1 hour ago, Ed Poore said:
Petrol or diesel?
Although I haven't got around to it yet and I know @Bowie69 agrees, I'd strongly consider a 1UZ-FE or 3UZ out of a Lexus rather than a Rover offering. Although space might be an issue in your case as its a very big square engine (700mm in all three axis).
In standard form it offers Tdi levels of torque across the band (crucially starting from 1000rpm) and a silly red line. Perhaps more importantly the factory ECU will run the engine out of the vehicle so no need to buy after market ECUs just to get it running. I sourced a donor car for £550 running which has everything required whereas to achieve something similar with a 4.6 it was looking at close to 4x that.
That's good into Thank you
I will be running the tdi initally, if it's not enough I will then explore the V8 route but that would not be until next year, need to see where my health is going first regards Stephen
  • Like 1
6 minutes ago, TD5toV8110 said:
How the feck did you break the end off your anvil?
The anvil came to me like that, it was a garden ornament that was getting scrapped, at some point I will repair it, also it was free so I'm not complaining regards Stephen
  • Like 1
13 minutes ago, Anderzander said:
OR….
you cut it off to make a shim …
OR….
You leaned the chassis brackets against it - and the weight broke it off
12 minutes ago, Bowie69 said:
Stephen just placed his cuppa tea too close to the edge.
There's a whole lot of tea involved in this build, for sure.
10 minutes ago, Anderzander said:
Hammer formed from 1/2” stock ?
6 minutes ago, Bowie69 said:
It's not the container weight, it is the volume contained.
Carrying the weight of your collective abuse on my shoulders.......
need to join a different forum..........
Now, what was the name of that embroidery forum..........
Regards Stephen
  • Haha 3
11 minutes ago, landroversforever said:
Time for a bit of cross stitch with 3” round bar?
You joining the stellaghost depreciation society as well..........
Predictable Ross predictable ............lol
Regards Stephen
11 minutes ago, miketomcat said:
Wait hang on a minute, you can embroider
Errr, actually I can , used to embroider album covers onto jackets years ago I had Queens Night at the Opera embroidered on mine regards Stephen
  • Like 2
  • Haha 2
  • Confused 1
Amazing what you can do with 2.5 t+e.
Does inhibit progress at airports though.
