Posted December 16, 2022 9 hours ago, Stellaghost said: I was thinking of hinging both ends and using the cross member for storage ie; a place to put ground anchor pins, the caps will be very easy to remove, 10mm welded plate end caps not so easy ..lol Not sure storing recovery gear in a location that is likely to be buried when you need recovery is the best idea... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 16, 2022 Author Share Posted December 16, 2022 16 minutes ago, elbekko said: Not sure storing recovery gear in a location that is likely to be buried when you need recovery is the best idea... Good point, although if Sid gets buried that deep he will need @miketomcat and his future 6x6 crane to get him out ..lol Regards Stephen Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 16, 2022 Share Posted December 16, 2022 True, but considering the, ahem, gravity of this build some sinking may happen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 16, 2022 Author Share Posted December 16, 2022 28 minutes ago, elbekko said: True, but considering the, ahem, gravity of this build some sinking may happen I think that's a bit cheeky..........lol Considering Sid has been on a diet, diff reduction, aluminium bulkhead etc..... Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
