L19MUD Posted January 25, 2023 Share Posted January 25, 2023 1 hour ago, Stellaghost said: I know exactly what you mean my original belting wings have been on for a couple of decades and not sagged, however they don't stick out anything like the above, the parlock look good but totally the wrong shape for my requirements, the belting will do until I find something better regards Stephen What about Dibond sheet? Can normally pick a load up second hand cheaply from building sites where they use them for signage etc and then using your skills you could make a die to form them in the shape you want and make a couple of sets up for when/if you bend them. They are light, stiff and strong. The Alu faces can also be easily painted Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 25, 2023 Author Share Posted January 25, 2023 40 minutes ago, L19MUD said: What about Dibond sheet? Can normally pick a load up second hand cheaply from building sites where they use them for signage etc and then using your skills you could make a die to form them in the shape you want and make a couple of sets up for when/if you bend them. They are light, stiff and strong. The Alu faces can also be easily painted I have some of that and the instructions say you have to cut the internal joint aluminium away to form shapes I could use 3mm aluminium and then bond some insertion rubber onto it, but the same issue remains once bent it is to reshape, plus you also stand to deform some of the lighter panels such as the ones I made yesterday Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 25, 2023 Share Posted January 25, 2023 The fabricated ali arches on this 101 always looked right to me: 3 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 25, 2023 Author Share Posted January 25, 2023 Earth straps fitted 6 in total Should be enough I think Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 25, 2023 Author Share Posted January 25, 2023 Shocker reservoir problem resolved Bonnet still close nicely Regards Stephen 4 Quote Link to comment Share on other sites More sharing options...
steve b Posted January 25, 2023 Share Posted January 25, 2023 Looking very good Stephen, it must be close to being driveable now. Steve 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 25, 2023 Author Share Posted January 25, 2023 Eh electrics........ That's all I'm saying........ Regards Stephen Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted January 25, 2023 Share Posted January 25, 2023 Only one wire needed surely to the stop solenoid. Can always bump start it... 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 25, 2023 Share Posted January 25, 2023 26 minutes ago, Ed Poore said: Only one wire needed surely to the stop solenoid. Can always bump start it... I'm sure our man Stephen could knock up a starting handle Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 25, 2023 Author Share Posted January 25, 2023 2 hours ago, landroversforever said: our man Stephen That's a bit presumptuous in these times Ross..... I identify as a Roach..........lol Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted January 25, 2023 Share Posted January 25, 2023 Hey Stephen, Looking good as always..... But...... Galvanic corrosion on the earth strap connections..... (it will start where the ss bolt touches the ally panel and moisture is present) Maybe use some boaty stuff like Tef-Gel or maybe Anti Seize/coppersilp or similar. Australia day here! 🤪 Cheers Dave 1 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted January 25, 2023 Share Posted January 25, 2023 (edited) Edited January 25, 2023 by TD5toV8110 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 25, 2023 Author Share Posted January 25, 2023 16 minutes ago, TD5toV8110 said: Hey Stephen, Looking good as always..... But...... Galvanic corrosion on the earth strap connections..... (it will start where the ss bolt touches the ally panel and moisture is present) Maybe use some boaty stuff like Tef-Gel or maybe Anti Seize/coppersilp or similar. Australia day here! 🤪 Cheers Dave Bolts are all going to be sealed against moisture Happy Australia day Dave Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 26, 2023 Author Share Posted January 26, 2023 Vent panel fitted today using rivetnuts drilled them slightly smaller and hammered them in so extra tight regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted January 26, 2023 Author Popular Post Share Posted January 26, 2023 Started fitting my @FridgeFreezer not for me shelving today What a bloody hassle and only one done so far First some aluminium strip to go on the inside to stop rivets pulling through Now in position Masking tape Then some sikaflex to tidy the joint up it's not quite as neat as I would have liked, but it's on and staying on until or if I get something better regards Stephen 8 Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 26, 2023 Share Posted January 26, 2023 Looks pretty good from here 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 26, 2023 Share Posted January 26, 2023 That shape sits nicely! fits well with the Sid. 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted January 26, 2023 Share Posted January 26, 2023 Looks good. You won't know until you flex it again but is there any risk of the rear part hitting the tyre and the tyre then ripping it off? Might need a slight trim? 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 26, 2023 Author Share Posted January 26, 2023 Well the nearside front was a hell of a lot easier than the rear Both nearside on, not looking too bad Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 26, 2023 Author Share Posted January 26, 2023 10 minutes ago, L19MUD said: Looks good. You won't know until you flex it again but is there any risk of the rear part hitting the tyre and the tyre then ripping it off? Might need a slight trim? You've echoed my thoughts, yes may need Mr Stanley time will tell regards Stephen Quote Link to comment Share on other sites More sharing options...
Tim94 Posted January 26, 2023 Share Posted January 26, 2023 Looking pretty good! Maybe another possibily to use in the future may be 2 or 3mm HDPE sheet. Seems to be a little bit more rigid then rubber belt, but still flexible etc. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted January 26, 2023 Author Popular Post Share Posted January 26, 2023 Front nearside shot with bonnet back on Adding the wheel arch makes it look less wide now I think, granted a good bit wider than a standard lightweight, but not too bad overall Standard lightweight 59" wide Sid 74" wide Disco 1 70" Quietly pleased the way the width has turned out.... Regards Stephen 8 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 26, 2023 Share Posted January 26, 2023 12 minutes ago, Stellaghost said: Quietly pleased the way the width has turned out.... You should be singing from the rooftops! That looks great! 1 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 26, 2023 Share Posted January 26, 2023 I have to admit they look pretty good. Mike 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 26, 2023 Share Posted January 26, 2023 It’s looking fantastic - the whole thing is a credit to you. Outstanding 👏🏻 1 Quote Link to comment Share on other sites More sharing options...
