Roman Posted August 17, 2005 Share Posted August 17, 2005 Hi all, Just got back from a long trip and discovered that everybody has moved over from LRE to this forum. So her I am too. Now, what's the body of opinion regarding these shocks? How do they perform? Are they robust enough for long trips? Do the remote reservoires make a big/little difrerence for the overall score? Any comments will be much appreciated. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 17, 2005 Share Posted August 17, 2005 Never heard of them old chap, so absolutely F all use Nige Quote Link to comment Share on other sites More sharing options...
Roman Posted August 17, 2005 Author Share Posted August 17, 2005 Nige, At Billing they were on display at the Equip4x4 and SR stands. I may be wrong but they are part of the Extreme suspension kit. Quote Link to comment Share on other sites More sharing options...
SteveG Posted August 17, 2005 Share Posted August 17, 2005 These are the ones used on the extreme suspension set-up from Scorpion. You might try posting posting on LRO forum as a few on there use extreme kit. I also saw the King shocks at Billing that they use for racing. These are very heavy duty shocks. They also are component based so you can strip, replace seals and re-gas in the field too. Expensive too, but if it provides good reliability and saves buying multiple sets of shocks, over the long term it probably pays back. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 17, 2005 Share Posted August 17, 2005 I've been dribbling at the Equipe site, the A Frame rose jointed thingy is a joy to behold... .if the shocks are of this qaulity, shame not to have them on the mantle piece as "Art Work to dribble over", so nice shame to use, place it next to the A Frame I'm thinking about ! ? Nige Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 17, 2005 Share Posted August 17, 2005 Those A-frames are about £400-500 IIRC Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 17, 2005 Share Posted August 17, 2005 ...dribble.......... Quote Link to comment Share on other sites More sharing options...
landrover598 Posted August 17, 2005 Share Posted August 17, 2005 Those A-frames are about £400-500 IIRC £417 for a few bits of pipe welded together and 3 joints Something that is nice a easy to build in the garage Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 17, 2005 Share Posted August 17, 2005 out of 10mm plate eh Nige? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 17, 2005 Share Posted August 17, 2005 Damn! beaten to it! Quote Link to comment Share on other sites More sharing options...
western Posted August 17, 2005 Share Posted August 17, 2005 out of 10mm plate eh Nige? Shouldn't that be 10mm wall tube Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 17, 2005 Share Posted August 17, 2005 Yep, thinking of it I have some <ahem> thick wall tube about to hand, Oh yes ok, its 38mm CDS OD with a 12mm wall .....................PYSL then It is on the possibilities listing.............. Nige Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 17, 2005 Share Posted August 17, 2005 its 38mm CDS OD with a 12mm wall .....................PYSL then Quote Link to comment Share on other sites More sharing options...
rick Posted August 18, 2005 Share Posted August 18, 2005 from what i can make out, Oram dampers are thinly veiled Italian copies of an Ohlins damper. Ohlins make some of the best (pure racing) road and off-road dampers in the world. I emailed them several years ago about tech specs and possible sales/distribulorship in this part of the world, but they either don't speak English or just didn't want to talk to me..... Quote Link to comment Share on other sites More sharing options...
Petergg Posted August 18, 2005 Share Posted August 18, 2005 I have them on my 90, they work Ok, had to replace rear's due to stone damage on rods and then oil leak they are 2 years old and had a good bashing. Peter Quote Link to comment Share on other sites More sharing options...
