Snagger Posted May 29 Share Posted May 29 Fortunate timing - Mike just released a video on the matter showing different generations of gears, the later cross drilling and the interim oil feed plate Muzaz mentioned. https://youtu.be/m8R5DM9Nwfo?si=aYdQNG28i7fMAwBw 1 Quote Link to comment Share on other sites More sharing options...
ashtrans Posted May 29 Share Posted May 29 yes the new gear is wrong even though it may have 26 teeth, you need the FRC5428 as mentioned earlier 2 1 Quote Link to comment Share on other sites More sharing options...
MuddyWinny Posted May 29 Share Posted May 29 I'm probably echoing the reply from ashtrans but the new gear in the picture is cross drilled to allow the input shaft splines to be lubricated. My understanding is that a cross drilled input gear is not available for a suffix B LT230 and hence is not the right part. You do have the option of fitting an oil feed plate but I get the impression it's not an ideal solution. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 29 Author Share Posted May 29 12 hours ago, Snagger said: Fortunate timing - Mike just released a video on the matter showing different generations of gears, the later cross drilling and the interim oil feed plate Muzaz mentioned. https://youtu.be/m8R5DM9Nwfo?si=aYdQNG28i7fMAwBw Yes I see that it was him who got me to look at my gearbox and transfer input shaft and cost me money,😂 yes I’ve had both of them side by side same length same width same bearing size only difference was pto but not needed but the cog splines them self altho they are both 26 teeth the new one is a tad wider both ends so guessing that’s the problem I’ll go for the original FRC5428 no oil holes get an oil adapter can it not just be drilled out 4 holes? Quote Link to comment Share on other sites More sharing options...
muzaz Posted May 29 Share Posted May 29 27 minutes ago, Green200tdi said: Yes I see that it was him who got me to look at my gearbox and transfer input shaft and cost me money,😂 yes I’ve had both of them side by side same length same width same bearing size only difference was pto but not needed but the cog splines them self altho they are both 26 teeth the new one is a tad wider both ends so guessing that’s the problem I’ll go for the original FRC5428 no oil holes get an oil adapter can it not just be drilled out 4 holes? Yes you can. 14 hours ago, muzaz said: You could try to drill it, but it's hardeded, especially on the internal splines. I did one on my mill with a carbide endmill, goes through with ease being careful when aproaching the spline. Some people do it with a masonry drill, works as well but probably you'll break some. The new input gear you have although the same no of teeth has a different tooth profile, that's why it binds. The FRC5428 you need has a shorter spline, probably the reason LR did not cross drill them and used the modified oil plate instead. Quote Link to comment Share on other sites More sharing options...
ashtrans Posted May 30 Share Posted May 30 its not the width or the 4 holes that are the issue, the width indicates its the wrong gear as the tooth pressure angles differ, it may run but will howl. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 30 Share Posted May 30 10 hours ago, Green200tdi said: can it not just be drilled out 4 holes? As someone said further up the thread - you can drill it but it's very hard material, and TBH although the splines wear in the undrilled ones it does take many years, the oil splasher plate should be more than enough to keep the splines happy. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted May 30 Share Posted May 30 The holes have to be eroded, not drilled. The oil feed plate will work. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 30 Author Share Posted May 30 5 hours ago, Sigi_H said: The holes have to be eroded, not drilled. The oil feed plate will work. Ok, I guess another way would to be remove it once a year on say a service grease it up? It’s not an every day vehicle anyway, I’ll look out for the plate if anyone has a link be great, Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 30 Share Posted May 30 https://ashcroft-transmissions.co.uk/product/oil-feed-plate/ Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 30 Author Share Posted May 30 18 minutes ago, Bowie69 said: https://ashcroft-transmissions.co.uk/product/oil-feed-plate/ Thank you Quote Link to comment Share on other sites More sharing options...
muzaz Posted May 30 Share Posted May 30 If you don't manage to find an oil plate and have no access to a milling for drilling the holes, have a look at this guy...he got your exact problem and managed with some masonry drills. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted May 31 Share Posted May 31 (edited) removing once a year is better than nothing. Drilled will be best. Drilling with a mesonary bit will be possible. They have a hardended blade. But you will need a lot of passion and cooling fluid. I find the YT movie not very clever. Edited May 31 by Sigi_H Quote Link to comment Share on other sites More sharing options...
Peaklander Posted May 31 Share Posted May 31 Have a good look around your area. You might find someone with a workshop as did I. In a hamlet near me is a guy with all sorts of machinery doing precision jobs for industrial customers. All on his own. He has a water jet cutter and a spark eroder amongst many things. He eroded a 6mm grubscrew with broken Allen key. He also made my Salisbury axle height gauge and dummy bearings. You might be surprised and find someone who can produce your holes. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 31 Author Share Posted May 31 On 5/30/2024 at 7:00 PM, muzaz said: If you don't manage to find an oil plate and have no access to a milling for drilling the holes, have a look at this guy...he got your exact problem and managed with some masonry drills. Cool I’ll have a look now 👍😊 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 31 Author Share Posted May 31 10 minutes ago, Green200tdi said: Cool I’ll have a look now 👍😊 Well that was interesting must of cost him a few quid in drill bits? good to see videos like this tho. thank you. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 31 Share Posted May 31 I once bought some drills that looked like masonry drills from the NEC bike show, they were brilliant, I wish I could replace them, however when ever I tried to drill through a pilot hole the carbide would break and render the drill bit scrap. In my experience it is better to just drill through with the finished size, sharpened masonry bit and not bother with the pilot hole, I have broken less bits since doing this Regards Stephen Quote Link to comment Share on other sites More sharing options...
muzaz Posted May 31 Share Posted May 31 I drilled one with a cheap 10mm carbide endmill on a mill. Went right through without any issues, the surface is not hard at all but the spline inside is. You will at least need a pillar drill and some sort of vice. Keep the pressure down on the quill when breaking through. A couple of masonry drills should not be expensive, and a 10mm carbide endmill from aliexpress costs £10 https://a.aliexpress.com/_ExXY5v9 Quote Link to comment Share on other sites More sharing options...
uninformed Posted June 4 Share Posted June 4 Even though the gear is made from a forged blank they are still heat treated. This makes the surfaces “hard” you can simply grind some of the surface where you will drill. You won’t need to go very deep, maybe 1mm. This will help to start and drill the hole. Of course it won’t help the internal side but that’s only the last bit of drilling. I don’t see the appeal in using a masonry drill bit. Yes they often have a tungsten carbide insert but their cutting geometry is very poor. A good quality HSS drill bit will do the job with prior surface grinding… 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 5 Author Share Posted June 5 Thanks all looks like the one I brough is now going back and I’ll end up with the original type and get a splash plate. 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 11 Author Share Posted June 11 On 6/5/2024 at 5:46 PM, Green200tdi said: Thanks all looks like the one I brough is now going back and I’ll end up with the original type and get a splash plate. Well all is well 4 hole one sent back and DLS have sent out the correct replacement. More new bearings to buy now.🙄 Quote Link to comment Share on other sites More sharing options...
