dangerous doug Posted September 6, 2021 Share Posted September 6, 2021 3 hours ago, Stellaghost said: Thank you. Best look at a seal modification then regards Stephen I’m not sure but I think I looked at fitting a seal on the outside of the knuckle face. It’s the only spot you can really get a seal in because of the land the bronze bush rides on. do not modify that bush, there is quite a lot of load on them 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 6, 2021 Author Share Posted September 6, 2021 17 minutes ago, dangerous doug said: I’m not sure but I think I looked at fitting a seal on the outside of the knuckle face. It’s the only spot you can really get a seal in because of the land the bronze bush rides on. do not modify that bush, there is quite a lot of load on them @dangerous doug what were yous like these seem to have a seal already, I had thought that the seal would go to the outside so the bush got lubricated within the axle case regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 7, 2021 Author Share Posted September 7, 2021 A wee bit of painting tonight regards Stephen Quote Link to comment Share on other sites More sharing options...
Wytze Posted September 7, 2021 Share Posted September 7, 2021 That thing of your's is gonna be sexy as freshly shaved and oiled leg's😁 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 7, 2021 Share Posted September 7, 2021 😳 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 7, 2021 Author Share Posted September 7, 2021 11 minutes ago, Wytze said: That thing of your's is gonna be sexy as freshly shaved and oiled leg's😁 I would most definitely not like to get lost in your mind lol regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Wytze Posted September 7, 2021 Share Posted September 7, 2021 6 minutes ago, Anderzander said: 😳 The booze took my modesty😁 1 Quote Link to comment Share on other sites More sharing options...
Wytze Posted September 7, 2021 Share Posted September 7, 2021 Would be nice to be a fly on the wall when you work 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 7, 2021 Author Share Posted September 7, 2021 1 hour ago, Wytze said: Would be nice to be a fly on the wall when you work You would spend most of your time dodging the sparks regards Stephen Quote Link to comment Share on other sites More sharing options...
Wytze Posted September 7, 2021 Share Posted September 7, 2021 2 minutes ago, Stellaghost said: You would spend most of your time dodging the sparks regards Stephen My co worker's tell me that sparks dodge me😁😁 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted September 8, 2021 Author Popular Post Share Posted September 8, 2021 Sometimes it's the little touches regards Stephen 8 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 18, 2021 Author Share Posted September 18, 2021 Bo$$cks made a bit of an oversight and had to put caliper brackets back into milling machine the reason why? did not allow for paint thickness what a donkey now sorted regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 18, 2021 Author Share Posted September 18, 2021 Where can I get stainless braided hose and fittings for my brakes, thanks in advance regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 18, 2021 Share Posted September 18, 2021 Llama4x4 will make up hoses to any length, and fitting. Be warned, if in a good mood your phone call to him may last all day Alternatively @FridgeFreezer I think used gear to make his own flexis, forget the name of the system? 1 1 Quote Link to comment Share on other sites More sharing options...
Wytze Posted September 18, 2021 Share Posted September 18, 2021 With aeroquip you can make your own. Used in motorsport for as long as i can remember. 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 18, 2021 Share Posted September 18, 2021 Probably that @Wytze, thanks 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 18, 2021 Share Posted September 18, 2021 My local hydraulic hose place made up nice lines for me some years back - and it wasn’t dear, might be worth asking yours ? 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 19, 2021 Author Share Posted September 19, 2021 Looking to the future I have a question for my more knowledgeable betters... at the moment I have an lt177 gearbox on my lightweight, it's not the best and I will need to add the gears to change ratio in the transfer box I still have the series 2a box with a series 3 bell housing in the garage, this box could also probably do with a rebuild but was fine when I was using it, one advantage of using this box would be because it's shorter it will help with rear prop length, fitting an overdrive would also make it more usable, but I'm unsure as to how the mog drop boxes will affect it thoughts would be appreciated regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 19, 2021 Share Posted September 19, 2021 What size tyres are you going for, and what is the drop box ratio again? Low range in the series box is lower, but High range likely too low -most go 1:1 transfer box ratio, even with big tyres, which means swapping out with gears from ashcroft. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted September 19, 2021 Share Posted September 19, 2021 Drop box ratio is 2:1 diff ratio is 3.54:1 if you run a 1:1 transfer box with big tyres then it’ll be “ok” on the road and give similar gearing to a defender but with a much lower Lowratio 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 19, 2021 Author Share Posted September 19, 2021 9 minutes ago, Bowie69 said: What size tyres are you going for, and what is the drop box ratio again? Low range in the series box is lower, but High range likely too low -most go 1:1 transfer box ratio, even with big tyres, which means swapping out with gears from ashcroft. Tyres are 36.8" regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 19, 2021 Author Share Posted September 19, 2021 I'm assuming a series box is not the way to go ?? Regards Stephen Quote Link to comment Share on other sites More sharing options...
missingsid Posted September 19, 2021 Share Posted September 19, 2021 If it hasn't be mentioned before, Ashcroft has a ratio calculator page where you can model this to get the best working ratios. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted September 19, 2021 Share Posted September 19, 2021 Set up with Rrc/disco lt77 1.003:1 lt230 7.08 diffs (3.54x2) 36.5 tyre if you ran 40s then it would drop rpm by around 500. What engine are you running as the gearing will greatly depend on that Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 19, 2021 Share Posted September 19, 2021 Sounds like a 1:1 set of LT230 gears are on the horizon.... Quote Link to comment Share on other sites More sharing options...
