Bowie69 Posted June 7, 2023 Share Posted June 7, 2023 These really do feel like finishing touches to me, certainly be more 'finished' than LGT was in september when it had a tablet gaffered to the gauge cluster for a dash. Clearly you have more wiring to do and just putting it off? 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 7, 2023 Author Share Posted June 7, 2023 30 minutes ago, Bowie69 said: Clearly you have more wiring to do and just putting it off? Seen right through me...... However, loads of wiring experts at Summer Sisters..............I hope...lol Regards Stephen 3 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 7, 2023 Share Posted June 7, 2023 Offroad cutlery made me chuckle Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 8, 2023 Author Popular Post Share Posted June 8, 2023 Pan hard rod bracketry now sorted As was for temp testing A piece of 3" x 2" box a small piece shaved off to allow access to lube nipple previously made brackets cut off and cleaned up Tacked on gusseted and painted Complete Regards Stephen 8 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 8, 2023 Author Popular Post Share Posted June 8, 2023 Redneck repair issue...lol History first... Around 25 yrs ago my lightweight was in a friend's garage overnight whilst I was doing some repairs. Early evening I got a call from guys I knew in the fire brigade to tell me the garage was on fire, but my lightweight was relatively ok ( they had recognised my lightweight and had the decency to pull it out before it got too damaged ) Damage consisted of blistered paint, damaged beyond use tyres, bonnet was up so had hoses to renew and a partially melted brake master cylinder reservoir, so reservoir was still holding fluid and brakes were fine so it has stayed in service until present day. The other week I tried to bleed brakes with a gunisons easybleed and ended up squirting some brake fluid out of the top of the reservoir, queue redneck repair using some of this reservoir 30 mins after repair i successfully bled the brakes using the easybleed I love the plastic padding stuff, always does what I need it to do Regards Stephen Ps. I will get around to changing it at some point....... 5 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 8, 2023 Author Popular Post Share Posted June 8, 2023 Cooling system finished off, well I hope so it's warming up at the moment and no signs of leaks as yet First an easy bracket to support header tank Then I cheated and went the route of LGT and forgo the delights of a heater, for now I hasten to add An oversight with intercooler pipework, needed to remove flexi pipe to get radiator plug out..duh I'll let it run for a wee while and hopefully it will be OK Regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 8, 2023 Author Popular Post Share Posted June 8, 2023 So results of some initial flexing Tyre at lowest point is 39" off the ground Now the bad Mud flap is in the way and could possibly get ripped off so I've had to trim things a wee bit Some assistance required Does not look as nice, may have to do rear mudguards again but extend the to the outside of the back body Here thoughts if any please regards Stephen 7 Quote Link to comment Share on other sites More sharing options...
elbekko Posted June 8, 2023 Share Posted June 8, 2023 Looks pretty decent. Could you fit those extensions with a pin for road use? 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted June 8, 2023 Share Posted June 8, 2023 How about a mud guard over the rear of the tyre that is mounted to the axle - a bit like the set up on the BMW GS trail bikes? Steve Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 8, 2023 Author Share Posted June 8, 2023 3 minutes ago, elbekko said: Looks pretty decent. Could you fit those extensions with a pin for road use? Never thought of that, thank you, could certainly look at something for road use Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 8, 2023 Author Share Posted June 8, 2023 3 minutes ago, steve b said: How about a mud guard over the rear of the tyre that is mounted to the axle - a bit like the set up on the BMW GS trail bikes? Steve That would certainly make it look different Regards Stephen Edit, only problem being there is not a lot of room on full flex... Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted June 8, 2023 Author Popular Post Share Posted June 8, 2023 I'm annoyed with myself, far too premature cutting mudguards, have altered the other one and it looks OK, at least I only have one side to do... Some quick angle iron in the gabro Fitting regards Stephen 6 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 8, 2023 Share Posted June 8, 2023 From memory yours is a 200tdi, if so I've never needed to remove the radiator bung as the bleed pipe is quite high so it's always bled up fine. Mike 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 8, 2023 Share Posted June 8, 2023 39", so for us young 'uns that's a whole metre off the ground.... Think you got LGT beaten! Amended guards look great! 1 Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted June 8, 2023 Share Posted June 8, 2023 Would it be an idea to move the bracket to the other side of the rubber if possible? I’m scared for your tyres giving it a little smooch 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 8, 2023 Author Share Posted June 8, 2023 3 minutes ago, dangerous doug said: Would it be an idea to move the bracket to the other side of the rubber if possible? I’m scared for your tyres giving it a little smooch They shouldn't........ The tyres would hit angled section of aluminium first, but it they do I will hack them off and start again....... Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
hurbie Posted June 8, 2023 Share Posted June 8, 2023 2 hours ago, Stellaghost said: then I cheated and went the route of LGT and forgo the delights of a heater, for now I hasten to add isn't the heater outlet supposed to be a loop , instead of closing the outlet's ? 1 Quote Link to comment Share on other sites More sharing options...
