Mo Murphy Posted January 5, 2022 Share Posted January 5, 2022 The boost ring advances the fuel timing at higher revs to give a longer burn time. They work well in my experience, though I find it makes the engine smoother rather than noticeably more powerful. Maybe that's the same thing, I don't know π Mo Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted January 5, 2022 Share Posted January 5, 2022 27 minutes ago, Mo Murphy said: The boost ring advances the fuel timing at higher revs to give a longer burn time. They work well in my experience, though I find it makes the engine smoother rather than noticeably more powerful. Maybe that's the same thing, I don't know π Mo That's completly the opposite of my understanding, but sounds sensible - thank you Moseph I felt it was much smoother, rather than more power. But I interprested it the wrong way as I had misundertodd (completly) how Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 5, 2022 Author Share Posted January 5, 2022 The Bosch VE manual gives a good explanation of the hydraulic advance mechanism which the spacer effectively modifies, I think the Video on Stegs site i think it is - is quite informative. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 5, 2022 Share Posted January 5, 2022 Basics: Mechanical fuel lift pump? New fuel filter? No air leaks?Β Something changes between start, spike and subsequent running.Β That's got to be fuel or air. Or glow plugs? Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted January 5, 2022 Share Posted January 5, 2022 (edited) Where are you taking boost pressure from? Mine was from the back of the manifold, I also controlled turbo from the same connection. Edited January 5, 2022 by rusty_wingnut Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 5, 2022 Author Share Posted January 5, 2022 52 minutes ago, rusty_wingnut said: Where are you taking boost pressure from? Mine was from the back of the manifold, I also controlled turbo from the same connection. Standard place T'd off the turbo compressor snail. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted January 6, 2022 Share Posted January 6, 2022 OK, and you take boost readings from the manifold? Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 6, 2022 Author Share Posted January 6, 2022 6 hours ago, rusty_wingnut said: OK, and you take boost readings from the manifold? No, its T'd off the pipe from the turbo to the Injector pump boost pin module. Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 7, 2022 Share Posted January 7, 2022 Could it just be some initial "sticking", but not really noticeable sticking, that you're seeing on the gauge because you hardly have any air volume to take up the spike? Probably a reading from the manifold would look fine. Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 7, 2022 Author Share Posted January 7, 2022 1 hour ago, elbekko said: Could it just be some initial "sticking", but not really noticeable sticking, that you're seeing on the gauge because you hardly have any air volume to take up the spike? Probably a reading from the manifold would look fine. Potentially, but its not just a spike on the gauge - the vehicle runs noticeably different, I'll be accelerating in 2nd very sluggish then without moving the accelerator you feel a surge, smoke goes and it suddenly accelerates and the boost pressure drops slightly. Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 7, 2022 Share Posted January 7, 2022 Could it be a collapsing hose or a kink in a hose or something? 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 7, 2022 Author Share Posted January 7, 2022 4 hours ago, elbekko said: Could it be a collapsing hose or a kink in a hose or something? Possible, but I would say its a remote chance, as I'd expect the problem to be there all the time and not just on start up (but when has a failure ever been reliable). I do have a set of Silicone air hoses to go on, I was waiting for a slightly less hospitable outside temperature to appear before having a go at it. Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 20, 2022 Author Share Posted January 20, 2022 So.. I've been driving her for some time and the sticking is happening after each re-start. - other stuff I've noticed, is that she smokes badly, I put this down to a worn engine before then dodgy injectors and now this un fathomable issue, the only thing I've not touched on this vehicle is the injector pump. The more I think about it the more items are pointing to its misbehavior.Β When I first installed this turbo back in 2020, I drove her all over the south of England and never once noticed smoking pretty much under every condition when you've got your foot on the accelerator... I hate being the stereotypical Smokey old land rover on the road. And with this latest strange fuel/boost issue I figure I've not got much to loose at this point. Will be picking up a refurb pump from Sheaf Diesel Services this afternoon. 2 Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 20, 2022 Share Posted January 20, 2022 Good luck. Β I hope that is the last round of spending to fix it. 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 20, 2022 Share Posted January 20, 2022 Fingers crossed Mav, that's a big investment ! Mo 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 20, 2022 Author Share Posted January 20, 2022 Well I tried using the logic route... and kinda hit a brick wall, so plan B - throw more money at it...Β π€’ At least defenders are "appreciating" - I keep telling myself its an investment... Its all part of the master plan... when the Mk2 Grenadier comes out, sell all my landys and buy one of them! 1 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 20, 2022 Author Share Posted January 20, 2022 Fingers crossed. 2 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 21, 2022 Share Posted January 21, 2022 Shiny shiny π Mo Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 21, 2022 Share Posted January 21, 2022 16 hours ago, Maverik said: Sheaf Diesel Services this afternoon. They are on the same Attercliffe street as Mister Gearbox, who helped me with my Roamerdrive this week.Β Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 21, 2022 Author Share Posted January 21, 2022 Pretty gutted, pump installed it's dark so not seen it properly but it looked like no change what so ever.Β Engine seems a little smoother maybe, but looked to be smoking like a train and the strange boost behaviour was exactly the same.Β Next I'll be taking the VNT turbo off and reverting back to standard. Sick to the teeth of throwing cash down the sink.Β If I didn't have some god awful attachment to this truck then it would be gone. 4 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 21, 2022 Share Posted January 21, 2022 13 minutes ago, Maverik said: Pretty gutted, pump installed it's dark so not seen it properly but it looked like no change what so ever.Β Engine seems a little smoother maybe, but looked to be smoking like a train and the strange boost behaviour was exactly the same.Β Next I'll be taking the VNT turbo off and reverting back to standard. Sick to the teeth of throwing cash down the sink.Β If I didn't have some god awful attachment to this truck then it would be gone. Ah carp. Was hoping this sorted you out. If you are keeping it then the pump being sorted will at least sort that out for the next 150k miles. Β I agree swapping back to standard would be next on the list to rule it out Β Β Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 21, 2022 Share Posted January 21, 2022 49 minutes ago, Maverik said: Next I'll be taking the VNT turbo off and reverting back to standard I was taught by Japanese mentors to "never give up", so try to keep your mojo working. I had to remove a VNT off a CRV this time last year- twice. It's almost impossible to get at; really really hard. So I am sure it will be simple for you on your truck and will eliminate another potential cause in your Cause & Effect. Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 21, 2022 Author Share Posted January 21, 2022 17 hours ago, Peaklander said: They are on the same Attercliffe street as Mister Gearbox, who helped me with my Roamerdrive this week.Β Yeah they are, I noticed a couple of gearbox places down there. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 22, 2022 Share Posted January 22, 2022 5 hours ago, Maverik said: Pretty gutted, pump installed it's dark so not seen it properly but it looked like no change what so ever.Β Engine seems a little smoother maybe, but looked to be smoking like a train and the strange boost behaviour was exactly the same.Β Next I'll be taking the VNT turbo off and reverting back to standard. Sick to the teeth of throwing cash down the sink.Β If I didn't have some god awful attachment to this truck then it would be gone. Arse ! Β Mo Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 22, 2022 Share Posted January 22, 2022 Bugger π But if nothing else itβs for you a new pump and ruled it out. we all know these things can get you down though.Β Quote Link to comment Share on other sites More sharing options...
