white90 Posted June 19, 2007 Share Posted June 19, 2007 Keep on it Lewis nice to see all variants of any mod especially ones that saved my drill bits trying to drill that shaft Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 19, 2007 Share Posted June 19, 2007 You can stop hating me - I didnt do the Tig, my Tig skills are somewhat lacking Loverley tig work tho Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted June 19, 2007 Share Posted June 19, 2007 I only found out on Sunday that my little brother has been TIG welding professionally for the last 7 years! I knew he was a welder but don't see him that often. Makes stainless steel hot water cylinders! I asked him to knock me up a fuel tank for the tray back. He is looking into it BTW Lewis, keep up the good work Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted August 21, 2007 Share Posted August 21, 2007 Lewis Unfortunately in his haste to reduce costs Lewis forgot to make sure it ran true, And guess what it didn't So he had to get a grown up to make him one that wasn't bent This one's not quite so cheap as his last effort. Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 21, 2007 Author Share Posted August 21, 2007 So he had to get a grown up to make him one that wasn't bent This one's not quite so cheap as his last effort. You seem to imply that you are the grown up . . . And its still cheaper than a Gigglepin drum Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted August 21, 2007 Share Posted August 21, 2007 You seem to imply that you are the grown up . . . And its still cheaper than a Gigglepin drum I could have let you talk to the weasel, god only knows what would have happened then. Quote Link to comment Share on other sites More sharing options...
Daan Posted August 21, 2007 Share Posted August 21, 2007 Unfortunately in his haste to reduce costs Lewis forgot to make sure it ran true,And guess what it didn't So he had to get a grown up to make him one that wasn't bent This one's not quite so cheap as his last effort. Dan, What dimensions are that tube? Or is it your favoured bit of solid? Daan Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted August 21, 2007 Share Posted August 21, 2007 Dan, What dimensions are that tube? Or is it your favoured bit of solid?Daan 60mm solid bar. Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 21, 2007 Author Share Posted August 21, 2007 I could have let you talk to the weasel, god only knows what would have happened then. Urgh At least it wasnt the Weetos man from Gran Fabrications - please dont make me go back there again . . . . . Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 21, 2007 Share Posted August 21, 2007 Nice job there , Just one observation , on the support end you have had a bush made up to take the 60mm bar upto the original size where it will run on the polymer bearing , So why not use a sealed roller bearing instead of the bush ? Just an observation , please tell me to go forth and multiply if you like Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 22, 2007 Author Share Posted August 22, 2007 Nice job there , Just one observation , on the support end you have had a bush made up to take the 60mm bar upto the original size where it will run on the polymer bearing , So why not use a sealed roller bearing instead of the bush ? Just an observation , please tell me to go forth and multiply if you like If I were keeping the winch then a sealed bearing would have been on the cards, but as it was already sold and just needed a straight drum thats what it got Quote Link to comment Share on other sites More sharing options...
Daan Posted August 22, 2007 Share Posted August 22, 2007 60mm solid bar. Damn you like your armoured cars dont you? Daan Quote Link to comment Share on other sites More sharing options...
muddy Posted August 22, 2007 Share Posted August 22, 2007 Cant beat a bit of weight to aid tractive effort Drum looks very nice, keep it up. Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 23, 2007 Share Posted August 23, 2007 anyone know how far up the casing the oil comes? i want to put a filler in at top up level so i can check level is right without having to drain it. Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 23, 2007 Author Share Posted August 23, 2007 anyone know how far up the casing the oil comes? i want to put a filler in at top up level so i can check level is right without having to drain it. How much oil do you put in? I find that the drum seal allows water and dirt ingress such that by the time I want to top up the oil it needs changing anyway Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 23, 2007 Share Posted August 23, 2007 How much oil do you put in?I find that the drum seal allows water and dirt ingress such that by the time I want to top up the oil it needs changing anyway recommended is 0.2 ltrs AFAIK. mine is strippped at the mo so easy to drill and tap, but tricky to put oil in to see how high it sits cos it will just flow out over my boots Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 23, 2007 Author Share Posted August 23, 2007 recommended is 0.2 ltrs AFAIK.mine is strippped at the mo so easy to drill and tap, but tricky to put oil in to see how high it sits cos it will just flow out over my boots I generally put about 400-500ml in, this comes about 2/3rds the way up the main gear (i.e the one on the end of the drum) Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 23, 2007 Share Posted August 23, 2007 recommended is 0.2 ltrs AFAIK.mine is strippped at the mo so easy to drill and tap, but tricky to put oil in to see how high it sits cos it will just flow out over my boots I've got 180ml written on the side of my bottle, think I converted that from a figure I found in fl oz or quarts or something. I think the correct amount is small enough that it shouldn't pour over your boots even with the drum seal out. This is why the seal isn't great (and leaks if you overfill) as it's only designed to be a splash seal not submersed. Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 23, 2007 Author Share Posted August 23, 2007 I've got 180ml written on the side of my bottle, think I converted that from a figure I found in fl oz or quarts or something.I think the correct amount is small enough that it shouldn't pour over your boots even with the drum seal out. This is why the seal isn't great (and leaks if you overfill) as it's only designed to be a splash seal not submersed. More oil = better, at least for me, the splash lubrication works well with a lot of oil If you fit two seals it leaks less, a lot less Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 23, 2007 Share Posted August 23, 2007 i'll just guess the height then i dont have a problem with the seal leaking when its all together. Quote Link to comment Share on other sites More sharing options...
treebloke Posted February 12, 2008 Share Posted February 12, 2008 Any idea how the drum comes off the gearbox/mainshaft end. Does it simply pull off or is something actually holding it on. I know a guy with an engineering company so I thought I would see if he could lengthen the drum and make it a little slimmer at the same time. Quote Link to comment Share on other sites More sharing options...
gsr341 Posted February 13, 2008 Share Posted February 13, 2008 Any idea how the drum comes off the gearbox/mainshaft end. Does it simply pull off or is something actually holding it on. you need to remove the upper housing , and as you look at front on theres a plate on the right hand side you need to pull this up then you can withdraw the drum Quote Link to comment Share on other sites More sharing options...
treebloke Posted February 13, 2008 Share Posted February 13, 2008 Unfortunately in his haste to reduce costs Lewis forgot to make sure it ran true,And guess what it didn't So he had to get a grown up to make him one that wasn't bent This one's not quite so cheap as his last effort. That is truly a work of art, probably never see it hanging in a gallery but 'beauty is in the eye of the beholder' so you never know. I see you used solid bar but do you think a disused propshaft would suffice, if it can turn a 35" Simex surely it would withstand the forces from a plasma rope?. Quote Link to comment Share on other sites More sharing options...
Tonk Posted February 14, 2008 Share Posted February 14, 2008 I see you used solid bar but do you think a disused propshaft would suffice, if it can turn a 35" Simex surely it would withstand the forces from a plasma rope?. a prop is only about a 3mm wall, it will bend, especially if u lengthen the drum Quote Link to comment Share on other sites More sharing options...
D9OSV Posted February 14, 2008 Share Posted February 14, 2008 Please take great care what materail you use for extending the drum. I get sent a t least one drum a month where someone has done a DIY conversion using Solid or gas tube or some other strange bit of gear and it has collasped or bent the drum in use. If your stuck for what to use or just need advice you can always ask. We also sell the billet material. Jim Quote Link to comment Share on other sites More sharing options...
