Clearance Tow Hitches
Anderzander
  • Anderzander changed the title to Clearance Tow Hitches
4 minutes ago, Anderzander said:
The 3500kg one came - not much corrosion on it !
Not sure if those little locking wires for the pins won’t be a pain though 🤔
Have them on most of mine and they don't cause any hassle. Also stops you not bothering putting both the R clip and lynch pin in as they hang down and swing about on the wire which is annoying enough to put the back in!
That makes sense ! Only annoying if you don’t use them. I can go with that.
On 3/24/2023 at 7:29 PM, Happyoldgit said:
Those little cables eventually corrode as they are vulnerable to road salt and carp. I put chains on mine like Uncle Ralph.
Same, I fitted a stainless chain and drilled the tow pin to take a 5mm stainless lynch pin (a standard IWT part). I hate R clips, especially in cold weather.
