renault4 Posted October 10, 2010 Share Posted October 10, 2010 why are there retainers on the bottom of the rear springs but not on the front springs, AND, why do they sell retaining brackets for front springs? it's all very mysterious as I am going about fitting +4" shocks and spring relocating cones in an effort to gain more articulation and am a little miffed as to why land rover thought that the front springs would not need fixing to anything but the rear ones do. any ideas? Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted October 10, 2010 Share Posted October 10, 2010 why land rover thought that the front springs would not need fixing to anything but the rear ones do. The front springs can't fall off if they get over extended 'cos the shock absorbers go up the middle. Without the clip holding them to the axle the back ones have nothing to hold them in place once the spring is fully extended. Nick Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 11, 2010 Share Posted October 11, 2010 The front springs DO have retaining bars. Mo Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 11, 2010 Share Posted October 11, 2010 Mine didn't have them either, but I picked some up on fleebay for a couple of squid and put them on. Quote Link to comment Share on other sites More sharing options...
pedro Posted October 11, 2010 Share Posted October 11, 2010 my 300tdi 110 axles def do have front and back spring retainers, the mount plates are different sizes (cos of bigger springs at back!) Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted October 11, 2010 Share Posted October 11, 2010 The fronts do have retaining clips... Instead of being straight bars, they have a bend in them to allow the damper to mount. Looks like a someone left something out....? Quote Link to comment Share on other sites More sharing options...
renault4 Posted October 11, 2010 Author Share Posted October 11, 2010 looking in my parts catalogue (110 1987 0nwards) page 436 it clearly shows no retainer on the front. Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted October 11, 2010 Share Posted October 11, 2010 Had 5 Discos, 2 Rangies & now a 90, all of them have had retainers on front/rear if a shock was to break at the bottom your spring would 'fall' out John Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 11, 2010 Share Posted October 11, 2010 Ah I see, we're wrong, parts book right. Ok but why bother asking if you know already ? Mo Quote Link to comment Share on other sites More sharing options...
western Posted October 11, 2010 Share Posted October 11, 2010 why are there retainers on the bottom of the rear springs but not on the front springs, AND, why do they sell retaining brackets for front springs? it's all very mysterious as I am going about fitting +4" shocks and spring relocating cones in an effort to gain more articulation and am a little miffed as to why land rover thought that the front springs would not need fixing to anything but the rear ones do. any ideas? front springs cannot fall out as damper is inside the spring, so how do you get the spring off ? rear springs if over extended can fall out, so bottom end is anchored to axle/spring seat plate. Quote Link to comment Share on other sites More sharing options...
LR90 Posted October 11, 2010 Share Posted October 11, 2010 Ah I see, we're wrong, parts book right. Ok but why bother asking if you know already ? Mo TBH I thought front spring retainers were after market only so would not be in the parts book. If they were/are standard fitment I'd be very interested in the p/n as a gen alternative has to be considered. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted October 11, 2010 Share Posted October 11, 2010 Microcat doesnt show any spring retainers on the front. The curved ones you see advertised in various places never seem to have a landrover part number either... Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted October 11, 2010 Share Posted October 11, 2010 front springs cannot fall out as damper is inside the spring, so how do you get the spring off ? Err, you take the damper off? The front end on a standard car doesn't articulate as much as the back either and with standard shocks and springs I don't think it was anticipated it would ever be a problem. At the back end on a standard car the spring should be able to just lift off it's seat, with over length shocks the spring can dislocated but "should" be guided in by the blade on the outside of the spring seat, provided the spring hasn't fallen out of it's lower seat. The parts catalogue may show a part that was "optional" but not fitted to a standard car. I'm not familiar with them being fitted to RRC as standard. Quote Link to comment Share on other sites More sharing options...
renault4 Posted October 12, 2010 Author Share Posted October 12, 2010 Ah I see, we're wrong, parts book right. Ok but why bother asking if you know already ? Mo the reason I am asking is because of this obvious dichotomy that exists between the parts book and what other people have fitted to their vehicles but thanks for your input Mo. Quote Link to comment Share on other sites More sharing options...
Cat_J Posted October 12, 2010 Share Posted October 12, 2010 Not fitted to mine which has (had) original (buggered) suspension from factory. I've bought some for my new setup which will be standard height but +2" shocks, so more articulation. Quote Link to comment Share on other sites More sharing options...
robhybrid Posted December 2, 2010 Share Posted December 2, 2010 depends on how you fit longer shocks i.e weather you do it right and suitably alter the turret to match the shock. But I have run +5 shocks without the need for spring retainers on the front of my 90 whilst using it for winch challenge. if you use shorter/stronger springs or set the shocks up (in my opinion wrong) so that thay have masses of droop but bottom out on compression(needing longer bump stops) then spring retainers and possibly spring relocators on the front may be needed. on my whinch challenge vehicle at full articulation only my drivers side front spring dislocates by about 10 mm, the passenger side one goes loose enough that I can just about move it but does not dislocate. my springs are ome and give approximately 2"lift. Quote Link to comment Share on other sites More sharing options...
jbs Posted December 2, 2010 Share Posted December 2, 2010 I've never ever had front spring retainers on any of my trucks-2 x 90 and 1 x 110 I've only ever viewed them as after market parts anyway's-when did L/R ever fit them? Quote Link to comment Share on other sites More sharing options...
nicks90 Posted December 2, 2010 Share Posted December 2, 2010 /\/\/\ not got any on my 90 either. so parts book IS right. Quote Link to comment Share on other sites More sharing options...
