13 minutes ago, ThreePointFive said:
I wasn't sure when you first showed them but the wheels really do suit it. I'm so impressed how 'right' it all looks, I thought it was going to end up as a very well built, hugely capable, very badly proportioned car but it's all spot-on. Watching it come together has the same mix of satisfcation/admiration of seeing a set of skills at work and the execution of an idea as Project Binky.
I am certain you'll find a way to weld a new canvas top.
Kind words
thank you very much
Regards Stephen
100% agree about it looking outstanding and being so satisfying to follow along with.
I actually think that rightness is apparent everywhere - for example those diffs were modified to hell and back, but yet they ended up looking factory made.
There was a point in their making where I thought ‘these will be hard to get to look good’ - 25 minutes of Stephen later (100 hours later on my labour times) and it’s looking like Mercedes made it that way.
Remarkable.
  • Like 3
  • Thanks 1
Remarkable.
Couldn’t have said it better!
  • Thanks 1
4 minutes ago, Stellaghost said:
How considerate of you.....
However I'm generating enough smoke due to my brain overheating at the moment...
Regards Stephen
On a more serious note. I am sure we can help if you get stuck 😀
  • Thanks 1
7 minutes ago, Stellaghost said:
I seriously dislike wiring..but you probably already know that...lol
However I do like Q max cutters, first use this morning to cut a hole in the bulkhead for loom to pass through
Some progress on the wiring front
regards Stephen
First mount all your components.  That helps
The good
Had Sid turning over today although lights etc are still to wire up
The Idiot
Could not get diesel system bled through, since found out it helps if there is diesel in the tank !!!
The bad
Put diesel in the tank only to find my lift pump is not lifting, new one ordered, so unfortunately Sid will not breathe this weekend  although he did have a little rumble
Overall quite happy, also soldered pin back onto relay
Regards Stephen
  • Like 4
I have gone much further than this before realising there was no fuel. Sender had got hung up on the tank and showing 1/3 full, various symptoms of low on power, running poorly and then fine again, changed the lift pump and had thought the new one was also duff until I realised the tank was basically dry
Sounds like good progress though
