TheBeastie Posted August 11, 2012 Share Posted August 11, 2012 I want to be able to attach magnetic signage for my 4x4 Response group or for my RAYNET group (depending upon activity) to the sides of my Defender. The signs are about 615mm x 150mm. I have salvaged some old PC cases where the matrerial used is proper steel (and thus magnetic). My thinking is that if I put them powder coated side against the aluminium and fix them I should be OK on a corrosion front but how best to fix them? Do I just glue them, or should I use a sort of rubber sheet between. Alternatively would somehow using Velcro be better. Has anyone done anything like this before and if so then what seems to have worked best? I may also put some onto the roof so I can use a magmount for a PMR radio I have just got. Any ideas much appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2012 Share Posted August 11, 2012 a sheet of steel mounted on inside of the panel, maybe glued on with tigerseal or similar means no holes to drill in panels, or if the 90 has rear side windows put the signs inside, then they are easily visible & can't be stolen. Quote Link to comment Share on other sites More sharing options...
Blackfiesta123 Posted August 11, 2012 Share Posted August 11, 2012 In rainbows in tiverton they do a pack of stickers letters and numbers. That go on a a magnetic sheet which is white. Iv also seen them in other shops. Think ther about £5-6. Well worth a look. Same as this. But ther cheaper in the shops. http://www.ebay.co.uk/itm/4-SETS-MAGNETIC-SIGN-MAKE-YOUR-OWN-COMPANY-VAN-SIGNS-/160861075205?pt=UK_Car_Parts_Vehicles_Automobila_ET&hash=item2574113705 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 11, 2012 Share Posted August 11, 2012 I like Ralph's idea, sitck something on the inside of the doors. Wonder if the magnet would pick up the door frame? Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted August 11, 2012 Share Posted August 11, 2012 Magnetic forces obey an inverse cube law which, put simply, mean that you need to be very close to the steel for the magnet to stick. I have some number plates which I have put magnetic material on the back of so I can change the plates on my trailers quickly and they will only stay on if they are in direct contact with the metal of the trailer. I think your chances of getting magnetic signage to stick to a piece of steel if there is a 2mm layer of aluminium bodywork in between are pretty slim, and it certainly won't work unless the steel is right up against the inside of the Ali. If this going to work for you, you need to put the steel on the outside of the body. Nick Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted August 11, 2012 Author Share Posted August 11, 2012 Thanks for input guys. Not too encouraging since the whole idea was to get a fairly big and prominent Lothian 4x4 Response or Lothians RAYNET sign onto both sides of the vehicle to provide publicity and also clarity when attending events. The vehicle will not necessarily be static and the signs are too expensive to go billowing off in accordance with Nick's inverse cube rule (not heard of that one but do not doubt it! Certainly do not want steel on the outside, and equally do not want the signage on a permanent basis, so it looks perhaps like a non-starter. Also means the time spent stripping the Karrimat off the side walls was wasted :-) Back to the drawingboard but thank you gentlemen for saving me having two expensive signs flapping off going round the bypass!! Malcy Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 11, 2012 Share Posted August 11, 2012 Do you have a roofrack or bars, if so you could attach coated steel plates to the sides, front and back. Quote Link to comment Share on other sites More sharing options...
G4FUJ Posted August 13, 2012 Share Posted August 13, 2012 Looks like Thule roofbars in your avatar - presume you are still using them? Why not make a couple of brackets to hold the PC case metalwork you've sourced, then you could stick the magnetic signs to them. Keeps the sign up out of the reach of small fingers that have a habit of 'playing' with stuck on signs if they are in reach... Quote Link to comment Share on other sites More sharing options...
Tanuki Posted August 13, 2012 Share Posted August 13, 2012 I tried something similar to put a magmount 450MHz UHF antenna to the roof of a Defender: 6-inch-swuare piece of thin steel plate duct-taped to the inside of the roof and magmount on the outside. It seemed to hold - until we hit the first significant bump. There was a loud thud as the steel plate untaped itself and dropped off in the back; the magmount ended up dangling by its feeder. I ended up duct-taping the magmount to the roof on the outside, and forgetting about the steel plate. This them survived 1200 miles of motorway-travel without budging. --Tanuki. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 13, 2012 Share Posted August 13, 2012 How well would it work if you glued a number of rare earth magnets (get the polarity right!) to the inside of the panel? Quote Link to comment Share on other sites More sharing options...
