=jon=
Mounting Auto Dead Pedal
Hi
To those who have done an auto conversion - where did you mount the dead pedal?
I've just got one, and it looks it's a case of drilling 3 holes on the side of the bulkhead - there doesn't appear to be any existing holes that it would line up with. Is it just a case of finding a spot that feels 'comfy' and taking the plunge? :wacko:
Cheers
Jon
Share this post
Link to post
I have the same thing. I was going to ask the 50 th anniversary owning peeps for a picture.
Share this post
Link to post
I've found some pics from a LHD US Spec model:
Still to find any RHD equivalents tho :)
Share this post
Link to post
Half of the conversions I've seen use the dead clutch pedal ! Not that I'm recommending this method
Share this post
Link to post
A mate used a bit of old shelf racking angle, bolted in place with a piece of carpet glued to it...
Share this post
Link to post
I'll dig out the parts manual
I had a look at the parts info that I use on here, found this Footrest automatic ------------ in interior trim section
http://www.allbrit.de/UNI.cfm?PAGE=769402&SPRACHE=EN
the footrest part
http://www.brit-car.co.uk/product.php/84292/2691/footrest
the mounting bracket
http://www.ebay.co.uk/itm/LAND-ROVER-FOOTREST-BRACKET-DEFENDER-RANGE-ROVER-4-0-4-6-P38-NEW-BTR1875-/350225888345
Share this post
Link to post
I've got the dead pedal kit from Ashcroft:
But there's no fitting instructions, just wondered if it was trial and error or if there was a 'right' location to mount it!
Share this post
Link to post
I was wondering about doing that purely so it looks like its still standard! I'll be making my own auto shifter from the Original gear stick too.
Share this post
Link to post
I didn't bother fitting one on my 90. I'm not that tall but found the bottom of the footwell reasonably comfortable.
Share this post
Link to post
I was hoping the parts manual would have a diagram indicating fitting, plan b ask if anyone has a anniversary 90 they could take a couple of shots of
Share this post
Link to post
+1 :)
I used a discovery auto brake pedal .HTSH
Share this post
Link to post
I don't get on with the footwell I might measure the angle on my other auto and just match that.
Share this post
Link to post
Bizarrely, my '95 RRC has one, despite being factory fitted with an R380. It's a nuisance as it stops me stretching my leg on long drives.
I'd recommend you try driving without one first, and if you find it uncomfortable, then fit one after sitting in the car for a bit with varied trial positions until you find what you want. You could always make slotted holes to allow adjustment.
Share this post
Link to post
I will be in the position of fitting the Ashcroft item to my 300TDi soon as I am currently in the process of fitting an auto conversion.
I will leave it off at first to see how I get along without one and only then will I decide on whether to fit it and if so, the exact position that is comfortable for me.
Another consideration is my pedal lock, I have to make sure that it isn't going to interfere with that.
Share this post
Link to post
Got someone to fit it and it's pretty limited on mount options due to bulkhead.
IMG_3103.JPG.9aeeabea2d84964811f66cff50a5b0e1.JPGIMG_3147.JPG.331693f6eea9a6912a45f83b6807a5ec.JPGIMG_3148.JPG.c2081cd42b6634b470c8bde557d17dc2.JPG
I found it pretty steep
So with someone providing fettling help
I now have this
Share this post
Link to post
As someone has resurrected this old thread..............................
Decided against the footrest, after nearly a year of driving the auto I have not felt the need to rest my left foot on anything other than the floor. Took it back to Ashcroft for a refund.
X-Eng pedal lock fits fine, even with the larger foot-plate & rubber.
Share this post
Link to post
I like the foot rest but it will depend on your own size and preference. I appreciate they aren't for everyone.  How do you find the fat pedal ? I haven't put mine on yet. Worried it might make the pedal noticeably higher. Does it seem like the rest pedal would block the pedal lock ?
Share this post
Link to post
The original piece looks more like something to stop your toes rubbing the paint off the bulkhead, more than an actual footrest?
Share this post
Link to post
I created a 'fat' brake pedal by welding a piece of metal either side of the original Defender brake pedal, sufficient to keep a standard RRC or Disco auto pedal rubber in place. This worked perfectly with the X pedal lock.
I noticed a while back that the dead pedal on my RRC is quite bent, presumably from someone pushing against it. I never bothered straightening it. I guess it can't be that stronger an assembly.
Share this post
Link to post
I fitted mine a while back, but forgot about the thread :unsure:
There is a hole for one of the panel fixings there already, I used this as the rearmost hole, put it on at a comfy (to me!) angle and drilled the front two holes. I find it worthwhile, but I've got stumpy legs which don't reach the bulkhead!
Share this post
Link to post
Any pictures? or measurements :)
I'm about to send my bulkhead for galvanising and once it goes back on the 110 will be auto so ideally want to drill prior to galv :)
I have the same footrest from Ashcroft
Cheers
Share this post
Link to post
Here you go. I *think* that the back hole was there already with one of the plastic push pin things the same as the other two in the pic, so I enlarged the hole, loosely bolted it up, sat in it, set the angle and drilled the other holes.
Share this post
Link to post
