ThreeSheds Posted November 15, 2007 Share Posted November 15, 2007 Only takes a few minutes and it's good fun: LINKY. I'd bet good money that members of this forum score highly Apologies if it's already on here... This is my score anyway Quote Link to comment Share on other sites More sharing options...
landmannnn Posted November 15, 2007 Share Posted November 15, 2007 I only got 88%, mind you my brain is worn out. Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted November 15, 2007 Share Posted November 15, 2007 Er....I only got 60%.... Mind you I run a coffee shop for a living......so my exscuse is....well, Im a thick git! Am I still allowed to hang around on here then??!! Gonna keep trying....I WILL pass, dammit! Quote Link to comment Share on other sites More sharing options...
white90 Posted November 15, 2007 Share Posted November 15, 2007 82% but a pass is a pass Quote Link to comment Share on other sites More sharing options...
rtbarton Posted November 15, 2007 Share Posted November 15, 2007 94% - some of the questions were a bit iffy - eg one mentions a FORCE of 50 PSI, the one about the induction stroke correct answer is atmoshere pushing it in, to me this is the same as suction. The parallel electric circuits were ambiguos, for example the parallel circuit shows two bulbs in parallel with a switch in series so I put that down as series/parallel. I got the drive ratios wrong, I was looking at it from the point of view of the relative rotation of the gears, rather than as if they were in an actual gearbox. Quote Link to comment Share on other sites More sharing options...
jericho Posted November 15, 2007 Share Posted November 15, 2007 90% - still can't figure out the pair of electric fans. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 15, 2007 Share Posted November 15, 2007 94% Yes HONESTLY ! Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted November 15, 2007 Share Posted November 15, 2007 yeah right there were too many electrical question there for you to get that sort of score Quote Link to comment Share on other sites More sharing options...
landmannnn Posted November 15, 2007 Share Posted November 15, 2007 94% - some of the questions were a bit iffy - eg one mentions a FORCE of 50 PSI, the one about the induction stroke correct answer is atmoshere pushing it in, to me this is the same as suction. The parallel electric circuits were ambiguos, for example the parallel circuit shows two bulbs in parallel with a switch in series so I put that down as series/parallel. Although if you put a switch truely in parallel it would go bang (or at least some smoke would escape) Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted November 15, 2007 Share Posted November 15, 2007 I must be thick then with 70% . And I''m supposed to be fairly clever for the job I do. :o Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 15, 2007 Share Posted November 15, 2007 yeah rightthere were too many electrical question there for you to get that sort of score they will be me 6% Thank gawd no squeeeeelze questions Nige Quote Link to comment Share on other sites More sharing options...
russ3120 Posted November 15, 2007 Share Posted November 15, 2007 72% but i is a fickky Quote Link to comment Share on other sites More sharing options...
rtbarton Posted November 15, 2007 Share Posted November 15, 2007 Although if you put a switch truely in parallel it would go bang (or at least some smoke would escape) True, but one of the circuits showed a switch in parallel with a bulb. If the question was worded "Are the bulbs in series, parallel or series/parallel" there would be no ambiguity. If a single bulb is connected to a battery, is it a series or parallel circuit? Quote Link to comment Share on other sites More sharing options...
TomG Posted November 15, 2007 Share Posted November 15, 2007 84% - some tricky ones in there! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 15, 2007 Share Posted November 15, 2007 94% - I bluddy hate electrics Les, Quote Link to comment Share on other sites More sharing options...
landmannnn Posted November 15, 2007 Share Posted November 15, 2007 If a single bulb is connected to a battery, is it a series or parallel circuit? Leave that one for Nige to answer....... Quote Link to comment Share on other sites More sharing options...
ashtrans Posted November 15, 2007 Share Posted November 15, 2007 82% but I am no good at electrics and have has 2 glasses of wine ! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 15, 2007 Share Posted November 15, 2007 I hope you got all the gear questions right Dave have has 2 glasses of wine ! Evidently! Les. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 15, 2007 Share Posted November 15, 2007 Did this last week on Difflock. Got 88%. Time for a career change perhaps!! Quote Link to comment Share on other sites More sharing options...
wormhole Posted November 15, 2007 Share Posted November 15, 2007 True, but one of the circuits showed a switch in parallel with a bulb.If the question was worded "Are the bulbs in series, parallel or series/parallel" there would be no ambiguity. If a single bulb is connected to a battery, is it a series or parallel circuit? well if we are being picky it should be "Are the lamps in series, parallel or series/parallel" got 84% Quote Link to comment Share on other sites More sharing options...
sheeppimp Posted November 15, 2007 Share Posted November 15, 2007 78%, ok with that far better than i thought it would be . btw I did badly on gears ashcrofts have nothing to fear from me Quote Link to comment Share on other sites More sharing options...
danshepp Posted November 15, 2007 Share Posted November 15, 2007 thought i was doing well untill i read what the rest of you managed. 80% B) for me a pass is still a pass Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted November 15, 2007 Share Posted November 15, 2007 88%.........Its far to late for this sort of thing. shame it dose not tell you which ones you got wrong. Rod Quote Link to comment Share on other sites More sharing options...
white90 Posted November 15, 2007 Share Posted November 15, 2007 it does if you review the results at the end Quote Link to comment Share on other sites More sharing options...
steve_a Posted November 15, 2007 Share Posted November 15, 2007 74% - I hate gears, my brain doesn't work on them. Phraseology for the intake stroke question. I didn't read the question on one (lever question about which would be more difficult) and after I clicked two I knew it was the other answer... Quote Link to comment Share on other sites More sharing options...