G4FUJ Posted August 13, 2012 Share Posted August 13, 2012 I tried something similar to put a magmount 450MHz UHF antenna to the roof of a Defender:... I ended up duct-taping the magmount to the roof on the outside, and forgetting about the steel plate. This then survived 1200 miles of motorway-travel without budging. --Tanuki. You were lucky - even though duct tape is good stuff. I've watched a magmount (rally radio) taped to the roof of a Disco become dislodged as he started off on a stage (very low speed) and swing on the cable 'til it went through the rear door window! Glass everywhere - an expensive day! All my antennas are firmly fixed. Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 13, 2012 Share Posted August 13, 2012 I tried something similar to put a magmount 450MHz UHF antenna to the roof of a Defender: 6-inch-swuare piece of thin steel plate duct-taped to the inside of the roof and magmount on the outside. It seemed to hold - until we hit the first significant bump. There was a loud thud as the steel plate untaped itself and dropped off in the back; the magmount ended up dangling by its feeder. I ended up duct-taping the magmount to the roof on the outside, and forgetting about the steel plate. This them survived 1200 miles of motorway-travel without budging. --Tanuki. But now you have no ground plane? Quote Link to comment Share on other sites More sharing options...
Tanuki Posted August 13, 2012 Share Posted August 13, 2012 The "ground plane" is capacitive between the base of the magmount and the metal of the vehicle roof. It doesn't depend on magnetic coupling; the RF doesn't 'know' what holds the disc of the magmount to the roof.At 450MHz there's plenty of capacitance between a 6-inh-diameter metal disc and the roof, even if there was a mm or so air-gap! But now you have no ground plane? Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 13, 2012 Share Posted August 13, 2012 Fair enough, brain fart there for a moment, never mind Quote Link to comment Share on other sites More sharing options...
zardos Posted August 13, 2012 Share Posted August 13, 2012 You could try repainting you landrover with a base coat of magnetic paint http://www.amazon.com/Magnamagic-Magnetic-Receptive-Wall-Paint/dp/B0007KRDK8 Quote Link to comment Share on other sites More sharing options...
zardos Posted August 13, 2012 Share Posted August 13, 2012 Or you could try some of temporary whiteboard paper that sticks to most stuff but you can peel off (use static charge to stick I think) e.g. http://www.amazon.com/Brewster-WPE90261-Dry-Erase-Message-Marker/dp/B000TW0QT4/ref=pd_sbs_op_2 Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted August 13, 2012 Author Share Posted August 13, 2012 Thanks for the continued input which has made (mostly) interesting reading. I am now wondering about the idea of putting steel bracket plate onto "roof rack" - it is 3 Thule roof bars with homebrew angle iron sides. I may go for slightly smaller signage but like the idea of it being out of easy reach. I am also thinking though of gluing plate to roof to take a PMR magmount I have acquired but think I will def use PU adhesive rather than gaffa tape after others' experiences. Shame I removed all my insulation from one side but hey! it is a Land Rover Quote Link to comment Share on other sites More sharing options...
western Posted August 13, 2012 Share Posted August 13, 2012 for the antenna mount if it's a mag mount, attached a angled steel bracket to the roof bar for it so sit on. Quote Link to comment Share on other sites More sharing options...
muddy Posted August 13, 2012 Share Posted August 13, 2012 Rivet press studs ti thé side panels. Just remove thé studs and replace with à single rivet, no one questions rivet placement on a défender! Will. Quote Link to comment Share on other sites More sharing options...
Pastycrimper Posted August 14, 2012 Share Posted August 14, 2012 How well would it work if you glued a number of rare earth magnets (get the polarity right!) to the inside of the panel? I think this is a good idea - The magnetic "stick" would probably be stronger than the glue to body panel Quote Link to comment Share on other sites More sharing options...
mozwal Posted October 1, 2014 Share Posted October 1, 2014 Just bought some magnetic signs for my new 110 utility, glad I got them a bit smaller than the back panels as I've had to stick them on the front doors - this might be a solution for you? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted October 1, 2014 Share Posted October 1, 2014 Just bought some magnetic signs for my new 110 utility, glad I got them a bit smaller than the back panels as I've had to stick them on the front doors - this might be a solution for you? Only doors on late model Defenders are made of steel, earlier types had steel frames clad in aluminium. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted October 1, 2014 Share Posted October 1, 2014 Make sure any steel you put for the magnetic signs to cling to are very flat and smooth , and clean when the signs are applied as they wont stay for long at speed otherwise ! Quote Link to comment Share on other sites More sharing options...
