Hitower Posted December 9, 2009 Share Posted December 9, 2009 Hi all... Well, its time for me to buy a winch for my defender 90. I was thinking about this one? champion C12000 EWX 12V Electric Winch. What do you think? Quote Link to comment Share on other sites More sharing options...
suggs Posted December 9, 2009 Share Posted December 9, 2009 depends on what you want it for, serious winching or a bit of green laning. if you can afford a bit more then look at a Superwinch EP9, i and many others use this winch... winches are very much "you get what you pay for" last thing you want is for it to let you down when your really stuck Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted December 9, 2009 Share Posted December 9, 2009 depends on what you want it for, serious winching or a bit of green laning. if you can afford a bit more then look at a Superwinch EP9, i and many others use this winch... winches are very much "you get what you pay for" last thing you want is for it to let you down when your really stuck You've been out of the loop too long H around that price range, cheaper actually, the winch of choice would have to be the TDS Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 9, 2009 Share Posted December 9, 2009 I would also suggest a TDS. The only issue I can see with them is that the rustproofing on the tie bars is a bit non existent. Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted December 9, 2009 Share Posted December 9, 2009 You must have a bad one? mine are fine after 2 years on the front of the disco. Quote Link to comment Share on other sites More sharing options...
Hitower Posted December 9, 2009 Author Share Posted December 9, 2009 the winch is for greenlaning... i do some ocasional serious off road... Quote Link to comment Share on other sites More sharing options...
suggs Posted December 9, 2009 Share Posted December 9, 2009 You've been out of the loop too long H around that price range, cheaper actually, the winch of choice would have to be the TDS next your be telling me the Dodo is extinct Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 9, 2009 Share Posted December 9, 2009 Maybe it was - it wasn't mine just one I saw. A new set of tie bars was supplied FOC anyway - though I think if I had one I'd get a metalworker to turn up a set of stainless ones like the Milemarker has Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 9, 2009 Share Posted December 9, 2009 TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS TDS. Quote Link to comment Share on other sites More sharing options...
SteveG Posted December 10, 2009 Share Posted December 10, 2009 You must have a bad one? mine are fine after 2 years on the front of the disco. I think it's the other way round, you have a rare good one Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 10, 2009 Share Posted December 10, 2009 Yep, mine are a bit rusty -lack of maintenance I say in my case though Other than that, it's excellent Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 10, 2009 Share Posted December 10, 2009 the winch is for greenlaning... i do some ocasional serious off road... Seriously trying to think ,as to why you need a winch for green lanes ?? If its that bad, should really you be there !!!! Quote Link to comment Share on other sites More sharing options...
Hitower Posted December 10, 2009 Author Share Posted December 10, 2009 Well,,,,for greenlaning no...but i tend too push the limits of the car every sunday morning....and i ve been stuck sometimes....And theres was time that me and my friend got sutck and theres was no winch that could help us. i just want to know if the winch is good or not... there is one for sale for about 290 euros.... Quote Link to comment Share on other sites More sharing options...
calle-fas Posted December 11, 2009 Share Posted December 11, 2009 I have two winches from Warn. I'd no doubt go TDS if I were to buy another electric winch. Sick and tired of stripping the winches to get mud and water out of gearbox and motor. Now sealed and rubber hoses for drainage I hope to save some of that work though. But even worse, the cone brake get's oily after a while and you need to clean that too. Quote Link to comment Share on other sites More sharing options...
SteveG Posted December 11, 2009 Share Posted December 11, 2009 Seriously trying to think ,as to why you need a winch for green lanes ?? If its that bad, should really you be there !!!! Are you serious Tim????? There are numerous reasons for where a winch could be used on a greenlane and none of them reckless, irresponsible etc etc. Gently getting over an obstruction or rocks after slipping off in to a ditch Getting through a section of deep ruts (tractor) without causing further damage. etc etc btw I seem to recall using a winch to pull you out on a lane in Wales. Steve Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted December 11, 2009 Share Posted December 11, 2009 I would also suggest a TDS. The only issue I can see with them is that the rustproofing on the tie bars is a bit non existent. Mine have gone all rusty, I was thinking of having some stainless ones turned up as someone else mentioned but its a great winch none the less! Dave. Quote Link to comment Share on other sites More sharing options...
Hitower Posted December 11, 2009 Author Share Posted December 11, 2009 well but a tds is not a champion, or is it. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 11, 2009 Share Posted December 11, 2009 It's not no. The good people are reccomending a TDS instead Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted December 11, 2009 Share Posted December 11, 2009 TDS 9.5 Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted December 11, 2009 Share Posted December 11, 2009 Its the same winch made in the same chinese factory. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 11, 2009 Share Posted December 11, 2009 I thought it was the Kingone winches that were the same as the Bowyer TDS? http://www.electricwinchshop.co.uk/catalog/184-King-One-TDS-Range-9500-to-16500lb.html Unless Champion also buy it and re-brand, as Bowyer/Kingone does? Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted December 11, 2009 Share Posted December 11, 2009 Its the same winch made in the same chinese factory. To a different spec Quote Link to comment Share on other sites More sharing options...
zoltan Posted December 11, 2009 Share Posted December 11, 2009 Despite their Far Eastern ancestry, these TDS ones work OK? Maybe not as good as XYZ brand but adequate for non competing, occasional use? Quote Link to comment Share on other sites More sharing options...
BennyB Posted December 11, 2009 Share Posted December 11, 2009 We use a TDS on the rear of our comp truck, not had any problems and have done a whole season of comps with it. Value for money you can't beat them. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 11, 2009 Share Posted December 11, 2009 Kingone is the same anyway because one of the ones here still has a Kingone logo on it Quote Link to comment Share on other sites More sharing options...
