MJIbex Posted February 8, 2007 Share Posted February 8, 2007 I need to get a fire extinguisher for the truck; since this is something I know less than nothing about I'm after some suggestions. "Are all fire extinguishers equal?" What size should I get and does anyone have any good experiences with where to get one at a sensible price? And what is a sensible price? I looked in halfords and a 2kg powder 1 was 43 quid. Cheers Mark. Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted February 8, 2007 Share Posted February 8, 2007 Is this for competition, if so it needs to be AFFF 2.2 litres I think. If not I carry a CO2 in mine, plus two Halon, I know its banned but it works, and they are ex military so look right on the lightweight. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 8, 2007 Share Posted February 8, 2007 Like said above AFFF is usually what's required for comps. Powder isn't ideal in a vehicle, especially an off road one, as the vibrations can lead to the powder compacting at the bottom into a solid lump and then it won't work. Halon is/was the best for putting fires out, shame it's banned. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 8, 2007 Share Posted February 8, 2007 Mate of mine races. He has a Red AFFF, ..........and next to it another extinghuser - also Red. However this one is a Halon, .......sprayed red for passing scruntineers ! Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 8, 2007 Share Posted February 8, 2007 The small ones (souped up aerosol cans) you find in more domestic shops and halfords are not really enough to put out the candles on a birthday cake. Bigger is better, and when you use it empty the thing onto whatever's on fire, don't mess about. 2-3Kg is a respectable size, above that you may start having storage problems in a vehicle. I plan on having a small-ish one in the passenger area and then a bigger one stored in a quickly-accessible place in the back, that way you have options and are never far away from one. Green (halon) ones are illegal now because they make cute fluffy squirrels sneeze but lots of people have hoarded them as they're rather good. CO2 is useless for our purposes, once it blows away the fire can re-ignite. Hours of fun! Edit: Not dry powder, you want AFFF, told you an adult would be along soon... If you can find 2nd hand industrial ones on eBlag they can be a bargain as they are refillable and some have a tyre valve on the side to pressurise them - if nothing else you can re-use them as mega water-pistols Quote Link to comment Share on other sites More sharing options...
najw Posted February 8, 2007 Share Posted February 8, 2007 Like they said, minimum capacity for AFFF is 1.75 litres Or as someone once told me, carry an AFFF to pass scrutineering and Halon for putting out fires Dry Powder is not permitted for motorsport and as Mark says has been known to clump and not work Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 8, 2007 Share Posted February 8, 2007 'Collectors item' e-bay :170077649151 Nige Quote Link to comment Share on other sites More sharing options...
pugwash Posted February 8, 2007 Share Posted February 8, 2007 even better, a black one 170077652307 Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 8, 2007 Share Posted February 8, 2007 Red ones are more discreet Quote Link to comment Share on other sites More sharing options...
pugwash Posted February 8, 2007 Share Posted February 8, 2007 some people are never satisfied Quote Link to comment Share on other sites More sharing options...
dollythelw Posted February 8, 2007 Share Posted February 8, 2007 O/T but old full sized water extinguishers make great presurised EP90 dispensors with minimum modification - save loads of hassle B) Quote Link to comment Share on other sites More sharing options...
v8bertha Posted February 8, 2007 Share Posted February 8, 2007 O/T but old full sized water extinguishers make great presurised EP90 dispensors with minimum modification - save loads of hassle B) What a bloomin fantastic idea! No more refilling Halfrauds squeezy bottles from the 25l drum, or using the 0.5l syringe with the knackered seals!!... sound like bliss to me. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted February 8, 2007 Share Posted February 8, 2007 drill a hole, tap a BSP thread in it and put a PCL airline fitting in, unscrew the business end, fill with EP, pressurise to 20 odd psi and have a pump action EP gun, over pressurising leads to "entertainment" the EP can be slightly aerated when it comes out depending on how much puff you put in the can so experiment till you find the right setting for your extinguisher I have 9 litres to change on a regular basis - pump guns make it a breeze Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted February 8, 2007 Share Posted February 8, 2007 Or as someone once told me, carry an AFFF to pass scrutineering and Halon for putting out fires Thoroughly agree with this statement. I've got 2.5 plumbed in AFFF another 2.25 handheld and a n other fire extinguisher for actually putting fires out. The EP90 dispenser sounds a great idea, might well have a crack at that. Thanks for that one! H Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted February 8, 2007 Share Posted February 8, 2007 drifting O/T, but i've done the same thing with a plant sprayer thingy, drilled and tapped to take a threaded tyre valve, fill it up with oil and away you go! the hooked pipe and trigger make it rather handy. Not entirely my idea, nicked the sprayer off Roger! Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted February 8, 2007 Share Posted February 8, 2007 Mr Webster, I thought you'd have a few pints of gold top Quote Link to comment Share on other sites More sharing options...
white90 Posted February 8, 2007 Share Posted February 8, 2007 I have: 2.5lt AFFF from Nick(cheers Nick) and a 2ltire Halon(left out at AWDC events) At the Belgium Nationals a couple of years ago I watched a Disco V8 try to set itself alight luckily Jay had a small extinguisher that saved the car from a far worse fate. Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted February 8, 2007 Share Posted February 8, 2007 I have:2.5lt AFFF from Nick(cheers Nick) and a 2ltire Halon(left out at AWDC events. Why leave it out for AWDC events - I do all the Hillrallies with it on display - its only illegal to use and as long as you have the obligated AFFF as well then they shouldn't mind. Comp spec AFFF's can be picked up for £30 so it seems silly not to have at least something in the car. I've now put one in my commuting car as well! I don't find Gold Top all that good for putting out fires, must be the fat content! Quote Link to comment Share on other sites More sharing options...
white90 Posted February 8, 2007 Share Posted February 8, 2007 Thanks I never considered that Quote Link to comment Share on other sites More sharing options...
rtbarton Posted February 8, 2007 Share Posted February 8, 2007 O/T but old full sized water extinguishers make great presurised EP90 dispensors with minimum modification - save loads of hassle B) I've used a modified Calor gas cyclinder, but the fire extinguisher idea would be much better. (Suggest you paint it a different colour though and remove the lettering!) Quote Link to comment Share on other sites More sharing options...
smo Posted February 8, 2007 Share Posted February 8, 2007 Why leave it out for AWDC events - I do all the Hillrallies with it on display - its only illegal to use and as long as you have the obligated AFFF as well then they shouldn't mind.Comp spec AFFF's can be picked up for £30 so it seems silly not to have at least something in the car. I've now put one in my commuting car as well! I don't find Gold Top all that good for putting out fires, must be the fat content! Any reccomendations on where to purchase an extinguisher for £30? Quote Link to comment Share on other sites More sharing options...
white90 Posted February 8, 2007 Share Posted February 8, 2007 ebay peter Lloyd rallying Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted February 8, 2007 Share Posted February 8, 2007 Just what I would have said. I'm not a big Peter Lloyd fan, but he is often very good on price. My last couple of extinguishers have come from him at the Autosport Show. In fact I think he was doing them for £25 this year! H Quote Link to comment Share on other sites More sharing options...
V8RRC Posted February 8, 2007 Share Posted February 8, 2007 The AFFF ones don't seem to badly priced here http://www.cheapfireextinguishers.co.uk/index.asp Quote Link to comment Share on other sites More sharing options...