NRS91 Posted June 8, 2023 Share Posted June 8, 2023 A quick reminder for those too lazy to scroll back through the thread on their phone... What wheelbase you running? And if it's stretched where did you put the extra length? F/R? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 8, 2023 Author Share Posted June 8, 2023 2 minutes ago, NRS91 said: A quick reminder for those too lazy to scroll back through the thread on their phone... What wheelbase you running? And if it's stretched where did you put the extra length? F/R? Wheel base is 97" , Did not extend chassis, just re-designed rear chassis and moved spring hangers back to suit, hope that helps Regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
NRS91 Posted June 8, 2023 Share Posted June 8, 2023 1 minute ago, Stellaghost said: Wheel base is 97" , Did not extend chassis, just re-designed rear chassis and moved spring hangers back to suit, hope that helps Regards Stephen Cheers! Interesting to know! Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted June 8, 2023 Share Posted June 8, 2023 19 minutes ago, Stellaghost said: They shouldn't........ The tyres would hit angled section of aluminium first, but it they do I will hack them off and start again....... Regards Stephen Ah I couldn’t tell from the photos. It flexes up nicely! You think you’ll ever go back to radius arms after that sort of result? Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted June 8, 2023 Share Posted June 8, 2023 Awesome as always! Quick question...... When Sid is on the straight and level it looks like only an inch ish until axle hits bump stop. Could that be an issue when driving any undulating terrain? Can you trim the bump stop, or it has to be that long to protect the shocks? Seems a shame there is so much flex but bugger all up travel. 1 Quote Link to comment Share on other sites More sharing options...
NRS91 Posted June 8, 2023 Share Posted June 8, 2023 1 minute ago, TD5toV8110 said: Awesome as always! Quick question...... When Sid is on the straight and level it looks like only an inch ish until axle hits bump stop. Could that be an issue when driving any undulating terrain? Can you trim the bump stop, or it has to be that long to protect the shocks? Seems a shame there is so much flex but bugger all up travel. They look like extended bump stops, would be worth checking the closed length on the dampers to make sure they won't bottom out if you go to standard bumps Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 8, 2023 Author Share Posted June 8, 2023 1 hour ago, dangerous doug said: Ah I couldn’t tell from the photos. It flexes up nicely! You think you’ll ever go back to radius arms after that sort of result? Good question, probably not, have had good flex in the past but not like this, it won't do too many road miles so not overly worried about body roll although I'm hoping that will have been reduced with a totally non steel body Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted June 8, 2023 Author Share Posted June 8, 2023 29 minutes ago, TD5toV8110 said: Awesome as always! Quick question...... When Sid is on the straight and level it looks like only an inch ish until axle hits bump stop. Could that be an issue when driving any undulating terrain? Can you trim the bump stop, or it has to be that long to protect the shocks? Seems a shame there is so much flex but bugger all up travel. At the moment I'm running 1" lower than standard springs, I may put the original + 2" back in at some point, this will push the bump stop back up, not sure as yet, need to see what it's like offroad, I guess it's still a work in progress Regards Stephen 1 1 Quote Link to comment Share on other sites More sharing options...
