Anderzander Posted September 7 Share Posted September 7 Is there a good way to get grease into all the cups on a UJ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 7 Share Posted September 7 G clamp round it to move the spider to one side. 1 Quote Link to comment Share on other sites More sharing options...
jason110 Posted September 7 Share Posted September 7 @Shackleton has just uploaded an excellent video to his YouTube on UJ’s. Well worth a watch Quote Link to comment Share on other sites More sharing options...
Steve Marquis Posted September 8 Share Posted September 8 15 hours ago, jason110 said: @Shackleton has just uploaded an excellent video to his YouTube on UJ’s. Well worth a watch I looked at the profile and didn't see it, is there a way of unearthing it (maybe there's a search technique I could usefully use) or sharing a link? TIA Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 8 Share Posted September 8 His channel is ‘Soup Classic Motoring’. 1 2 Quote Link to comment Share on other sites More sharing options...
pat_pending Posted September 8 Share Posted September 8 On 9/7/2024 at 8:36 PM, Anderzander said: Is there a good way to get grease into all the cups on a UJ? For what it's worth, after 40 years of Land Rover ownership and 45 years repairing all sots of vehicles professionally... Use molybdenum disulfide grease (CV joint grease), and warm up the joints with a hot air gun if the grease has dried in one cup (not normally a problem when you use Moly grease. Jack up a wheel so you can spin the prop's during greasing. Grease every month, if you can. Don't use cheap universal joints. Buy a decent grease gun and learn how to fill it properly. 3 1 Quote Link to comment Share on other sites More sharing options...
Steve Marquis Posted September 9 Share Posted September 9 22 hours ago, Peaklander said: His channel is ‘Soup Classic Motoring’. Any clues, I've gone past 6yrs of titles and see no mention of UJs, there are some 5yo Range Rover restoration vids which I'll look at for my defenders. Maybe it's my foggy Covid brain, but I can't see anything about them, just supercars, unicycle, lotus and sprinter stuff etc. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 9 Share Posted September 9 No sorry I haven’t watched. I just know that the Shackleton referred to by @FridgeFreezer is the chap who runs the channel to which I linked. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 9 Share Posted September 9 15 minutes ago, Steve Marquis said: Any clues, I've gone past 6yrs of titles and see no mention of UJs, there are some 5yo Range Rover restoration vids which I'll look at for my defenders. 11:55 in this video, should link to the correct time: 1 2 Quote Link to comment Share on other sites More sharing options...
Steve Marquis Posted September 9 Share Posted September 9 Pefect, thanks 😊 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 9 Author Share Posted September 9 This is similar to what George is saying: that’s about assembling it though - and I was wondering if there was an alternative to rebuilding it. On 9/7/2024 at 8:38 PM, Bowie69 said: G clamp round it to move the spider to one side. Bowie’s comment makes sense - I guess you’d just remove the one circlip and press the cup (where the grease come come out from) a little bit deeper to tighten it up? 14 hours ago, pat_pending said: warm up the joints with a hot air gun if the grease has dried in one cup I have heard farmers say they put sort it by putting a torch on the UJ - I did worry that would just burn up the seals… it hadn’t occurred to me that a heat gun would work too. I did have an air powered grease gun, and when I could get it working it seemed that the abruptness of the pressure helped get it to all the cups much more than the manual pump. 14 hours ago, pat_pending said: Buy a decent grease gun and learn how to fill it properly. This is likely the situation with that air gun though - I never really got to grips with it. It could be the guns quality but it’s more likely user error. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 9 Share Posted September 9 2 minutes ago, Anderzander said: Bowie’s comment makes sense - I guess you’d just remove the one circlip and press the cup (where the grease come come out from) a little bit deeper to tighten it up? If you want to do it that way use a socket smaller than the internal size of the circlip. 1 Quote Link to comment Share on other sites More sharing options...
Daan Posted September 9 Share Posted September 9 Here: 4 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 9 Author Share Posted September 9 Sorry I missed it the first time around Daan. So you’re not moving the cap - just using a clamp to shift the ‘spider’ across into the easiest cap. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 9 Share Posted September 9 Yup. 1 Quote Link to comment Share on other sites More sharing options...
Steve Marquis Posted September 9 Share Posted September 9 3 hours ago, FridgeFreezer said: 11:55 in this video, should link to the correct time: @FridgeFreezer and @Peaklanderthanks both for the video link, I've learned a bit about modern welding too (learned oxyacetylene in the mid 70s as nothing else was a thing). I'm going to burn too much time on that channel, cheers folks. 1 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 9 Share Posted September 9 Shackleton specialises in making things hard for himself by filming in stop motion. The episodes that caught our imagination was the series showing the restoration of a classic Range Rover. 2 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted September 9 Share Posted September 9 Easiest way is to simply remove the end you are about to grease, then, using a coloured lithium grease circulate the UJ as you pump (fnarr) Quote Link to comment Share on other sites More sharing options...
Daan Posted September 9 Share Posted September 9 6 hours ago, Bowie69 said: Yup. Yes, on the initial cup, but if you have 2 opposed cups that get all the grease, I push these cups against the spider, to close of the gap between the cup and spider. This closes off the grease path, so the grease now has to choose a different path. Like this: The nut under the G-clamp compresses both opposed cups, while the vice compresses the Rh cup against the spider (against the wooden blocks). I am greasing the cup on the left. This way, all your cups last basically forever. It is a real pain when the props are on the car though. Any other ideas, like heating up your U/J, use the correct grease all help, but are not really a solution to this problem. even a brand new U/J, quite often does not grease to all 4 cups in my experience. You only need a micron difference in gap between the U/J and the cup, or the cup seated very slightly on an angle, and the grease chooses the path of the least resistance. Dirtydiesel attempted to solve the problem, From memory, by drilling a hole and welding a nut to every cup and close off the grease paths in the spider. So have a nipple on every cup you can service them individually. Quote Link to comment Share on other sites More sharing options...
soutie Posted September 12 Share Posted September 12 I have a G Coupler for my grease gun which means that it seals on the grease nipples and pumps grease all round on the UJs. There are now cheap copies, with the original costing about £25. It however does make greasing your UJs so much easier. https://interflon.com/gb/products/interflon-g-coupler 1 Quote Link to comment Share on other sites More sharing options...
fmmv Posted September 15 Share Posted September 15 I'd also recommend the Doost D600 coupler, it positively locks onto the zerk, and is slim enough to do 300 style propshafts. Makes it much easier if you haven't got 3 hands. Struggles with the Puma u/js with the zerk in the middle of the spider ( why t.*. did they do that?) but what wouldn't? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 16 Share Posted September 16 Since using the K48 grease that Gwyn Lewis sells I've had no trouble with getting grease out of all 4 bearings on my UJs. It's similar / same stuff that Pat_Pending is recommending to use above. Much better than using GP grease. Mo Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 16 Author Share Posted September 16 That’s encouraging ! I bought some last week - some good prices on eBay: https://www.ebay.co.uk/itm/204944252165? Quote Link to comment Share on other sites More sharing options...
fmmv Posted September 16 Share Posted September 16 I too use that, and rate it, though it does make a mess when flung out. Note, it isn't suitable for wheel bearings etc. Quote Link to comment Share on other sites More sharing options...
ballcock Posted September 16 Share Posted September 16 7 hours ago, fmmv said: I too use that, and rate it, though it does make a mess when flung out. Note, it isn't suitable for wheel bearings etc. IT says it's good for wheel bearings, that link is out of stock. Quote Link to comment Share on other sites More sharing options...