MogLite Posted August 18, 2005 Share Posted August 18, 2005 its 38mm CDS OD with a 12mm wall .....................PYSL then Have you got any of that spare ? About 120cm would make an awesome track rod for MogLite Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 18, 2005 Share Posted August 18, 2005 Andy, you're steel fettish is getting nearly as bad as Nigel's Mark, are you sure the Equipe price is right? IIRC, the 'Rock kit' is basicly the A-frame and that's about £900 I don't know much about the Oram dampers. They look to be pretty good quality from the photos I've seen but I've never seen one in peices so I can't really tell. Probably the person to ask is Julian Read, its the sort of shock that the racers use. Remote reservoirs are useful if you really give you're shocks abuse (at speed) as they mean there's more oil in them so they don't overheat as fast and they also act like a radiator to loose some of the heat. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 18, 2005 Share Posted August 18, 2005 £417 as stated above is the price from http://www.lrsoffroad.co.uk Does the rock kit include the rose jointed trailing arms? Quote Link to comment Share on other sites More sharing options...
fisha Posted August 18, 2005 Share Posted August 18, 2005 gulp how much. not my cup o tea i must admit for the UK's scene - rock climbing certainly, but mud pluggin? . i'd rather have slightly extended articulation, then whack a locking diff in . . . . if i had any money that is Quote Link to comment Share on other sites More sharing options...
steffUK Posted August 18, 2005 Share Posted August 18, 2005 I run orams now for more than 3 years and have no problem with them. they are also rebuildable and damping and rebound can be adjusted via a little pump (between 1 and 7 bar pressure). Neil Redpath (sp?) destroyed them on the OBC some time ago. He broke off the top of the damper. I know have a set of 14 inch orams with external reservoir but i still have to fit them and test them. so all in all, i'm pleased with the setup. Quote Link to comment Share on other sites More sharing options...
Top90 Posted August 18, 2005 Share Posted August 18, 2005 Been running orams with my extreme kit for two and a half years now. Only problem I had was that the origional seals started leaking after a year, by which time the design had been improved, so scorpion stripped them down and rebuilt them with the modified seals for me (free ). Being able to change bits and not be forced to buy a new shock is a plus for me. Richard Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 19, 2005 Share Posted August 19, 2005 Andy, welcome to the "heavy AF overengineering club" I'll have a measure and be back to you I have spent a while on the Equipe site, nice but Serious F overpriced, and the thing that worries me (otgher than £900 squid) is the fact that a RR a frame is in SHEAR whereas the rose joint is screwed in to the tube and is in tension rather than shear ? Mind you the £900 bit has dione it for me Jeeeeeeeeeeeezz I could but loads of thick wall tube / heavy plate for that much £ Nige Quote Link to comment Share on other sites More sharing options...
teslo Posted March 19, 2013 Share Posted March 19, 2013 Hello, i am searching for some service manual/instructions or parts diagram for Equipe4x4 art.003 and art.004 shocks - older desing (same as was used by scorpion racing extreme kit - without remote reservoir).I want to know to what pressure they should be inflated as one of the shocks started to leak and i want to check the pressure in it.many thanks Quote Link to comment Share on other sites More sharing options...
discomark10 Posted March 19, 2013 Share Posted March 19, 2013 I've been dribbling at the Equipe site,the A Frame rose jointed thingy is a joy to behold... .if the shocks are of this qaulity, shame not to have them on the mantle piece as "Art Work to dribble over", so nice shame to use, place it next to the A Frame I'm thinking about ! ? Nige My questions is why do all the makers or the rose joint Aframe joint orientate the rose joint that way, with the more extreme setups it would be better to mount it upright, so you get the unrestricted moment from the joint for axle angle (articulation) Quote Link to comment Share on other sites More sharing options...
zardos Posted March 19, 2013 Share Posted March 19, 2013 Hello, i am searching for some service manual/instructions or parts diagram for Equipe4x4 art.003 and art.004 shocks - older desing (same as was used by scorpion racing extreme kit - without remote reservoir).I want to know to what pressure they should be inflated as one of the shocks started to leak and i want to check the pressure in it. many thanks From memory of when I changed the seals on mine they were supposed to be 200PSI. Will try and dig out the values I was given for pressure and oil quantity. Though I used Argosheild not Nitrogen to fill :-) Quote Link to comment Share on other sites More sharing options...
