What she's reet bonnie mind!
gibbon
it's not that bad - if you look through a net curtain in the fog from 500 paces........
as for going back to school.....well, skip that one and just buy a saxo and backwards baseball cap and join the maccy d's crew would be a lot better......innit
OMG, but love the description ................
What I’ve done so far:
Removed the body
Converted the engine from EFI to standard twin SU carbs
Wonderfull, turned a RR into a pile of scrap, and gone backwards re fuelling :)
followed by the classic gem :
Known Problems
Carbs have some crud in them and one of them has a sticking float so the fuel sometimes overflows. The carbs need stripping and cleaning to get the full potential out of this engine.
Brilliant, not only backwards but done badly too :)
and then the finishing gems :
Things left to do
Roll Cage is a must
Tank needs securing
Water pipes to the radiator are only semi-temporary. You’ll need to buy a few more rubber bends so you don’t have those nasty white pipes running down the middle of the car
Header Tank is only tied to the back of the chair.
Brakes need oil. They should work. They worked fine before. I’ve removed the servo so it should just be a matter of putting oil in and bleeding them (assuming I’ve connected all the pipes to the master cylinder correctly).
To do the engine justice it needs two straight through exhaust pipes. It still has the cats on at the moment so you should hear a lot more of that V8 rumble once removed.
Fit a battery.
Outstanding Private Pile
This could be a great ongoing thread of Nasties :D
Nige
