Help request
Hello, I want to change my clutch kit.
My truck is a Land Rover Defender 110 HARD TOP 300TDI,  It was produced on 09-01-1997. The engine is 300tdi, The gearbox is a  R380
Please answer the following questions:
A) Which clutch is preferable / you would use /, for what reasons :
1) Land Rover Performance Clutch Kit - OE STC8358
Item number: 3000.950.701-S
manufactured by the company SACHS : https://www.sachsperformance.com/en/clutch-kit/zf-sachs/performance-clutch-3000950701-s
OR
2)POWERspec TDI 200/300tdi
manufactured by the company LOF clutches : https://lofclutches.com/shop/clutches/clutch-kits/powerpec-tdi-300tdi-heavy-duty-clutch/
B) For LOF clutches:
  1. What is the % higher transmitted torque of the POWERspec TDI 200/300 tdi kit compared to OEM? https://lofclutches.com/shop/clutches/clutch-kits/powerpec-tdi-300tdi-heavy-duty-clutch/
  1. What is the torque capacity of the POWERspec TDI 200/300 tdi kit in Nm ? https://lofclutches.com/shop/clutches/clutch-kits/powerpec-tdi-300tdi-heavy-duty-clutch/
  1. What is the clamping force /eject fors/ of the POWERspec TDI 200/300 tdi kit in N or kg ?
    4) What will be the weight of the pedal if I install /put/ a 2.8 TGV HS International POWERspec kit - (Also fits TDI) and a DEFENDER POWER MASTER BUNDLE Spring and Master Cylinder on my truck?
    https://lofclutches.com/shop/clutches/clutch-kits/2-8-tgv-powerspec-kit/
    https://lofclutches.com/shop/clutches/pedal-assist-products/defender-power-master-bundle-spring-master-cylinder/
    5) The weight of the pedal from point 4) is equal to or less or greater than if I mount /put/ on my truck POWERspec TDI 200/300 tdi kit and Defender POWER MASTER BUNDLE Spring and Master Cylinder?
    Thank you in advance.
I do not speak English! I use google translator.
If you have a 300Tdi, then you don’t need an expensive conversion - the standard parts are usually up to the task unless they have been damaged or contaminated.  Standard is usually cheaper and easier to source, guaranteed to fit and not cause any strange effects or complications.  Just buy good quality, like Valeo or Borg and Beck (genuine parts).  They were good enough for military and emergency service use all over the world, utility companies and the Camel Trophy, so will be sufficient for any Defender with a Tdi and regular transmission.
  • Like 2
I had a Borg and Beck clutch from a reputable source. The metal centre of the clutch friction plate gradually fell apart until the clutch failed - it was low mileage and not hard worked. Valeo for me from now on.....
I've known a Borg and Beck one go inside 12 months... I've also wiped the center out of a Valeo 130 pressure plate.
My truck is a Land Rover Defender 110 HARD TOP 300TDI. It was produced on 1997. The engine is 300tdi . The gearbox is R 380 .
OR
@slon4eto
You are asking technical questions about a company's product that few people know the answer to.
I suggest you contact LoF clutches and put your technical questions about their products in an email.
They should be able to answer your questions.
Mo
  • Like 2
1 hour ago, Badger110 said:
Clutchfix is my latest but if I’m honest it replaced a 50k +standard cheap clutch which never gave any issues
My clutchfix clutch is at 70k miles and still happily pull over 4 ton off road around farms.
  • 1 month later...
